Forum Replies Created
GuyModeratorIs this what you need? (from the ‘Fan Adjustments’ section on page 4.9 of the service manual):
In this menu, the following settings can be made:
Fan full speed temp 45-64
Fan stop speed temp 36-50
Fan PWM min. 16-39
Fan PWM max. 20-41The following can be read out:
Fan 1 speed 2057 RPM
Fan 2 speed 2002 RPM
Temperature 1: 42c
Temperature 2: 24cLocation: Warwickshire, UK
GuyModeratorif I get hold of an HDMI audio extractor with a digital coax out, then connect that to the BS3 and choose that as the sound input for that particular AV input, that might work.
Yes that should work fine*. When hdmi inputs were first introduced on B&O TVs, users with ML systems were told to add a SCART connection in order to make sure that sound was distributed to link rooms. This was quite straightforward when, for example, DVD2 had both hdmi and SCART outputs.
* EDIT: Actually I am not sure that it will! It’s still a digital input to the BS3. Maybe an hdmi extractor providing analogue output that can be fed into the BS3 would be better.
* EDIT2: From the BS3 Userguide p14:
NOTE! Only sources with an analogue signal
can be distributed from a main room TV to
the link room system.I have had mixed results trying to distribute hmdi sources from BV10-32, as described in this post (and the wider thread): https://forum.beoworld.org/forums/topic/beovision-10-and-new-apple-tv/#post-51987
GuyModeratorI’m not sure which version of PTSN it is, so I have a ttached a photo of the back of it, hoping that will identify it.
That’s a Beoline EU Mk2. If you take the second to fifth digits of the number under Beoline (1113068 GB), I can see that its Type Number is 1130, and then you can make reference to that table. The GB next to the number indicates that it is built for the UK market and should be able to provide caller ID with compatible phones.
Unfortunately the table indicate that the BC6000 Mk1 is incompatible with that PSTN – basically not all functions work. I had a similar problem connecting a BC2 Mk1 to a Beoline Mk2 where everything worked except clock and phonebook.
First I would be tempted to try your original PSTN again, resetting phones and PSTN before setting up the whole system from scratch.
Failing this, I would be tempted to replace your three BC6000 Mk1s with the much more capable and reliable BC6000 Mk2s – they are quite good value on UK eBay currently.
Lastly, here’s a copy of notes that I have made about using the service menus in Mk1 and Mk2s – this may be useful:
Beocom 6000 Mk2: Service Menu: 9#9#9✱INT
(allows handset/base reset and to check SW versions etc)
Beocom 6000 Mk1:
Service Menu: 9 – # – 9 – # – 9 – ✱ – (DOT) – 7 – OK
1: HS SW VERSION
2: BS SW VERSION
3: CURRENT VOLUME
4: MAX VOLUME
5: NOMINAL VOL
6: MIN VOLUME
7: FORCED TRANSM
8: EEPROM EDIT
9: RAM WATCH
10: CONTRAST
11: SERIAL NUMBER
12: ONTIME TOTAL
13: ONTIME OFFHOOK
14: ONTIME CHARGER
– When replacing the battery, always press: 9#9#9✱655 OK
– Reset base: Press (dot) 7 000 8
– Reset handset: Press (dot) 7 000 9
– Read out Handset software version: Press (dot) 7 000 1
GuyModeratorAre the Beocom 6000s Mk1 or Mk2? The Mk2 has an INT button to the left of the wheel.
What version of PSTN are you using? Is it the second one along on the table below?
Check compatibility between phone and PSTN using the table – for example there could be problems using BC6000 Mk1 with Beoline EU Mk2.
You could also try re-setting all handsets/bases and setting the system up again from scratch.
GuyModeratorSorry, my impatience made me click too many times, perhaps a moderator can take away two posts? Thanks! Johan
27 April 2025 at 12:31 in reply to: No software updates on various B&O products: Essence MK2, Beosound 1 MK1 … #65354 GuyModeratorHave you got ‘Power Saving’ turned on in Settings? Apparently that ‘limits certain functions’, so I suppose it could include SW update.
You could also try a reset to factory settings and set up again.
27 April 2025 at 11:16 in reply to: No software updates on various B&O products: Essence MK2, Beosound 1 MK1 … #65348 GuyModeratorThat’s a bit strange. Are you sure it is connected to the network, and that the network has access to internet? You could maybe connect straight to your internet modem/router using RJ45 and try again.
27 April 2025 at 11:07 in reply to: No software updates on various B&O products: Essence MK2, Beosound 1 MK1 … #65345 GuyModeratorAnd has successfully updated to version 6.0.57105.69827962
27 April 2025 at 11:03 in reply to: No software updates on various B&O products: Essence MK2, Beosound 1 MK1 … #65343 GuyModeratorI just connected my Essence – it is showing as avail:
27 April 2025 at 10:48 in reply to: No software updates on various B&O products: Essence MK2, Beosound 1 MK1 … #65339 GuyModeratorHave you checked against the latest listed releases here? https://update.bang-olufsen.com/products
According to page 3 of the link, Essence Mk2 latest update was released 9 Apr 25. I will connect my Essence later and check that it updates OK.
GuyModeratorHi and welcome to Beoworld!
Effectively you have two devices connected directly to your Beolabs, which you shouldn’t do – for reasons that you have discovered, but you could also cause damage!
You have at least two options:
- A powerlink switch like this to enable two devices to share the speakers: https://shop.oneremote.dk/shop/69067-powerlink-switch/4162-powerlink-speaker-switch/
- Adding a NL/ML Converter so that you can connect the ML socket of the BeoSound to the NL socket of the TV. This could be a better option if you want to add more NL devices in the future and want to play the BeoSound 9000 over the NL system.
There are possibly other options making use of the aux input of the BeoSound (or AV input of the TV) but these may not be as user-friendly.
EDIT: Here’s a cable from one of our Sponsors that makes use of the TV’s AV input: https://soundsheavenly.com/tv-input/138-2295-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html#/5-length-5m
GuyModeratorI set up my Mk1 Playmaker today and experimented with a few things including factory reset, followed by different methods of setup.
Some observations:
- I too was not able to setup or access the Playmaker using the B&O app – I saw the same messages as Madskp.
- I was able to use the old BeoSetup app (no longer avail) to do a ‘first-time’ setup the Playmaker. As described in the instructions, I had to first go into the iPhone wireless menu, disconnect from my home wifi and connect to ‘Playmaker_AP’, whereupon the BeoSetup app (but not the B&O app) could be used to complete setup.
- After a further factory reset, I was able to complete to complete a ‘wireless setup via cable’ using a laptop (switched to airplane mode) and the following instructions:
I found the Playmaker setup menu under the published IP address of http://169.254.11.22 – so perhaps it is indeed just different for the Mk2 Playmaker (or perhaps it is only for first time setup via cable – I haven’t seen a Mk2 manual).
I am not sure how the above helps @TWG, but am happy to experiment further if required. It would be useful to know if his Playmakers are Mk1 or Mk2, but I would recommend webpage setup using a computer on his home network to find the individual devices by IP address (look in computers Network folder for Playmakers) and change settings as required.
GuyModerator(I am not sure why this is not as mentioned in the manual, but maybe a difference between MK1 and MK2 or something that has changed with an software update.)
The only significant difference that I know of is that the Mk1 had to be connected to router by RJ45 to update firmware (as mentioned in the Mk1 manual), whereas the Mk2 could apparently do so wirelessly.
I usually used the setup webpage (rather than the app) to set up my Mk1, and it was relatively straightforward. Although I don’t currently have the Playmaker in use, it is listed in my B&O app so this must have detected its presence in the past. I do remember experiencing connection/detection problems if I renamed the Playmaker and included an ‘&’ sign in the name – eg ‘B&O Playmaker’, but this may have been specific to the dnla streaming app I was using at the time (I didn’t have an iOS device when I first bought my Playmaker).
I do still have the ‘BeoSetup’ app (no longer avail) on my iPhone, and think I have used that with the Playmaker in the past. The app has slightly different setup instructions for PM Mk1 and Mk2 – the Mk1 has an orange flashing light when ready to connect to network, whereas the Mk2 has green.
@TWG I am happy to dig out my Mk1 Playmaker and test anything that may help with your problem – I’ll see what I can discover later in the week.Location: Warwickshire, UK
The Beolink Converter 1611 would not be any help in this setup. Masterlink audio connections need to be activated and controlled by B&O equipment at the ‘receiving’ end of the connection.
I assume that the BS4 and Denon amp are in the same room and that the BS4 has no other speakers connected?
I can see two options:
- Use Masterlink to connect the BS4 to a Beolink Active 1636 (and IR sensor – the ‘hockey puck’ type) co-located with the Denon amp. Then use a cable like this to connect the BL Active’s Powerlink output to the Denon amp’s aux input. If the BS4 and Denon amp are in the same room, put the BS4 in A.OPT 0 and remote control it through the BL Active’s IR sensor. You will have a double volume control situation, able to control volume with either the B&O remote or the Denon amp (but not via the volume buttons on the BS4).
- Re-purpose the wires in the masterlink cable either:
- To connect the BS4’s aux output to the Denon’s input. Aux output is fixed volume hence volume control would only be via the Denon.
- To connect the BS4’s Powerlink output to the Denon amp.
Original B&O masterlink cables are wired as in the following diagram, so you could chose appropriate wires and solder your own connections:
(EDIT: Unable to load image for some reason, hence added as attachement)
You must be logged in to view attached files.Location: Warwickshire, UK
GuyModeratorHaver you tried a handset reset? Press (dot) 7 000 9
Also (but you may have done this), after a battery replacement you are supposed to press 9#9#9✱655 OK
GuyModeratorHi Roger and welcome to Beoworld!
The runners for the doors (especially at the bottom) may need cleaning and light lubrication – I would try this first.
In addition the door drive belt may need replacing, or the wires that move the doors may have come off their runners.
With the video in the thread above, plus some of the disassembly instructions in the following thread, you may be able to attempt a DIY repair: https://archivedforum2.beoworld.org/forums/p/4707/42777.aspx#42777
If you need the Service Manual it is available on this site to Silver and Gold Members.
GuyModeratorBut now it seems that to get a PUC code for Apple TV would cost way more than I paid for the Apple TV!?
Don’t forget that you can also teach an Apple TV to respond to another remote. Hence you can chose another device that is available in your TV’s PUC list (eg a Humax Set Top Box) and teach the Apple TV to recognise the IR commands. I used this technique with my BV6, and have written about this in the past on Beoworld. I should be able to find the thread together with some helpful hints if you are interested?
EDIT: Here’s the thread where I talked about my experiences and gave a handy hint about pressing some of the commands repeatedly and fast: https://archivedforum2.beoworld.org/forums/p/46321/334962.aspx#334962
The DVB-HD does seem to be behaving itself so best left alone???
Yes probably, but you mentioned a ‘new menu in a foreign language’ – has that gone away?
GuyModeratorCan anyone tell me if the BC9500 and BC8500 amplifiers are the same?
The 9500 and 8500 share the same service manual, so I just had a quick look through and can’t spot any highlighted differences on PCB60, but it’s probably worth a more thorough scrutiny.
I don’t think I’ll ever have use for the 2-way remote capability of the 9500.
There is one other useful feature of the 2-way remote capability, that doesn’t need a 2-way remote. The fact that the BC9500 can transmit (as well as receive) IR commands can be of use: You can use Beo4/BL1000 to transmit a LIGHT command from an MCL link room and the BC9500 will re-transmit this in the main room. I found this useful to relay LIGHT commands from an MCL link room to a Lightmanager Pro in the Main Room, which then controlled (by RF) lights back in the link room (or anywhere else in the house in RF range). The BC9500 has to be in A.OPT 1 or 2, and I did not try it from an ML link room (I didn’t have one). It’s a bit of a specific case and may not be of value in your setup, but worth mentioning.
GuyModeratorThanks for the assistance. I know there was a list of PUC codes on the TV previously as I stumbled apon them by accident a few times but it appears that now there is just “B&O test control” There are no others. How this could happen I have no idea?
Additionally a new menu has appeared down the left side of the screen in a foreign language on DTV despite English being selected. It seems to have a mind of it’s own?
That all sounds a bit strange! I would be tempted to go into the Service Menu and ‘Reset to factory settings’ to see if that has any effect – at your own risk of course!!
Given that there also appears to be a DTV problem, you could also try re-flashing the DVB-HD module software using the USB socket. I have copies of the latest SW for mine that I downloaded from B&O before it was removed from their support pages – file name is ‘9100357_SW_DVB_HD_MODULE_10_01.990.fpkg’ if that’s any use?
GuyModeratorI have just spent 5 hours trying to find the PUC list on a BV10 to include apple TV.
Not sure that I can help with your other concerns, but on my BV10-32, when you go to the ‘connections’ menu and set up an input, if you populate the ‘IR SOCKET’ setting with ‘PUC 1’ (for example), once you press GO to store, the next screen is one where you can see the PUC list(s), and use the Left/Right arrows to move through the various PUC lists, (one for STBs, one for DVD players etc).
I hope this helps!
