Forum Replies Created
MillemisBRONZE MemberActually there is not much more to read about than what you already know from the box and the Masterlink Handbook.
It does what it says (no sw updates required ?).A must have tool for those who still install/maintain ML setups.
MillemisBRONZE MemberWhat I could think of, is to make a (plywood or alike) insert….
…..something that lets you connect and halfways hide the conversion cable – and then stick your iPad with velcro to that.I doubt that you can find a way to ‘Dremel out’ in order for the iPad and the cable to fit into the original mould.
But – who knows – maybe you will come up with a solution….to show here.And yes it is a pity that you can’t use a newer iPad with the A3 – it was a nice idea and quite good sounding.
My own – with the original iPad – still works with Spotify and Radio Paradise/TuneIn (older versions)….at least last time I tried.
Nowadays it works as a clock and stays so……just for nostalgia.MM
MillemisBRONZE MemberWhat would really be interesting for me, in the future when the Theatre will work with Mozart speakers, is to use 2 A5’s as additional temporary surround speakers. The battery would allow for placement where a power outlet is not available.
It would be cool to be able to snap one from the tv setup for listening in the garden (BT or Wifi) and be sure that it would know it’s role as a surround speaker, once it is back again ?
MillemisBRONZE MemberHi MM, The A5 does not allow feeding analogue audio into the USB-C port. However, it can connect to a computer using a USB-C cable and thhis will play the computer audio to the speaker, as well as charging the speaker. Kind regards, Steve.
Hi Steve
Thanks for clarifying.
MillemisBRONZE MemberThe problem is….that you on the A5 only have 1 USB-C port.
As long as the battery is full, you – theoretically – can use this for feeding audio (has to be tested, though).
But having to swap cables to charge * in the midst of an album, would be a no go for me.
(I am not aware of a solution/dongle that could charge the battery and pass audio through at the same time).The A5 was made for wireless feeding of audio.
Imo there is nothing wrong with that……unless you absolutely want to connect a turntable (or an older Beosystem ?)*Would be interesting to know, if connecting to a computer also includes charging?
MillemisBRONZE MemberHonestly….do you really think you can hear a difference using the A5?
MillemisBRONZE MemberWhy not just airplay from your Roon device to the A5?
MillemisBRONZE MemberThere are 1 woofer and and 1 tweeter – and then two tweeters, one on each corner.
And then there is DSP magic builtin.
MillemisBRONZE MemberA fully working BS Theater………with all new ‘satellite’ speakers for surround/rear/height ?
MillemisBRONZE MemberWhich version of the BV7 do you have?
Do you have a centerspeaker also added?
MillemisBRONZE MemberNot knowing which version of the BV7 you have and the configuration overall…..the most obvious reason is, that you can only add surround speakers, if you also have front speakers.
MillemisBRONZE MemberBut the pictures with the designers holding it over the shoulder like an old gettoblaster is… Too much cheesy!
I would not do that (not for long) – it is pretty heavy.
MillemisBRONZE MemberIn the specs they write: Mozart 2.0 platform.
I wonder what the 2.0 means/will bring?
MillemisBRONZE MemberGerman speaking/understanding can watch here.
Der Beitrag ist online.
MillemisBRONZE MemberWell – of course you are right.
However, it will be compared to the Beolit xx – but it is in any way better (again imo).The size makes it a portable/moveable speaker/BS…..with a ‘sound’ that is big ?
The only way to judge it, is to see and hear.
As with any speaker/BS this is not for everyone.Looking forward to hear what people – who had a proper listen – will say.
MillemisBRONZE MemberI had the opportunity to listen to the BS A5 today (in Struer).
Pretty amazing for the size – as a stereo setup it sounds even better, of course.
I did not make photos…..those, that you can see tomorrow at launch day, will be better anyway.
Starting tomorrow you can see/hear it in the shops – pictures will certainly not do this rather small speaker justice.
With the Mozart platform and the future options this will bring to it, it – in my opinion – is a resonably priced product.
I am sure it will sell well.
I wonder if I can find a place for it at home ?
N.B.
If is possible to use it as a BT speaker only, if that is what you’d want….and you can charge your phone on top of it.MM
MillemisBRONZE MemberHi there and welcome.
Maybe this helps
MillemisBRONZE MemberThe new A9 5th edition arrives this Wednesday!
And the official launch of the Beosound A? is on Thursday…..as far as I know.
MillemisBRONZE MemberThe linked ir eye is the right one – ad the description states.
Please remember the required cable!
The BeoSound Core version without IR had the type nr. 2797. The newer is type nr. 3051.
21 April 2023 at 19:47 in reply to: The Future of BeoWorld Membership Levels – Your Thoughts? #45908 MillemisBRONZE MemberHi 9LEE and Keith
Thank you both for thinking ahead – we need that!9LEE wrote:
‘So, we have the saying “If you’re not paying, YOU are the product”. I’m not sure where it was first said, but it’s very true. Companies who offer amazing platforms for free need to be getting their money from somewhere and most of it is simply the selling of your data, or having huge amounts of advertising. BeoWorld has neither, and never will have.’This is one main reason I stick to the Beoworld forum.
I’d like as much basic knowledge of B&O and the possibilities etc as possible to be free – including the access to the old and the old, old forum.——
Call the interested person, who wants to write/ask or even contribute a ‘Basic Member’.
No trying to ‘sell-stuff-or-wanting-to-buy-stuff-posts’ however, should be allowed for the basic members.The member with full access to everything could be called ‘VIP Member’.
Whatever you decide, it is a good idea to have only two levels.
Of course it needs to be visible on the website what the difference/the benefits of being a full/VIP member is…..including that one then contributes financially to the future of the forum.
