Forum Replies Created
Mark-sfBRONZE MemberGlad it worked out. I don’t know about a new string but belts and other spare parts are reliably available from https://www.beoparts-shop.com/. If you can’t find the “string” you can make a new one using tuning dial cord.
Mark-sfBRONZE MemberIt’s likely that the tensioned string that moves the arm has broken or come untracked. There are instructions at the end of the service manual at https://beomanuals.com/manuals/Beogram/Beogram%209500/Beogram_9500-Service_Manual-version2.pdf
on replacing and adjusting.
Mark-sfBRONZE MemberI am having trouble parsing the symptoms you are reporting. In normal operation, simply pressing start momentarily will cause the tonearm to move to the edge of the record and lower. If you press and hold then it will continue past that point until you release. Pressing 33 should just cause the turntable to spin for cleaning without the arm moving. If it is then you may have a shorted transistor in the servo motor control section. You can see a table of voltages on the schematic available at (removed reference to external manual)
Mark-sfBRONZE MemberIf you are referring to the resisters in the lower right where the board is darkened, those are 1/4w resistors which are typically 6.5mm in length. You will not find a replacement parts kit that includes standard resistors. I would check their values with a meter as even though the board is discolored most are probably fine when the resistor itself is not blackened in the middle.
Mark-sfBRONZE MemberThere are small knurled knobs under the black trim aligned with the speed indicators.
Mark-sfBRONZE MemberFrom your picture it is missing the veneer. Quite frankly I was never a fan of that motor but you have nothing to loose in trying to relubricate it. Cannot comment on how long it will last. I would also have the stylus checked for wear as you don’t want to be damaging your records.
Mark-sfBRONZE MemberTo answer that we are going to need a bit more information.
- Does the noise vary with volume and turn off when muted?
- Putting your ear to each driver (tweeter and woofer), do you hear the noise only from one or both? Note that the tone will be different.
Mark-sfBRONZE MemberIC1 is a voltage regulator and the operation is the same in that it is being turned off by the SO switch grounding the anode of D5. I would confirm that is occurring.
Mark-sfBRONZE MemberIf the 1200 has the phono preamp then you would connect to an AUX/CD/Tape input on your Marantz. If not you go into Phono making sure MM is selected versus MC if your Marantz has this. Either the stylus or its suspension may have worn out which is not surprising after 40+ years. Finding a replacement will be costly or lucky.
Mark-sfBRONZE MemberWelcome to the forum. First, I would check that your cartridge stylus force is adjusted properly. It should be 2 grams. You will need a stylus force gauge as I don’t believe there were calibrated markings. If this does not solve your problem, I would check whether yours as the phono card plugged into the bottom. If it does then this could be at fault. Which inputs are you using on your Marantz?
Mark-sfBRONZE MemberNo, a TR is not an IC. You will need to trace the circuit but you have the SO switch as a reference. Just follow its high side.
Mark-sfBRONZE MemberDoes the turntable motor keep spinning as well as the lamps stay lit? If so, you still have an active 22.8v rail and OTR1 is not turning off. Is the anode of 1D1 grounded when this occurs?
Mark-sfBRONZE MemberI was referring to the switch marked “SO” that is on the Arm Transport PC board. This keeps the TT off when the arm has returned to rest. Sometimes the optical bar can be misadjusted in its engagement of the switch or it can be dirty as its contacts are exposed. As to D1, I am referring to the diode that is between a 2.2K resistor and the base of TR1. I highly doubt it changed for your type.
Mark-sfBRONZE MemberI’m afraid you are not going to find a new one. Your best bet would be to find a used non-working 3404 with a reasonably clean cover, that you could then part out to recover some or all of your cost.
25 September 2022 at 18:31 in reply to: How can I operate a Beogram 8002 with a Beoremote One #34980 Mark-sfBRONZE MemberSorry, I don’t have experience with the Beolink products that came later to answer.
Mark-sfBRONZE MemberFor a start all of the electrolytics should be replaced, Thes are the cylindrical (horizontal or vertical ones) paying attention to their polarity. I would also clean and check the alignment of the switch that is activated by the optical rail when it returns to rest. This should be grounding the base of TR1 via diode D1.
22 September 2022 at 21:32 in reply to: Beogram 4002 (5501) – Strange command behavior when press “Start” #39146 Mark-sfBRONZE MemberIf it has never been repaired it is overdue to have its electrolytic capacitors replaced. Once this is done and the voltages confirmed your problems would likely be solved. This can be done by a competent technician even without B&O experience.
Mark-sfBRONZE MemberThis could be multiple issues including the servo belt, threaded rod alignment and cleaning/lubrication, loose or cracked pulley, etc. I would attack the mechanicals first before the electronics based upon an issue in only one direction.
Mark-sfBRONZE MemberHave you performed a re-cap of the electrolytics on the board? The symptom points to it needing that.
Mark-sfBRONZE MemberYou can find the service manual based upon your 5500 Type at beomanuals.com or if you become a Silver member of this site. The procedure is documented there.
