Forum Replies Created
MillemisBRONZE MemberSorry Steve.
Pindsen seems to live in Denmark…..and can not buy from you – unless this has changed recently.
MillemisBRONZE MemberAdapters like these two should do the job….if you want to go the Playmaker route.
Use your excisting PL cable with the RJ45 adapter
Use the 7 pin DIN adapter with the cable from the BG.
(You can use a 5 pin, if you screw out the two extra pins in the BG cable/plug….in that case be sure to keep those safe for future use of the BG).MM
MillemisBRONZE MemberYou will need some kind of volume controller.
I’d go for a Playmaker and connect the BG (using an adapter cable from DIN to RCA L/R).
From there just use regular PL for the speakers.
The line-in port on the Playmaker has auto sense – just start playing.You can get the Playmaker cheap – I just looked on Blå Avis.
Any Beo4 will be able to control the volume – maybe you already have one.MM
MillemisBRONZE MemberA converter will not be needed – the optical cable is all you need.
Be sure that you have turned on sound out via optical in the tv menu – also set the sound format to PCM ( the Core will not support sound in other formats).
There are many explanations/videos on the internet, that explains how to. It does not matter if it is a soundbar or the Core via optical – the settings are the same.
MillemisBRONZE MemberSeems that the Auralic sends the sound out as a line signal.
Is there no remote control for volume – can the Auralic be set to variable output (instead of fixed)?
The Playmaker had a volume control built-in via the Beo4 or the wheel on the top…..it works as a preamp.
The BL6002 can not be directly volume controlled.
If you still have the Playmaker, one solution would be to connect the output of Auralic to the line-in of the Playmaker – this has line-in sense and turns on when a signal arrives there.
Then connect the BL6002 via PL to the Playmaker as before.
Hereafter you can use the Beo4 for volume control.MM
MillemisBRONZE MemberThe DPL port does nothing – is for ‘future use’.
When or if this ‘future use’ will be available, is not known
Please also have a look here:The DPL port on the BL50 is for inter loudspeaker communication only.
As for digital inputs, apart from the USB audio input you have two SPDIF inputs – coax and toslink.
The optical input supports up to 24/96 – which is what the Core will output via optical.
MillemisBRONZE MemberJust use the optical in instead.
Every modern tv has an optical out.
MillemisBRONZE MemberThat is a serious setup, indeed – have fun ?
Please report back, when you have all set up and configured….and testet.
MillemisBRONZE MemberWhy not just use a regular ML cable?
Plug in the ML connector to the converter and run the ML cable (without the ML plug) to the junction box and mount the wires there just like the other ends are.MM
MillemisBRONZE MemberN.B.
You will probably be able to find your Blu Ray player in the PUC setup (in the tv menu) in order to control it with the B&O remote.
You can configure the Speaker Groups you make, so that only the 5’s (probably set as fronts) are active with a certain source….for instance if you often use the Blu Ray player as a CD player.
If you use the Beoremote One you can use one of the MyButtons to start a given source in a given speaker setup.
MillemisBRONZE MemberWhat happens if you use the local control on the A6?
MillemisBRONZE Member@Sandyb
I see what you mean – having 4 speakers is always better.
But when someone just wants 2, I always ask people to concider using these in the back (with the BST) – which may seem a bit strange coming from a previous setup.
The triangle can sound very good for movies – but in a somewhat bigger room having fronts will be a good decision, even if music has less priority.
With the 28’s in the back there is still the option of using these for (2 channel) music.MM
MillemisBRONZE MemberI see no reason, why you should not be able to connect the 5’s there.
I have have been running a full 5.1 setup with my office V1/32” for many years…..no problems there.
Lots of options how to use the speakers/speaker groups….just like with other newer BV’s.
You ‘only’ have 3xPL and no WiSA.
Otherweise – if you can live with a max of 40” – no limits.I have a blu ray player and an ATV connected – and it is connected to the NL setup in the house.
I am keeping that setup as long as possible!
MillemisBRONZE MemberIf you are only considering one pair of speakers plus the BST as the new setup, I would advice thinking of using the 18 or 28 as the surround speakers….not placing these in the front.
For a tv/movie setup this would be ideal.Do you plan to keep the BL8000?
How big is the room etc?MM
MillemisBRONZE MemberJoe Bonanassa – his 2022 album Time Clocks
In Dolby Atmos mixed by Bob Clearmountain
MIX STUDIO PANEL: JOE BONAMASSA’S TIME CLOCKS IN STEREO AND IMMERSIVE
MillemisBRONZE MemberSure, but in that case the owner of a BV Contour has paid extra for the included Stage…..that he can not use!
It is either/or – you can not send the sound from the LG using the Soundsend device to external speakers and use the Stage as the speaker unit at the same time – they both use the (e)ARC connection.
LG certified WiSA does not mean anything but certifying that the CEC control works flawless when connecting the Soundsend device to the newer LG tv’s.
MillemisBRONZE MemberThe short answer is no!
It is dedicated to a built-in Netflix app on the tv.
The 1719 version was sold with the BV Eclipse:
Guide here:Furthermore, with the 1719 you loose 3 of the otherweise 4 buttons on the more common 1717.
MillemisBRONZE MemberIn that case the BL5’s get the CD signal from the 9000 divided into a digital coax connection for the sound and PL for control and volume.
The signal from the radio part will be only via PL.N.B.
What is connected to the AUX-in on the 9000 will also come via PLIn the actual setup in the picture all PL and control will take place through the ML connection between 9000 and the BV…..given that the BV is in option 2 and the 9000 in option 0.
MillemisBRONZE MemberAs far as I can see, the Wiim is connected only to the BL5’s (using the digital coax).
In that case the volume would have to be done via the BL5’s directly/Beo4.In that setup I see no other solution than to connect the analog out of the Wiim to the BS 9000 – then the volume control would be just like with the CD and Radio section, through ML and BV7.
Another solution would be to connect the coax out directly to the BV7 – configure an input there and choose the A/V command plus the source button, you picked in the setup in order to just have sound.
This way the sound also will be through PL to the 5’s.(Personally I’d choose the first option for convenience).
MillemisBRONZE Member….Despite this, both driver and passenger can simultaneously experience a (mostly) centered image.
Not in my car!
