matador
Forum Replies Created
Viewing 20 posts - 281 through 300 (of 845 total)
  • in reply to: Limited edition flagship B&O product #47480
    matador
    Honestly, how many of us, of you, would buy a brand new Beogram inbox, with full warranty ans panels stickers?
    I mean aren’t we praising those beogram, appart that they’re beautiful, because we save them from a certain death, because we like to repair them, adjust them, fight with them to bring them to work?
    If you, like me think the same, who cares they sell very expensive ones to whealthy people?
    If in the end a refurbished, painted like a stolen car 2020 beogram 4002 value increases, where will be the value of my trully original 1972 BG? A fraction of it maybe but still something. And even then, would I depart from it?
    Anyway, two things, two audiences.
    in reply to: Limited edition flagship B&O product #47472
    matador
    The anodising of the alu-parts is in this colour-combo is bordering on vulgar.
    I Agree…
    Mr10Percent wrote:
    I think there is something very wrong with a brand – particularly luxury brands when they keep re-hashing merchandise…
    Again, I agree…
    Omega Speedmasters etc…
    I can’t agree more (only smart move was the MoonSwatch)…
    Appart from this, I must say I don’t really care. That kind of things, relayed by fancy magazines and instagram post make just raise our Beogram 4002 value (happy when you own it, less when your look for one, but, hey…).
    Now, whoever want a beosystem like that one but with more peaceful or classic color palette can make it’s own, to his tastes, with the money he has : from my poor Beocenter 72-97, to an old but B&O refurbished BG4002 paired with any Beolab speaker and any high-end RIAA pre-amp. Thank you B&O for giving us the idea of that setup.
    That said, the real shame of it is the color… Awfull.
    in reply to: CDM12.4 for a VAU1255 #47402
    matador
    Zut, not a good news, I used to believe the deep cleaning was a forever cure.
    I remember it was a thread on the old forum about, I don’t know, reflowing some connections or maybe replacing one or to capacitors, in a nutshell another path out from the usual “just replace the lens”.
    I WANT to believe that lasers last forever and ore not just 5 years life long components.
    in reply to: CDM12.4 for a VAU1255 #47400
    matador
    The mirror too ?
    matador
    So it’s basically an 130€ Ikea Symphonisk shelf speaker guts connected to the Beolab 4000 drivers?
    I think I’ve seen the same mod with a Beovox C100 somewhere.
    in reply to: Buy and Sell pertmission #47169
    matador
    Hi, welcome to Beoworld and thank you for taking care of asking.
    Actually the rule is “paying members – Silver and Gold – are allowed to post in private ads.”
    The recent makeover of the forum, due to numerous reasons, leading to a lot of work of good-willing people as made the “lock” to this rule not working.
    So if you post, it will work and people will see your ad. and no (trustfull) buyer here will refuse to save a good piece from the trash or get a very desired item from a (supposed) trustfull seller and your deal will happen.
    But if you sell your things through Beoworld, please just consider making a donation or enrolling for a membership, just as a “thank you”.
    Of course, if the items you want to sell have nothing to do with the BOU (Bang & Olufsen Universe), moderators will remove your add.
    Truth to be told.
    in reply to: BeoLit 12 Replacement Battery #47067
    matador
    I vaguely remember you can buy spares cells and rebuilt the battery by yourself.
    Of course it implies still having the original battery.
    Also, I don’t know if there is any electronics inside the battery. If not, maybe just adding cells and make them fit inside the battery space would be enough.
    But I’ve been through a lot of trouble replacing battery cells in B&O equipment, namely Beo6, so I wouldn’t be surprised if doing all by the book would still not work.
    matador
    The SM I have has the same component layout as yours.
    in reply to: Beo6 battery management… #46399
    matador
    Hi Alls,
    Two day to cool down and I’m back. To make things easy allow me a little background:
    Three remotes, one gold and two silver.
    The gold one is (was) the main and central command of the living space. Use to work normally since many years now after a change of cells in the original battery pack. It had a problem last week and after opening it, it won’t hold the charge at all when before it did many hours. After a little bit of filling the remote won’t power at all.
    One silver, seems to work normally but won’t and never had hold the charge, Battery pack is the original. Problem is it don’t hold the charge with any BP.
    Second silver has never hold the charge including with a fresh BP made of the same cells that Gold one. That one I won’t mention it anymore. Just to say that even with fresh BP it dont last more than few seconds when not docked.
    Losing the Gold one really did p*** me a lot. To day I went back and discovered the the BP I was using was wrongly wired after wiring it correctly I was able to update it with CT and its back to life.
    The wiring should be as follow:
    Red wire = positive from the battery -> goes straight to the connector.
    Black wire = negative from the battery -> goes straight to the connector.
    Thermal protection = one leg to the negative of the battery and the other straight to the connector through the white wire.
    Thermal protection is a temperature sensitive resistor. Value seems to be around 40kOhms (one measured @ 39K, the other @ 43K) at ambient temperature. When temperature increases, resistance decreases (with the simple pinch of the fingers.
    Now I need to find a procedure to check carefully what cells are good and which one looks good but are not.
    After that I should be able to resume my experiment with AAA batteries.
    (People have helped me in the background, I thank them. A lot!)
    in reply to: Beosound 3000 laser replacement #47007
    matador
    Hi, I’ve no part number to give you but I’ve sucesfully swapped a CD block from a BS3000 MK1 et BS9000 MK3. You may find the reference you’re looking for by searching for “Beosound 9000 laser” on BEoworld II (link in the menubar).
    It seems that laser is quit difficut to source but not impossible. B&O may also afew still few of them but at crazy prices.
    Nevertheless, unless you know something about the fail (like having drop a coffee on the head or something similar!) chances are you just need a deep clean of the lens. It involves dimantling the laser lens and cleaning it inside-out. There again you should find a link to the youtube video on this forum.
    Good luck.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42586
    matador
    I think 2 and 3 requires even more black boxes
    It’s the Danish Mafia dealers: put a finger and soon you’ll loose your arm!
    in reply to: BEOLINK PASSIVE Entrée Powerlink #46929
    matador
    Oui, bon ben moi je suis pas français et je me relis quand même. Et puis je sais aussi que la dyslexie et les fautes d’orthographe ou l’absence chronique de ponctuation n’ont absolument rien à voir.
    Pas de panique ! j’en fais aussi des fautes et mon anglais (qu’on le veuille ou non, langue majoritaire sur ce forum, quelles qu’en soient les catégories) est certainement très proche de votre français.
    Bref…
    in reply to: BeoLink Converter 1611 Innovative Configurations #42584
    matador
    could be so useful for something …
    I once heard that 1, is Masterlink mode, 2 is Nespresso mode and 3 is Dyson mode, but I’m not really sure, the guy and me were really drunk at the time.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42581
    matador
    I don’t think I need one …
    Really? I believe that this “1-2-3” switch is already hitching you, right?
    in reply to: BEOLINK PASSIVE Entrée Powerlink #46927
    matador
    Maybe your cable was not correctly wired, it happens sometime, even to the best of us.
    Beo4 has nothing to do in that case, it is not “configurable” appart from link/regular.
    Please, also watch your French spelling, it really hurts.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42575
    matador
    What is… This?
    Capture d’écran 2023-06-01 à 20.02.08
    in reply to: BeoLink Converter 1611 Innovative Configurations #42573
    matador
    Oh goddamnit, you caught the Warwickshire flu!      ;-D
    in reply to: BeoLab 8000 MK1 Problem #46939
    matador
    If you read the whole thread you will not need the video.
    Also, search “Beolab 8000” in this forum and the previous and you’ll find plenty of useful information about dismantling, cleaning, servicing Beolabs 8000.
    Then, if you still have any question, please feel free to ask.
    in reply to: Beo6 battery management… #46398
    matador
    Actually the original goal was to replace the original 4/5AA with AAA rechargeable batteries now they can be rated up to 1100mA.
    But the problem is somewhere else: The remotes behave randomly as soon as they’re not powered with the original battery pack. Conclusion, the thermal resistor may be the culprit because volts are volts and Amperes are Amperes, right.
    But it’s always the same story: when it do not work you start to think you “may” ave touched something that creates at failure and the battery problem may have turned into a remote problem.
    Thank you for chiming in…
    in reply to: Beo6 battery management… #46396
    matador
    I Gave up. In the last attempt the Golden Beo6, command center of everything in the living room, was not even turning on.
    Moral of the story: they are Wonderfull remotes, but relying on it nowadays is a gamble you’ll never win.
    Sad.
