Forum Replies Created
Mark-sfBRONZE MemberI would not suspect the motor in this case based on your symptoms and what you have done to date. You can confirm if you have a 45rpm LP which should make the wow significantly worse if it’s a motor issue. I instead would check the adjustment of the tonearm optical shutter and ensure it is within the i.5 to 2.5 initial rotations and how it behaves toward the end of the record. Since the curve is tighter, if it is not correcting fast enough it can sound like a speed variation.
Mark-sfBRONZE Member“Fast” backwards,>>, is the same as Stop so I am still not sure what you are describing. How is the speed compared to moving forward between Play and Stop as well as < and >?
Mark-sfBRONZE MemberI’m not sure I understand your symptoms. You say going to stop works fine but fast backwards doesn’t. Those functions use the same circuit except for how they are activated. Are you saying that the arm returns fine at the end of record but simply raises and doesn’t when you press Stop?
Mark-sfBRONZE MemberGreat to hear! Keep ’em spinning.
Mark-sfBRONZE MemberHave you checked/cleaned R160/260 as they control playback output before the meters which I did not realize or had forgotten?
Mark-sfBRONZE MemberThe symptom that’s troubling is that you are observing the problem in both channels but still getting a signal. I would next try Martin‘a suggestion of recording on the 9000 and playing back on another machine. This would help identifying the defective section.
Mark-sfBRONZE MemberIn your description of work performed you said nothing about the tape heads. Have you cleaned them, checked for wear, and adjusted them?
23 August 2022 at 06:55 in reply to: Beovox S45-2 blown tweeter successful repair. What caused it? #37131 Mark-sfBRONZE MemberThat type of damage is typically caused by overheating which can be the result of any of the following or in combination:
- clipping an amp into the speaker
- if the series capacitor, C2 was too large or shorted
- if the parallel resistor, R6 is open.
Mark-sfBRONZE MemberAre B&O and Sound-Smith the only sources of compatible cartridges? I suspect that other sources are unlikely, but wanted to ask to be sure. Thanks, Glitch
Actually, B&O has not been a source for years and are even using a Sound-Smith in the 95th Anniversary Limited Edition 4000c.
On the used market your best bet would be for a non-working table with the cartridge intack as that will likely be cheaper and you can even part out the table to pay for it.
Mark-sfBRONZE MemberUnless you can find an MMC4 used your best bet is Sound-Smith SMMC4: https://sound-smith.com/cartridges/bo/smmc4 at $200.
Mark-sfBRONZE MemberI would agree with Martin but initially focus on tracking force if the diamond is still intact based upon your transporting without locking the screws.
Mark-sfBRONZE MemberAssuming you have tried it with multiple tapes, I would contact the seller as its obviously not in “superb condition”.
Mark-sfBRONZE MemberSince you are able to play using the < key, the issue is in the << electronic switch. I have found TR12 to be bad though rarely its been TR11. Also I have found TR8 to be bad on the muting board; however, in that case it tries to start and shuts off immediately.
Mark-sfBRONZE MemberUnfortunately, there is no industry standard for 12” record weight. They can range from 80-200g. I have never had a problem finding a suspension height that will work with all without bottoming or scrapping. In the end it’s critical that the platter also remain level.
Mark-sfBRONZE MemberThe service manual provides clearance specifics so I would adjust to that with your 180g records.
Mark-sfBRONZE MemberCheck the rear of the tonearm’s clearance with the record edge.
Mark-sfBRONZE MemberI would still suspect the muting contacts. They should be cleaned and adjusted as per the service manual available at https://beomanuals.com/manuals/Beogram/Beogram%204000/Beogram_4000-Service_Manual.pdf.
Mark-sfBRONZE MemberCheck out the service manual available at beomanuals.com.
Mark-sfBRONZE MemberGlad to see you are making progress. Are you able to start the turntable using the < key to move the arm inward? Does it stay or want to go back and shut off?
Mark-sfBRONZE MemberThere are some major issues there that can only be explained by one or more errors in your parts replacement. Pressing 33 should ONLY cause the platter to rotate and not move the arm. It is a “clean record” function. ON should cause the collector of TR12 to latch high (17v). If pressing 33 is causing that then I would carefully check your diode orientations as you may have one in backwards or a shorted one. The slow return could also be your pulley alignment, lubrication or servo belt. If it is running at the same speed as “>” then once again there may be a diode/trans issue. This is when TR13 should latch high. Finally, don’t forget to check D9/10 and TR8 on the muting board as they perform the same functions.
