Forum Replies Created
matadorModeratorUnfortunately it does not react on any buttons.
It seems to be a common IR board issue. The Beolab do not “see” the IR beam.
I think I’ve read somewhere that the solution it’s the usual two caps replacement, easy, but the problem is accessing the board that implies a deep dismantling IIRC.I seen somewhere on the forum that beolink converter 1611 might be a solution?
It will not be a solution to your IR problem but it will make the use of your BL3500 more convenient (once you solved the IR problem). The topic is well documented somewhere in the forum. Do a search with 1611.
matadorModeratorHi Steve,
Congratulations on your choice to go after a Shape. To me it’s one of the good old fashioned B&O magic things like ib the past even thought it has no glass moving parts.
I do not own one but have thought about it many times and to be honest in many ways (mystery…). Anyway, while waiting for a more educated answer here is some of my thought:
One thing that struck me is that the Shape is bigger than expected in real life. The individual tiles are massive and bigger than I thought. If your thinking rubout it for a long time you should be ware of this but still, don’t let yourself be surprised: going 8 tiles over 6 may really be 2 tiles too much.
Colors is a matter of taste. I do think that part of beauty lies in contrast but all the Shapes installations I’ve seen I’ve liked were mostly shade on shade. You said the wall is white, but for a clean installation you will need to make a groove to pass wires, meaning you’ll certainly need to paint after. Even if not, painting a wall is quite cheap. I would consider installing a Beosound Shape as it should be: like a piece of art, that is considering the tiles AND the wall and the surrounding environnement.
I’ll stay away from mixing fabrics, they away different grain and that would immediately make it look like a mix and match, second hand, not coordinated thing.
I would also think it twice on the dark oak tile: even if I like it too, I think it ruins the “Shape effect” by saying “under this tile there is something different than under the fabric tiles so this is a sound installation”. And wood ,appart on the floor, tends to be a very fashion turning material.Things I would you depending on what you have at hand:
• Use extensively the Shape simulator on the B&O website (Sure you have!).
• Use a projector if you have one, to display the configuration, including colored wall on your actual wall.
• Print fake tiles on A3 paper, stick them on the wall, let them for a couple of days and see.
• If you’re handy at Photoshop, make simulations.Hope this helps, lucky guy you are!
matadorModeratorHi,
Plug them, enjoy them…
Unless you home has a very specific wiring, meaning the opposite of a carefully and perfectly crafted network, and different from our common home where live and neutral colors are mixed somewhere in a wall, I doubt you’ll risk anything.
matadorModeratorYes I had a broken coil and managed to repair it.
To be honest the break was quite obvious but there is a chance that yours will be too.And for every weak sight there is a loupe somewhere, just find yours!
(Actually very cheap Chinese led light loupe googles, they help a lot!)Location: Paris France
matadorModeratorHello and thank you would have been welcome when you ask for help.
That being said, there is no way to retrieve a missing pincode as far as I know.Things you can try:
– if your device came with papers, look for a 4 figure number handwritten somewhere.
– If your friendly with a B&O dealer, talk with him to see if he agrees to help you.
– Talk with seller. It may be impossible but it should be more possible than guessing the right pincode out of the blue.Location: Paris France
matadorModeratorHi Pommeyard and welcome to Beoworld.
You are righ, seized woofer is a quite common issue wit some Beovox speakers.
The good news is that this is reparable: not easy but not that hard too.Seized woofer doesn’t means the coils are broken for sure.
Lost for lost I would take out the woofers, check for continuity and do a search on this forum with something like “P50”. You should find a step by step repair guide with some quite very good pictures and perfectly phrased frenglish explanations.Beside the fact that finding similar woofers could be difficult or need another pair of S45 that would then end in trash too (the donor problem…), reparing woofers is a very rewarding task, really.
Let us know…
matadorModeratorIt is now done.
I’ve Ravsted, great work.
What happen when you put on a standard TV the contrast glass from the BV.
Does it change something? In good or comes with some trade-off?Thanks.
matadorModeratorYou need to zip the files before attaching them.
matadorModeratorThank you to the people offering ideas in a pleasant way and no thank you to the people who are going out of their way to attack me.
Thomash,
I’ve been there too. Beoworld people can sometimes look or sound harsh. I’ve felt myself excluded from a closed circle of “knowing people”. But what I learned is that sometimes when, as you did through your experiments, look able to sort it out by yourself, members won’t interfere. They let you dig and dig and dig again and find out until you’re really stuck and then they show up with respect and good willing.
Long time since I’ve seen a post from Dillen more than one line. He told you “You have already achieved more than most owners could/would.”. Trust me, its a golden badge.
Purpose of Beoworld (as I see it) is not to repair your stuff for you. It is to teach you how to repair any stuff. Sometimes it hurts, yes. But in the end its really rewarding.
Your Deck is a gem, everybody told you that. Get it up and working!
See this as an “bizutage” in French.
Welcome to Beoworld.
matadorModeratorIt would be interesting to investigate that RJ45 socket inside the A3 and see how/what for it could be hijacked.
matadorModeratorPowerful to me meant that…
Thank you Tim. All this make sense now.
matadorModeratorYes pictures are available luckily.
The laser cleaning must be deep cleaning, meaning involving a full disassembly.
matadorModeratorCd clamper belt. Easy to diagnose, just remove the back.
Laser eye to be cleaned/replaced. Common fault.
Tape belt, common fault again. Full tutorial on the old forum, unfortunately with pictures missing. 2 hours work and quite an adventure but pretty sure that’s the fault (three Ouvertures, three time the problem).
matadorModeratorWhen the Tim question will be completely answered could someone elaborate on this:
The BeoSound Stage is not powerful enough for music.
I mean at what level has someone to listen music for the stage not to be powerful enough?
And is/are Beosound Balance that much more powerful than a Stage?Thanks.
matadorModeratorÓlafur Arnalds – Live from Hafursey, in Iceland for Cercle…
matadorModeratorThank you both. I will have a go at opening it next weekend. Do you know a good source for replacement foam? The ones I have found so far are pretty pricey. I am UK based.
For once, the best source is B&O. The original Foam replacement are like 10€ the set per speaker. I believe UK dealers are more flexible but if I’m wrong and they are like ours here in France, you may have to fight a little to have them order the parts. But parts are available and it don’t worth the hassle to try DIY or anything alike.
https://forum.beoworld.org/forums/topic/beolab-8000-preventive-care/
matadorModeratorPaypal… Pros and Cons…
Sometimes it works at it should: safe payment, peace of mind, safety.
Sometimes it don’t. With times, people who want to fraud, fraud! They have understood that all you need to win the case is a return tracking number even if they actually returned whatever crap in the box.I dot wanna even elaborate on what I don’t know but, would it be possible that the algorithms were something like “refund little money to keep the safety feeling, don’t refund big money because it’s not interesting financially speaking”? I don’t know.
There is countless stories o PayPal here on BW. I remember our valuable member Dillen having a lot of troubles with PayPal because of bad buyers that caused him to not use PayPal anymore. In the other hand, as a buyer, I feel safe to use PayPal because the possibility of a case just exists and it doesn’t with any other paying method. And this, even if the confusion may not be in my favor.
I “subscribe” to paypal, long ago, just because I did not want to give my credit card number to eBay. Since then, PayPal has refund me a lot of non delivered items. and even if today, undelivered eBay items find arrangement with the seller directly (because they don’t want a bad review) the original reason is still there.
So in a nutshell: When you’re a seller you may don’t like PayPal because if the buyer is a gangster you know he has ways of legally hustling you.
When you’re a buyer you may don’t like PayPal because you know sellers have ways to dismiss PayPal cases even if they are gansters.
But all in all, PayPal is what it is and, to me, still better than direct CC number.
matadorModeratorThank you Xavier, that’s perfect and surely will help a lot in the future.
matadorModeratorHi Xavier,
Very nice work, the kind I like! Thank you for sharing the detailed process.
because you seems to know a lot about, would it be possible you make for us a little pensum explaining what iPad wit what OS would work with pros and cons ( even theoretically). I know it could be a lot of work but I’m sure it could help people make the right decision when buying second hand iPads.
thank you.Location: Paris France
