Forum Replies Created
MillemisBRONZE MemberWhere/how did you find the pics/information?
When I try searching for Beoplay EX via the Support page, there is nothing.
When I try via the Google picture result, I – on the B&O site – am greeted with a request for logging in…..which never happened before.
MillemisBRONZE MemberOder die deutchen Beofans kommen nicht in die Puschen
MillemisBRONZE MemberThe BSys4/Sound Center platform – since that is the heart/the cornerstone of my setup.
MillemisBRONZE MemberI’d call that a bug in the Plex app.
What happens if you switch to another app, before you turn off the tv?
MillemisBRONZE MemberHi Thought Police
It is nice to know more about your setup, your wishes and habits in using the system.
In addition to what Geoff wrote…….the solution that trackbeo mentions in his post would be one other possible solutions.
However this would require some additional hard (and soft) ware.
Roon is quite advanced – you will need to run a (Roon) server somewhere in your network (could be on the Mac).
Roon can play via Airplay, but that won’t bring you further.
If you want to play the files as they are, you will need an endpoint to connect to the 28’s and the network in that room. There are a lot of solutions for this out there – starting from a DIY Raspberry solution to totally overpriced.
And you will need the Roon app on a mobile device for controlling.
Yet another solution would be to have a DLNA server running on the Mac and point that to the music files on the Mac.
The Bang & Olufsen app has a section for playback of DLNA based music.
All in all you will have to deal with additional hardware and to learn how to cope with the stuff.
The great question however, is…..how much would you benefit?Some people will say that it is worth it – other will be more hesitant.
My advice would be to start out with simply using Airplay to the 28’s from an iPhone/iPad that has access to your local music on your Mac.
Thereafter you can start to do some experiments (if you are not satisfied).
It will take some time to find ‘the right solution’……..and after all listening to the music must have priority over gear, that might bring a bit of extra to the listening experience.
Once you have the A9 it can be adressed likewise. IMO it wise have a unified, convenient way of playing back your music.
Note! When using Airplay your wireless network should be up to date and well working. You could use the wired network connection in your rooms for additional access points, if needed.
Looking forward to read about how you get along – the 28’s are an excellent choice for speakers.
MillemisBRONZE MemberHi Thought Police.
There would be multiple ways to do this.
However, the easiest way would be to do just as you – as I assume – do now with your Homepods…….use Airplay.
Properly setup and configured you will be able to reach the 28’s directly from the Airplay menu of the Mac.
P.S.
May I ask, if you have concidered to have the 28’s in the ‘home theatre’ instead of the Homepod combo….assuming that those would be used for your tv?
They indeed would be great for movies etc.
MillemisBRONZE MemberOdd decision for a wifi network ?
Have you tried to give these access points the same name.
Otherweise it is hard to give an advice without knowing about how the network in general is configured.
MillemisBRONZE MemberThat might be true.
However, I also made this post in order to get the discussion about Beolink/Multiroom going again on this new site.
What already was shared, we – for good (or rather bad) reasons – can not know now…..at least not untill the old forum will be online again as read-only.
Also I remember that Kristian Klit (from B&O) a while ago in the comment section in a Beotalk video wrote that he would have a new document about this ready soon.
Maybe this is that….or something else?
MillemisBRONZE MemberCompletely agree!
A huge thanks to Keith and the team for spending their time, knowledge to get the forum up and running again.
This is a test – very easy now inserting photos right from the iOS Photos app ?
