Forum Replies Created
Die_Bogener
BRONZE MemberThis may not matter if the 8000s have no significant output at those frequencies anyway, to phase-cancel.
Your ears will notice the difference that there is something wrong. Be sure, you can hear it. Maybe not today, but in some weeks…
And if you know that there is something wrong, you can hear it. Everytime, everywhere … 😉
Why not a quite normal Beolab 2 ?
Die_Bogener
BRONZE MemberThe delay will only be compensated when you sit straight inline… TV-BL8000-Bl19.
If you sit in different locations not inline you will hear the delay.
Are you sure, that the powerlink socket is a output for other speakers and not input?
It is no good idea to mix analog speakers with DSP driven digital speakers, there is always this disturbing delay. Playing with the runtime of the signal is only suitable for one (small) position in the room where it sounds right. All other positions notice the difference in runtime … distance and DSP runtime.
Why not using a quite normal analog bass?
Die_Bogener
BRONZE MemberNew belts are sometimes not ok, some have to much tension and are too small. Sometimes the tension is so high that the drives moves to the left side.
Too much tension also stresses the motor and needs to much power, the motor can not regulate it any more and makes “wowow”…
The right tension is very low, just test the belt that it does not work like chewing gum… getting bigger and bigger.
A good belt is stiff and keeps it’s size and dimension, not like a rubber band or chewing gum…
Die_Bogener
BRONZE MemberIt is not a good idea to plug in power, having a red led and then connecting Powerlink. Can make a big PLOPP and then nothing in the future…
Has it ever worked before, did you see or hear it or bought defect?
Die_Bogener
BRONZE MemberThe gear does only the movement, the head has it’s own justage … see the red stuff? This is for the head position.
The gear should only be in something symmetrical end position when switching side 1 – 2
I think there is one tooth wrong… just 1 tooth in endposition looks a little bit weak overlap… how does ist look in the other position? 3 Teeth?
Die_Bogener
BRONZE MemberThere is not one fixed position… there are 2 !
It’s an “either or” position. The spring shall fix it in side 1 or side 2.
It’s an over the peak snap construction.
Just snap it in the gap next to the teeth…
Die_Bogener
BRONZE MemberEbay?
L272M N8 around 50 offers, especially in GB. ~ 5-8$
BD437 is ok, 45V instead 35V… will work.
Die_Bogener
BRONZE MemberOK, safety resistor was dead…
Then the LM272 control of the motor can also have a problem.
Die_Bogener
BRONZE MemberThere is a safety resistor R1 4,7 Ohms in the power supply for TR1… i have seen this defect already several times…
If there is a mechanical overload of the drive it will blow. Especially if the motor is bad… check the motor on a regulated supply. There are caps INSIDE the motor… at least in the BC5500 drive, 7000 i dont remember right now…There is no 22V AC… it’s just 22V DC unregulated. And if in standby without load there can be more than 28V? Maybe, should be ok.
Die_Bogener
BRONZE MemberSince it should be the same keyboard foil with 8×5 keys and quite the same layout: 2300 and 2500 should use the same foil. Even BS9000 and Overture should use the same.
That means, that a scrab BS2500 could donate the foil for your BS2300 if the service part is no longer available… 😉
@Guy: Thanks for the PDF, it confirms that there should be the same keyboard foil in all of these Beosystems…
Die_Bogener
BRONZE MemberIt’s just a matter of cleaning the keyboard… above and behind. It’s a matrix of lines and colums… so a line is not working.
Probably some liquid came behind on the contact board… or a corroded plug of the front/display, may be cpu/lithium battery.
Remove the glas and covers, dismount the front and clamper, disconnect the wires, remove the keyboard and clean it with alcohol. Otherwise replace the keyboard… usually including front, easier…
Die_Bogener
BRONZE MemberDo you have access to a datalink connection?
I had a 8032 cpu with a defect INTerupt pin… meaning that IR is working bad. I connected the master to a MX TV-set… and all was working fine. Exchange of the cpu and the master was ok.
But: use a good socket. It can happen again. The reason is a missing z-diode on the INT pin, causing a small overload during communication. I added a 5,6V z-diode…
And: check the keramic caps near the connectors. There were problems with them, mechanical stress is not good for them.
Also the connector on the front-IR board is very often corroded, causing erratic flickering of the display data.
Martin 2
Die_Bogener
BRONZE MemberSiemens, Philips, Intel are OK.
ATMEL is not ok. To modern…
It must be a standard 80C32 CPU, not with extra additional ram… just 256 internal Bytes. No additional Eprom or ROM or extended RAM beyond 256bytes. No extra Timer.
Not Atmel 80C32x2 because faster…
I prefer Philips, just because of asian counterfeits… intel and Siemens are more expensive or some people get more of your money for nothing.
Martin No.2
Die_Bogener
BRONZE MemberThe cpu is a 80C32 chip. Jep, there are still a lot of them available… but most are not compatible with the old one.
It must be a Philips 80C32 BPN (!!!)
Not compatible are 80C32x2 … they are working faster, there are timing problems.
Have you checked 5V on the cpu board? Best point is the Eprom 27512… Pin14 GND and Pin28 5V.
Was there a Service RESET done… if battery changed? (!!!) Otherwise it will not respond!
Die_Bogener
BRONZE MemberBL8000: the standby transformer T2 has something like 2W available. Usually this transformer is very, very often defect of heat… and the power board is very rare. Usually found for 200,- replacement… if found. And used ones are not in good condition…
If the BT needs 5V 0,8A the transformer will not survive some hours… the transformer can supply 150mA in total. I had to replace last month a dozen of them … and new transformers that fit to the board are very rare and hard to get… out of production for 15 years.
There is plenty of room inside the BL8000 to install a quite normal PSU switch power supply in the upper loudspeaker area…
This one here was burning after 20 years…
Die_Bogener
BRONZE MemberHi,
taking fotos is a very good idea. Documenting with fotos before and after the operation… i do it also before beginning a difficult repair or a unit without documents…
Did you pull any connectors, plugs or something like that? Is it possible to assemble them the other way round? Or shift it by a pin…? Or forget a connector? Pins can break in the solder pad…
Blown fuse?
Disconnect the repaired drive and remove it, a center should also run without it and start again.
Good luck!
Die_Bogener
BRONZE MemberHallo Ernst,
das BC9300 hat dieselbe Radio Platine wie BS2500 und Overtüre. Baugleich jeweils pro Empfangsland…Diese Platinen habe ich dutzendweise instandgesetzt, es sind immer wieder dieselben Kandidaten: Elkos. Nach 20 Jahren ist einfach Schluß und das wird auch mit 30 Jahren keinesfalls besser.
Als besonders auffällig habe ich die kleinen 47uf in Miniaturgröße empfunden, aber das ist schlicht egal. Tausche alle, man kann nicht genau sagen welcher Kandidat defekt ist. B&O hat für jeden einzelnen Schaltkreis/Baugruppe jeweils einen Ladewiderstand und einen dieser 47uF Elkos verwendet. Fällt er aus, zieht er jeweils eine Baugruppe ins Nirwana.
Gruß
Die_Bogener
BRONZE MemberCleaning is a good idea.
But dont use hard plastic tubes… a brush is better.
Much besser is compressed air… do it outside 😉
If there were exploded caps, then there would be no function at all, the TV would be dead.
The problem is: a almost dead cap looks quite like a new one, only if it leaks it can be identified or if it is blown up/deformed.
Caps dont like heat, so most of them die in hot areas and dirty areas… when they dont get cooling air/ventilation.
This hardware is already 20 years old, most units i repair are 30-50 years, not only B&O, also controller/relais in very old cars, fuel injection or controls . I usually take a board, clean it and replace all caps on this board. I dont measure them, testing takes time and is not 100% safe in circuit. I replace them all. Since i do not only one unit or whatever, i restore always 4-10 in series, using 1 test unit for testing the boards. I do only hardware i have for testing… or if it is very simple to find the defect. Starting with the Power supply is usually the best way to start…
Buying caps is not easy. There is not the best cap, it’s always a compromise. The most longliving caps are MKS WIMA, i replace almost every electrolyth cap up to 1uF with a WIMA or even with the new X5R or X7R SMD parts.
The bigger caps come from Panasonic, FC or FR series. They are not easy to get, right now they are very hard to buy… but 10.000h lifetime at 105 degrees are good material.
The problem is: you need a very huge sortiment of caps of every size and dimension to repair them in a usefull time. I think, i have around 200kg and around 25.000 caps in storage right now… just for my retirement.
Die_Bogener
BRONZE MemberThanks a lot Martin ! That is helpfull. If I understand correctly, it can explode if I power it again ?
Do you have and idea of the root cause of this problem ? Is the moving of the TV a probable one ?
S.
Transport?
No big TV or heavy electronics likes a transport. But if you take care not to smash it on the truck… no problem.
But this picture is typical for a bad power supply…
Switch it on? NO! First the caps die, then the transistors and chips… A cap can easy be replaced, a dead chip is a expensive desaster.
TV Tecci? It’s possible to learn it 😉
Die_Bogener
BRONZE MemberLooks very good for a repair! 🙂
It would also cover the defekt black pads, often broken and silver shiny…
It is not 100% original, but 99% acceptable. I would like it … and much better than a 100$ for a single glass door.
