Madskp
Forum Replies Created
Viewing 20 posts - 841 through 860 (of 1,530 total)
  • in reply to: XTRA Speaker and MCL Issue #53867
    Madskp
    GOLD Member
    I noticed that Quality Dream Audio is out of stock on the one I have, but they have this one that I’ve attached. Would this work with my system? The only difference I see is the extra port for TV on it whereas the one I have only has the 3 ports, one being marked TV, which is the one that I use to relay from the bluetooth adapter to run my TV in the room above. Please let me know. I appreciate all your help with this, very frustrating.
    Yes this would work the same. The extra port for TV is just an antenna cable pass through that was left out in the later versions of the MCL2AV.
    in reply to: Beoplay V1 not turning on #53069
    Madskp
    GOLD Member
    I tried with the mains plugged in and when I touched the pin with the multimeter something on the awareness board blew up
    Sorry to hear that. Can you tell which component that blew up based on your pictures?
    at this point I dont even know if it’s worth fixing this tv. Was the problem something else on the video engine and now that I made that part blow up would it affect the video engine in case it was okay and the problem was really the awareness one?
    Hard to tell, but at least when you get the new PCB you will know if that was it or if it is the video engine part
    in reply to: Beosound Ouverture CD not working #50401
    Madskp
    GOLD Member
    All back together now … IMG_8350
    wauw. Great looking. Just need some speakers now
    in reply to: Beosound Ouverture CD not working #50399
    Madskp
    GOLD Member
    Quick photo of display with contrast too high (do I mean too low?) – only BBC R2, RADIO A and STEREO should be visible!  It is much better viewed direct on, rather than at an angle.
    Very good illustration of how it should not be 🙂
    in reply to: Beosound Ouverture CD not working #50398
    Madskp
    GOLD Member
    I am now able to check my display in the dark and it is far too bright! (the non-lit ‘pixels’ are glowing too much which reduces clarity).  I’ll re-adjust tomorrow, probably back to where I started.  It’s a bit of a faff to adjust so I actually wish I’d never attempted.  So if you can live with yours as it is then I recommend doing nothing!
    Good to know. I have not noticed any issuses with brighness on my Ouverture, but if I do at one point I might have to consider what I can live with.
    On a positive note, I replaced both belts today – first time I have tried that and it was a bit tricky but successful.
    Yes they are tricky. When I did it I ended up re wirering the doors as I probably had disassembled the mechanism to much. But with the extra lenght there was in the existing belts I have no doubt that belt change is mandatory.
    I also replaced the lithium battery – I (carefully) soldered a new battery directly rather than use a socket because the sockets I bought were a bit large and may have pushed against the upper shielding
    Also good to know in order to get the right battery from the start.
    Given that this is the first battery change in 20+ years I reckon that the replacement will probably outlive me.  (Old battery measured 2.86V no load, new one was 3.2V).
    And based on that, you are right, that next battery replacement is probably not worth thinking on.
    Apologies for hijacking madskp’s thread for the non-CD-related activities but I wish him all success in getting his Ouverture fully functional.
    No need to apologise. Allways great with extra inputs, especially since my Ouverture is still open. I would hate to find out that I should have done this little extra thing when I had just reassembled the whole thing 😉
    in reply to: Beoplay V1 not turning on #53067
    Madskp
    GOLD Member
    And BTW pin 5 is also ground so if you touch that while measuring you will probably also get 0V. Those small pins in these connectors are usually fididly to measure on
    in reply to: Beoplay V1 not turning on #53066
    Madskp
    GOLD Member
    Depending on how easy it is to see the pin numbers direction it could be that you are counting the pins from the wrong direction?
    Counting to pin 4 from the wrong direction seems to be a ground pin which will read 0V
    IMG_9808
    This test is only for checking if 5V drop to 3.8V, so I would expect a 5V reading.
    But the could be problems before in the chain. Try to look at page 3.4 in the servicemanual. There is a flowchart with things to test where this is only part of it.
    The TV has to be connected to mains for the test, and all internal  connections be intact, but as its part of a test for tv not turning on that should be it.
    in reply to: XTRA Speaker and MCL Issue #53864
    Madskp
    GOLD Member
    but the red lights are on the speakers as we speak, even though the MCL2AV box is not plugged in currently.
    The speakers are active speakers with built in power supplies, so they will always be in standby indicated by the red light if they are plugged into mains even though there is no source.
    Assuming they are wired to the main system in the living room and the MCL2AV box is just an addition to let you run them with the IR eye and remote for additional sound in another room.
    I would assume that yes. That is the way his system was intended to be used, as a link room to the main system.
    The IR eye, when the MCL2AV box is plugged in, does not come on, as the red light does not even light up.
    You could try to disconnect the IR eye from the screw terminal in the MCL2AV and try to measure the voltage at the screw terminal again. If it now shows 5V that would indicate that the problem is in the cable or the IR eye. If it is still 2V the fault is probably in the MCL2AV.
    Also as Guy suggested you could try to connect the old IR eye again to see if that works
    Maybe there’s something at the main system in the living room that I can reset or test to make sure there is accurate power going to the MCL2A box in the garage?
    I don’t think that is nessecary at this point. The MCL2AV should work independently even though the main systems is disconnected. The MCL2AV do not use the 8V power from the main sytem as it has it’s own power suply.
    in reply to: XTRA Speaker and MCL Issue #53862
    Madskp
    GOLD Member
    Hello again. I have now re read the whole thread and I might have misunderstood which components are in your system.
    If I understand it correctly you have the MCL2AV box in the garage, and the IR eye + speakers in the bed room?
    The measurement of the 2V where did you take that at the splice?
    If sio you could instead try to measure it at the screw terminals in the MCL2AV box to see if it has the correct voltage of 5V.
    I should be done between the terminals for the green and the brown wire
    Skærmbillede 2024-03-29 kl. 20.17.48
    Hope this helps
    in reply to: Beoplay V1 not turning on #53064
    Madskp
    GOLD Member
    1- By another board you mean within the video engine board or another one?
    It was the video engine board I meant, but the connection could pass to other boards. Best thing to do might be to make the measurement i refered to from the servicemanual in my earlier post.
    This is the back part I missed attaching it. Is that component  that has “H CM . &” a capacitor?
    Hmmm I can’t really tell what type of component that is, and wheether the black is burnt or just how it is supposed to look. It tried to do a Google picture search on it, but with no relevant result.
    in reply to: Beosound Ouverture CD not working #50392
    Madskp
    GOLD Member
    And I might have to revisit my Ouverture to see if I can get it fully working. Maybe one of the caps I put in it have slipped the board
    in reply to: Beosound Ouverture CD not working #50391
    Madskp
    GOLD Member
    And guess what?  I put it back together and it works, and for more than 20 minutes this time!!  It is a Good Friday!
    Nice to hear that it did the trick, and the soldering time was not wasted 🙂
    and potentially do the other jobs (belts, adjustment of display brightness and battery replacement).
    I can only recommend doing the belts while it’s open based on both my Ouverture and some other things I have worked on
    in reply to: Beoplay V1 not turning on #53062
    Madskp
    GOLD Member
    So I connected the ethernet cable to it and I was able to turn it on via the b&o app, but there is no picture, I managed to play the radio and it works fine but all I see is black screen. And it still doesn’t respond to the remote.
    Ok so the TV is not totally dead. Thats a positive.
    Would this issue be on the T-CON board or video engine board ?( even tho it is functioning without image) and the remote not working can be a related or a side effect from the video engine as the IR sensor is attached to it?
    Not really sure, but the fact that the IR board connects to the video engine makes it possible that it can be a fault on another board then the IR.
    I took some close ups of the boards. the back light one seems like there is some leaking around some parts (brown one and the big black piece) I noticed it today.
    I would not suspect these components to be leaking. To me it looks more like solder residue.
    I havent checked voltages yet, I need to learn how to do that.
    If you have a multimeter set it to measuring DC voltage and measure between the point mentioned in the service manual (provided you can locate it) and a ground point. Ask if you need more advice.
    Also on the room awareness module, there a dark spot on the side of a white thing, is that an indicator  that it was blown or something?
    It could be something. I can’t locate it on you pictures. Could you make a close up photo of that component?
    There are other B&O products where IR problems are related to failing capacitor.
    Other than that I don’t see any electrolytic caps on your picture of the IR board, so unless there are some on the other side of it this should not be the issue.
    in reply to: Beoplay V1 not turning on #53060
    Madskp
    GOLD Member
    You could also try this thing mentioned in the service manual to confirm whether it is PCB 58
    Skærmbillede 2024-03-28 kl. 20.01.10
    in reply to: Beoplay V1 not turning on #53059
    Madskp
    GOLD Member
    I had that component replaced and it still doesn’t turn on.
    Too bad that did not work, although it might have need to be replaced anyway based on the condition it was in.
    Ive been studying the service manual and it could be that the “IR Receiver & Room Awareness” ( 58Module 8007282 PCB58) need to be replaced
    Interesting. There are other B&O products where IR problems are related to failing capacitor. Maybe there are capacitors on PCB58 that need to be replaced. Could yo try to take this PCB out and take some photos of it?
    I wonder if the cable that connects to it might be damaged (photo) anyone know what kind/name this cable is?
    It is a Ribbon cable. It is probably custom made for this particular TV. If it indeed is damaged an alternative solution could be to desolder the connectors on the boards and solder another flat cable to the solder pads in both ends. This will of course make it harder to disconnect the separate boards, but should not be to often that is nessecary.
    in reply to: XTRA Speaker and MCL Issue #53860
    Madskp
    GOLD Member
    Just chiming in here with my 2 cents and a couple of questions
    1. You do mention a Beosstem 4500, but I can not tell from your description if you have been using that through any of the xtra speaker kits? The reason for asking this is that the MCL2AV shown in you picture can work independently of the MCL system when you are only using it’s local input connectors as it have it’s own powers supply. Therefor it can work without the MCL cabling and the Beosystem 4500 for the use case you have describe.
    2. You do mention that there is also xtra speaker kits in the garage and the bedroom. Are these the same type as the one in your picture? The reason for asking is that there is both an xtra speaker kit (where the grey box is an MCL2A) and en xtra active speaker (where the grey box is an MCL2AV as the one in your picture) and there are quite some differences in them.
    3. Where have you measure the 2V you are mentioning? The MCL cable do supply a voltage of arround 8V in the pink vire from the main system (in your case the Beosystem 4500). The voltage can be measure between the pink and the brown wire. Some voltage drop should be expected along the cable, but 2 V seems low.
    Here is the cable colors.
    Do note that it is also important the the two speaker connectors are connected correctly on the Beosystem 4500. Left and right must no be switched as one of them caries voltage and the other data signals.
    Also important that they are conencted to the speaker 2 terminal on the Beosystem 4500 as the speaker 1 connctors do not supply voltage for the MCL system.
    If you have MCL2A boxes (Those without local inpus) these can only work if they get power from the Beosystem 4500.
    Hope that these inputs can help you further. You are welcome to ask if any doubts
    in reply to: Your latest addi(c)tion? #34929
    Madskp
    GOLD Member
    Probably gonna be more of an addition than addiction
    I have never really been found of the look of it, but when BS4 was announced at a price I couldn’t say no to I picked it up anyway
    Of course it’s sticky all over since B&O at that point was going all in with these coatings on all surfaces.
    Furthermore when powered up the glass door is moving down, but when it reach the buttom gear noice starts and keeps going.
    Could be a sensor problem?
    IMG_9793
    I was very surprised by the low weight of it when I picked it up. B&O must really have saved on the material bill on these units.
    Anyway. First things first. I have allready started to remove the sticky coating as my fingers get all black when I touch it
    in reply to: Beo4 “special remote “ #53716
    Madskp
    GOLD Member
    I think it was this thread Stoobie was refering to
    https://forum.beoworld.org/forums/topic/beo4-special-remote/
    Madskp
    GOLD Member
    This thread may answer some of your questions
    https://forum.beoworld.org/forums/topic/beo-converter-controls-beocenter-9500/
    in reply to: Guidance on Masterlink system with 10 link rooms #43277
    Madskp
    GOLD Member
    Thanks for the information: by adjusting the timing between the two presses of “menu” I could indeed get into the test menu. 00 then showed “sw: 2.0”.
    Great to hear although it did not solve your problem.
    If you end up looking for another BL3500 with the correct software the best chance might be a MK2, although they came with software 3.0 or 3.1 initially so no garantee for the correct SW version
