Forum Replies Created
Madskp
GOLD MemberHello again. Very great findings, glad that it was actual more simple than it seamed. very nice to know how this can be used for other things than it was meant to be.
@Guy: Nice Beocom 6000 you have there ?
Madskp
GOLD MemberI think that is how it could be described. Mayby the sound is passing through some passive components instead through the supposed way through the circitry
Madskp
GOLD MemberI was using A.tape command, but can try with other commands later to see if its the same
i tried again, with the iphone connected to the AaL port and the BV6 via ML. Same result as 1) above whether choosing CD, A.tape and Radio (my BC6 is w/o built in radio).
also have a Beocord 3500 i tried connecting, same result. Discovered afterwards that it only has a 5 pin din plug, so will try to fit a 7pin and try again
Madskp
Madskp
GOLD MemberI am following this thread with interest,and also did some testing with the 1611.
1) connected with ML to my Beocenter 6, and an iphone connected to the AAL socket. My first impression was the same as Guy, but then I tried to crank the volume up to max on both the iphone and the TV. Then I would hear the sound, but very low like when trying to connect a record player to an input without a RIAA.
2) again connected to the Beocenter 6 with ML, and a Beomaster 5500 (Tape2/TV socket) to the AAL socket of the 1611. This way sound was comming loud and clear to the TV.
so my guess is there has to be something connected to the datalink pins on the 1611 to negotiate what to do with whatever master device is on the ML port.
the Oneremote cables might have a little chip insight on of the connectors that can do this negotiation.
Guy you mentioned that it worked connecting it to your BS1 which officialy doesnt have datalink abilities as far as I know. However looking at the diagrams in the service manual both pin 6 and 7 is connected (called data in and data out) to a control chip. Also left and right out is connected which I also didnt expect. So maybe this product is hardware wise datalink capable but might be software limited? Could be interesting to know more about as my parents have on with a Beogram connected. But that might be for another Thread.
Madskp
GOLD MemberFound this thread from the older forums regarding the power link socket on the 1611. Seems its an input, and might give some on off functionality maybe?
https://archivedforum.beoworld.org/forums/t/21371.aspx
what are your thoughts? The manual for the 1611 only mentions it briefly
Madskp
GOLD MemberAnother alternative could be this unit from Almando. https://almando.com/almando-category/almando-masterplay.html
I do not have any experience with this product, but use their powerlink switch without any issuesLocation: Denmark
