Madskp
Forum Replies Created
Viewing 20 posts - 1,601 through 1,620 (of 1,647 total)
  • in reply to: BeoLink Converter 1611 Innovative Configurations #42404
    Madskp
    GOLD Member
    sounds more or less as the experience I had with the BV6, 1611 and Beocord 3500. Didnt try the long press off though. Will test that for my next testing session
    I came around to try this test, but the Beocord keept playing even though i tried various lengths of long presses.
    Might be the difference between AAL an AL.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42403
    Madskp
    GOLD Member
    Perhaps the shorting (or otherwise) of ML pins 4 and 12 in early model BL3500s is relevant to our investigations?
    It doesn’t say why they have to be shorted, and weird since pin 4 is normally not connected in masterlink.
    What I can’t make of it is in most normal B&O link use cases the activation of the speaker will be from the speaker it self (or via IR). So the turn on feature might be a non standard thing
    in reply to: BeoLink Converter 1611 Innovative Configurations #42400
    Madskp
    GOLD Member
    Or maybe the BL3500 manual is not showing all the connectors on the W1
    Ok, so I confused my self, and probably also you. I misunderstood the drawing in the Beolab 3500 manual thinking it was showing the connections on the Wireless 1, but it is of course the connections on the BL3500. Sorry for that.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42397
    Madskp
    GOLD Member
    It is mentioned i the specification list in the servicemanual for The BL3500 MK2, and I also have seen manuals for the wireless 1 with drawings where it has Two powerlinks sockets and one Ir socket, and in a user manual for Beolab 3500  it only has one DIN socket and is connected via ML. So guess there must have been at least two versions of the W1
    in reply to: BeoLink Converter 1611 Innovative Configurations #42395
    Madskp
    GOLD Member
    But I’ve also read many times on the forum that the Powerlink socket on the 3500 is there for use with W1. I suppose they were different version of W1 over time, one of which uses Powerlink and the other Masterlink, right? But even then, Why would the Beolab react to a Powerlink connection from W1 only and not any other device?
    in reply to: BeoLink Converter 1611 Innovative Configurations #42394
    Madskp
    GOLD Member
    Just a quick note about triggering the BL3500 with 5V. I did tentatively try 5V to various pins whilst I had a 7-pin cable attached to the MCL socket (ML was disconnected). I tried all voltage injections variations that have been mentioned with ML turned both on and off. BL3500 did not turn on. Given that we now have BL1611 working well, I give up!
    Out of curiosity: Did you try the combination +5V on pin 6 (datalink) and -5V on pin 7 (datalink shield)? I have had some thought about this and cam to the conclusion that the rest of the pins are either not conencted or used for the sound part. Furthermore one of the olde manuals regarding datalink signals mentions high signals in the voltage range 2.1 to 5.5V. But again it is just a thought.
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42958
    Madskp
    GOLD Member
     Of course the downside is that for some reason my Mac forgot it had a paid license to LinkPlayer (the battery died during the 8 long years of storage, so on restart it thought we were in 2000, and then jumped to 2023)… and now the required esellerate.net servers don’t work, so I can’t activate my LinkPlayer copy even though I have the original receipt with a code —this limits functionality to one hour.
    I read some of the threads about Linkplayer back then, but didnt realize (or remember) that it was a paid software with activation. That makes it a little more difficalt to rely on if it is not possible to activate anymoreå
    in reply to: Connecting Beogram 2403 to BeoVision 11 #43022
    Madskp
    GOLD Member
    Connector wise you almost cannot do it wrong on the TV side. The worst that can happen there would be switching left and right channel. But what about the orher end of this cable? Do you have phono connectors or DIN connctor?
    in the TV setup under advanced settings there is a possibility to choos S/P DIF on/off. If it is set to on you might not get analog sound through
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42953
    Madskp
    GOLD Member
    I see your frustration when things are not working as you think it should, and then even on an old and slow computer.
    my earlier experience with the Beoport was with the Windows software from B&O which I found frustrating to use. At the time I didnt have any other Masterlink products, and was used to Winamp for listening to music on the PC, so I might not have seen the benefits.
    My first impression with this BM link is much better, and from your pictures Linkplayer seems to have much more functionality (not that more is always better).  So im optimistic.
    One advantage in my system might be that I re installed the Imac a couple of years ago for some other experiment, so its almost a new installation
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42951
    Madskp
    GOLD Member
    I now have the BM link software (v1.5) up and running with the Beoport connected and a pair of headphones in the Beoport.
    I can control Itunes music play/pause/skip/next album and volume with a BEO4, so guess my hardware part of the setup is working.
    I just realized that the Built in speakers in the Imac is redundant in this setup when the sound output is connected to the Beoport, but then again a pair of Beolabs can do better than the built ins anyday
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42950
    Madskp
    GOLD Member
    I’ve now BM-link and Linkplayer (Thank you E).
    I now have my old iMac 2006 with Snow Leopard 10.6.8 up and running and have found that I have the BM link Installation files. However a little search for Linkplayer Doesn’t help me, so Maybe you could Hint where you found it?
    Thanks in advance
    in reply to: BeoLink Converter 1611 Innovative Configurations #42389
    Madskp
    GOLD Member
    The BeoLab 3500 Mark 2 was introduced in 2006 from serial number 19343452 Item number 1160X11 is BeoLab 3500 with Master Control Link Item number 1160112 to 1160138 is BeoLab 3500 Mark 2
    then I guess both of Matador’s are MK2.
    On the picture of the BL3500 from the guy with the 5V trigger it seems to me that I can  the Item number to be 1160X11 and therefor and MK1 Version. I guess the SW 1.1 also indicates that it is an early version.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42383
    Madskp
    GOLD Member
    OK now looking in the back of the BL3500 – photos first to give you serial number: IMG_6507 And this one partially shows a useful sticker (on the left) that allows you to check the speaker setup in the service menu – will do that later! IMG_6508
    one thing to look for without opening it could be to measure if pin 2 in the MCL/PL connector is connected to other ground pins or not
    OK so no continuity between 2 and 7, or 2 and anything else! Measuring approx 400 kOhms between 5 and 7, and 3 and 7 so let’s assume 7 is ground , and pin 2 is not connected.
    ok these 2 informations combined indicate that you have a MK1 with the MCL connector. Good to know
    in reply to: BeoLink Converter 1611 Innovative Configurations #42380
    Madskp
    GOLD Member
    That’s what I thought! However, perhaps the BL1611 needs to ‘recognise’ a connected product (older TV or BeoCenter) via the AAL socket (pin 6) so that it knows what sources are available. I ran the setup through the PCG as if connected to a BL1611 and BC2300 in the main room, Beoport and BL3500 in two link rooms: This told me to put BL3500 and Beoport in Opt 6. The was no conflict or lockup with this, but I just couldn’t select (eg) TV or RADIO like I could when Beoport isn’t present. When I tried, the BL3500 just turned quickly on and off (as if looking for a source and not finding it).
    Maybe your software version on the Beolab 3500 is making the trouble here?
    in reply to: BeoLink Converter 1611 Innovative Configurations #42378
    Madskp
    GOLD Member
    @Madskp Yes those solution are the ones we try to avoid. They use the PL mode from service “Menu 0 4 GO” and the speaker is turned off as soon as you touch any key on the remote. Volume is set from the source and to me the more important: you lose the sound adjustments from the BL3500. It is clearly much better to have the 1611 solution. But when you have it, adding an extra source for casual needs with the PL path is something that comes free and can be useful.
    What I take from thoose solutions is the pins used in the DIN connecter for respectivly MCL and PL , not the use case.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42377
    Madskp
    GOLD Member
    I tried this and couldn’t find any way of selecting either of the BL1611’s dual-inputs when the Beoport is also connected to ML.  I tried various combinations of Beoport Option (0, 2, 4, 6) and BL3500 L.Option (0, 1, 2, 4, 5, 6) but had several conflicts as far as I am aware. At one point Beoport even locked up (the PC screen controls disappeared) and I had to do a complete re-install of the SW!
    One should think this was supported as the official drawing from B&O shows the dual input, and a Beoport should be able to coexist with another audio master in the same installation. But of course if that drawing is before the Beoport was made things could have changed.
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42947
    Madskp
    GOLD Member
    I also have A Beoport and an old Mac, so I might have to dust these of to join this thread too
    in reply to: BeoLink Converter 1611 Innovative Configurations #42373
    Madskp
    GOLD Member
    I am now trying a few other things on the Beoport and will then do those BL3500 MCL socket pin measurements.
    Another research regarding this from on of Peter Pans drawings on Hifi4all, all in danish, Both examples is for connection of a 3.5 minijack to the DIN socket but without any power on functions.
    First example is the MCL socket in LCS9000/BL3500 MK1. Again pin 2 is unused, and ground are on other pins.
    The second example for the same connections to the powerlink socket of af BL3500 MK2. It looks very much like af normal powerlink connction with pin 2 in use,  He is writing that he has tried it on his own MK2 BL3500.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42368
    Madskp
    GOLD Member
    @ madskp. That all looks very promising. I may well have a look in the back of my ‘new’ BL3500 in the coming days and see what can be achieved, but I am worried about mucking it up! When I was playing around with injecting voltage into the BL1611 there were a couple of times that the ‘system’ seemed to lock up, and I had to unplug all the mains power for a few seconds to get it all to reset. Nevertheless now that I have seen how well BL3500 works, I am keen to find the parts to update its SW from 2.0 to 2.1. Basically I want the newer sources to be shown on the display, and it would be nice to have N.RADIO (rather than PHONO) showing when I connect my OneRemote. If I do find the SW upgrade Processor/PCB (as listed in the FAQ) I’ll be digging into the back of the BL3500 then, and will look at those old ‘MCL’ connections. We know Matador has looked for a BL3500 ‘on’ trigger in the past. One thing I would be keen to explore is whether turning ML off (using MENU MENU 0 9 GO, then up/down arrows) changes the behaviour when trying to trigger the BL3500 from the old MCL socket. Anyway all this is listed as ‘Test 10’ on my schedule, and I will report back here if I discover anything. The diagrams to which you have linked will be a good start!
    in reply to: BeoLink Converter 1611 Innovative Configurations #42364
    Madskp
    GOLD Member
    I did some more research about the Beolab 3500 MCL/Powerlink connector. Browsing through the service manuals for respectivly the service manuals for the LCS 9000 (with MCL connector) and the Beolab 3500 (with Powerlink connector) I noticed a few things.
    1) The servicemanual for the Beolab 3500 with powerlink connector is from serial number 19343452. Are your speakers above or belov this serial number?
    2) In the specifications sections in the beginning for the service manuals:
    – For the LCS9000 the MCL conenctor is shown and all pins assigned except pin 2 (pink) which is DC supply 7.5-8.5 Volts. This corresponds well with the fact that it has its own power supply. Also all pins are shown in the right places in this drawing.
    IMG_8285
    – For the Beolab 3500 there is just a text string stating Beolink Wireless 1 (W1) 8 pin DIN connector and no drawing showing the pinout. I guess it’s B&O’s way of saying this conenctor is only intended for this purpose.
    IMG_8288
    – What strikes me is that Keith wrote that the module with the MCL socket was not redesigned, but as noted before pin 2 was not connected in the MCL, and Pin 2 is ground on a powerlink connector. This could bed the reason for the statement about a fully wired Powerlink cable needed as this also has a ground on pin 7 whis is Data ground/shield on both MCL and Powerlink.
    3) Looking at the wirering diagrams in the servicemanuals the external conenctors are not shown, but the conenctors between the different print boards are. Especially the conenction between the Plug PCB (the one with the ML and MCL/PL connector) and what is called the Cross field board:
    – For the LCS 9000 the MCL and ML connections are shown, and on wire shown as not conencted (Pin 3 on the Plug PCB).IMG_8286
    -For the BL3500 PL signals are shown instead of MCL, but more interesting this PIN 3 on the Plug PCB is now called SP ON. Guess that means speaker on and that is should be possible to turn it on with an external signal.IMG_8289
    – Question is: Is it conencted in the Powerlink connector? I don’t know how easy it is to open a Bl3500, but it could be interesting to see if there is a direct connections to something in the Powerlink conenctor.
    4) in the Service manual for the LCS 9000 the same block diagram as Keith show with the weird looking DIN connector, but also a full diagram of that PCB showing it the same way. Again it might be a typo as it onlys seems like Pin 2 (which is not used) is placed in the opposite end of the conenctor
    IMG_8287
