matador
Forum Replies Created
Viewing 20 posts - 801 through 820 (of 845 total)
  • matador
    I believe “damiendada” is some sort of spamer because his two post are just “I agree and was asking myself the same…”
    KolfMaker, nowadays the PSU are small. I dont know about the empty room size into BL6000 bt couldn’t you fit a PSU, feed from the main power socket to the voltage you need and tuck it somewhere inside the beolab? That would also makes your mod totally independent of the beolab electronics and rule out any related problem if they happen?
    in reply to: Back to old things: Beovox P50… #34679
    matador
    As another member would say… Progress!
    IMG_E9537
    IMG_E9538
    matador
    Thank you Guy, after a little search the Beolink MCL82 type 2041 works with the BS5000 and BC7700. The search also returned a little extract from the Beoworld product page that says: “It was superseded by the later MCL2 system which used Beolink 1000 codes.”
    So I’ll assume it may potentially not work with moderne remotes. When I had a full 5000 system, I used little cheap IR repeater to help the return of the IR signal to the remote. It did work when the same repeater don’t with modern Beo remotes (1000/4/6/5000). So the theory is it wont work.
    To the OP, apologies for this little out of topic, I felt like it didn’t deserved a full thread on it’s own. It’s now ended.
    matador
    I made some notes when I used an MCL sensor as a Beolink PC IR sensor. The three connections that you require are: Ground – Brown IR Data – Yellow +5v –
    Hi Guy, does that mean you can use MCL IR sensors (square ones) with more modern hardware that need round sensors ?
    To be more precise, would an MCL82 type 2041 sensor be able to control a beolink passive ?
    Thank you.
    in reply to: BeoLab 3500: how to fix ML input selection? #34433
    matador
    Another lead here Beolab 3500 Standalone
    It is said that the speaker is triggered with a 5V signal in the powerlink socket.
    Never heard about this solution that I would find easy and perfect, but the OP says it works.
    matador
    Hi, nice project, but wouldn’t the bluetooth signal be too weak if the module is mounted inside the speaker?
    in reply to: Back to old things: Beovox P50… #34678
    matador
    Still thinking on the better way to fix the magnet. In the meantime I’d like advices on something: the frets.
    They’re in a coarse and stiff fabric glued on a thin panel made of wood and plastic for the wedge. the fret is fixed to the speaker with weird velcro strips, some in the groove in the edge of the speaker, and more wide bands in the flat surfaces of the front panel (those looks like added afterwards, not originals). The fabric is folded to follow the beveled shape of the wedge and not deformed like in the S45 or C30 I’ve seen.
    I’d like to know if this fabric is original or not. It is actually in not so good shape and the speaker will benefit of changing it all (once the drivers are fixed!) but if they are original, I’d rather try to rescue them.
    I’ve noticed P45, which seems to be technically identical have everything needed to clip their frets, like holes in the front panel which P50 don’t have.
    So the two question I have are:
    • Are those frets original (fabric and structure)?
    • How where they originally fixed to the enclosure?
    Below some pics. Thanks to alls.
    in reply to: A question for Geoff Martin on BL8000 Damping… #34341
    matador
    Hi Bill, thank you for the explanation. It helps.
    This is a schematic view of the Beolab 8000 internals:
    BL 8000
    From top to bottom: top plate, bass port, tweeter, 2 woofers, amplifier section, base cone.
    The new damping looks like this:
    Damping Original
    Then after your comment, it blocks the high frequencies from the tweeter, but allows low frequencies coming from the woofers to “fill” the whole speaker, right?
    I should add that if the kit didnt come with instructions, I would have placed them like that:
    Damping Alt
    To “push” all the air towards the bass port.
    in reply to: Back to old things: Beovox P50… #34677
    matador
    Hi Alls,
    Got the P50!
    First of all, they’re big and heavy. Despite being very thin, they make My S45-2 look like a portable speaker!
    Second, of course and as expected the 4 woofer are seized. I extract the two woofers from speaker 1 and was able to remove the magnet quite easily. Now the battle is to stick him back with the right alignment. What I’m the most afraid is to damage the coil in my attempts. One of them already has the coil wire flying out of the base cylinder that only begs to be cut!
    I’m currently studying the Beoworld II forum about the better process to fix this.
    Stay tuned.
    in reply to: connections help ? #34783
    matador
    Hi Dariod,
    Sorry if I tell you things you already know but as you said your newbie…
    All your speakers are powered speakers that don’t need an amplifier to work.
    Normally, they all have a line in socket that allow you to use them with a simple “RCA to anything” wire, sparing you from the need of expensive Powerlink cables.
    Now, if you want to build an home cinema with all those speakers and be able to listen to music, manage scenarios, speakers allocation and more, the easiest way would be a Beosystem 3 or 4. It’s an AV system that stand between the TV and the speakers and can do… A lot of things… But they’re not cheap.
    Or you can search for dolby boxes with line out (to your speakers) or Powerlink out (maybe Almando or something like that…) but then the music part would need to be handled by your TV.
    Good luck.
    in reply to: Beo products for hotels #34742
    matador
    Hi Jim,
    Regarding prices I would not be a good source of information. I live in Paris and the second hand market in local ads is crazy, you can find a Beovision MX for free one day, and the other day another add with the same TV around 400€. There is currently a Beogram 4002 @ 2500€.
    The eyes are rare, so rare that when I sold a beosystem 3 to a Swiss guy, he did send me his own IR eye for me to check the BS was working and I had to send it back, luckily with the Beosystem 3. So do the math: somebody want to sell one, he knows there is “Bang & Olufsen” printed on it, he looks for similar ads, he don’t find any then he puts a high price! Easy.
    But I also know that depending on countries this rules do not ever apply. Each time I hear about second hand bargains on the forum I say to myself, “why do I not live in that country”!
    Regarding your boxes, It don’t looks like B&O to me but I never opened that kind of box, so I don’t know for sure.
    Good luck.
    in reply to: Using the Playmaker in 2022… #34779
    matador
    To me the only thing preventing the PM to be “future proof” is the lack of support for 5 Ghz wifi. In my case this is not a problem because wifi works well and must stay 2,4 Ghz to allow standalone wifi speaker compatibility and sensitive connections are hardwired.
    The ability of using it as a tiny basic Audiomaster is perfect to use a spare pair of Beolab.
    I too thought of using a playmaker for TV, but the main problem is the lack of audio output in modern TVs. Of course you can use any audio extractor but I hate to have a collection of boxes and PSU behind the TV.
    As for Airplay 2, You’re right, it may be a major downside. But when you’re streaming from a computer, it’s not a problem in since you can add and select many Airplay 1 devices.
    Thanks for your kind words.
    in reply to: Back to old things: Beovox P50… #34676
    matador
    Thank you again Julian.
    in reply to: A question for Geoff Martin on BL8000 Damping… #34339
    matador
    Thank You Geoff.
    in reply to: A question for Geoff Martin on BL8000 Damping… #34337
    matador
    Thank you Geoff for your answer, I was just worried my question became “invisible” with new topics coming along…
    I adjusted the piece around the bass port tube, but what I don’t understand is isn’t the V shaped piece (the one just below the entry tube one) preventing the air coming from the woofer movement going through the bass port?
    Actually I did “feel” that something is coming from the bass port by getting closer to the sounding speaker, but I’d like to understand the rough theory behind this since the original foams and the replacement are not alike at all.
    Below, the foam kit guide…
    Thank you Geoff.
    20210718_145755
    in reply to: Back to old things: Beovox P50… #34674
    matador
    Excuse me but after thinking it twice, I’d like to be sure I’ve understood well:
    Are you saying the rendering is more affected by the height of the driver than the wall making some kind of reflector or resonator that compensante the box thinness?
    Is that right ?
    in reply to: BeoLab 3500: how to fix ML input selection? #34432
    matador
    A very interesting thread on the new old forum , unfortunately not giving the actual solution but that still gives hope…
    https://archivedforum2.beoworld.org/forums/p/6704/60185.aspx#60185
    in reply to: Back to old things: Beovox P50… #34673
    matador
    Thank you Pepps.
    matador
    Hi alls,
    Got the same problem here. The Century is a wreck beyond repair (CD, tape, door, one channel dead… And no IR) For the love of the game I’d like to play with this IR problem!
    Its a mixed MK: silver clamper but no headphone socket, Type 2656.
    Have tried the activation sequence with no result, I would have said “broken IR board”.
    Checked the only big capacitor (purple, in the picture), it’s OK. The other two little are like SMD, with no pins, so I won’t mess with them.
    A guy is selling (way too expensive) an ir board but the thing is it’s not the same than mine.
    Mine:
    IMG_9322
    His:
    e0c7abb7a117e52b06ca48d4b4fe6b2e36569c09
    Absolutely nothing in common. And that makes me wonder if the fix that consist in replacing caps does apply to my board and people really replace those two tiny little capacitors.
    Thanks.
    in reply to: Beo products for hotels #34739
    matador
    To me, it looks like a specific system based on modified B&O hardware.
    Usual sockets are DIN for Powerlink and a large connector that looks like a wide Ethernet plug for Masterlink. The IR eye plug is the original.
    Googling a little bit shows that Otrun is a brand that makes TV system for hotels. To what extend they can be integrated in a classic B&O network and for what, I don’t know.
    Members who have the original boxes may help you to compare them with your hardware and maybe, luckily, it would just be a matter of plugs.
    In all cases you have a handfull of IR eyes which is very valuable: the boxes, even original B&O are cheap, but the IR eyes are quite rare and often more expensive.
    Good luck with all this and you nice project!
