Millemis
Forum Replies Created
Viewing 20 posts - 341 through 360 (of 1,251 total)
  • in reply to: BeoSound Moment und Essence, BeoVision 11 #52119
    Millemis
    Ich bin für die Kombination vom iPad/iPhone und BROne ?
    IMG_0832
    in reply to: Beolink Converter #52708
    Millemis
    Which ‘beolink converter’ do you mean?
    If you mean the ML/MCL Converter, the posted pic from sverreh is the right one.
    In that case your ‘beolink converter’ – with the ir eye – is what usually is called a ‘Beolink Passive’.
    My post is for the ML/NL Converter.
    in reply to: New product launch – beosound theatre? #38494
    Millemis
    “…unveiling” of what?
    in reply to: Beolink Converter #52705
    Millemis
    Is this what you are looking for?
    Millemis
    Have a look here – click the attachment. MM
    MM – see the already attached file at my response from January 29th!
    Oh – sorry…I did indeed overlook that.
    Millemis
    in reply to: Beosound Core – connectivity and alternatives #49997
    Millemis
    Info here
    Be prepared for a steep learning curve!
    However, there are numerous thread on the forum about this.
    in reply to: Beosound Core – connectivity and alternatives #49995
    Millemis
    Two ways to do this…
    You either connect the output of the Core (using an adapter cable from the PL) to a spare input on the oldschool 7000/9000.
    You connect the output of the 7000/9000 (again using an adapter cable from the PL – alternatively from the A.Tape of the 7000) to the input on the Core.
    However in any case, you will only be able to control the Core part with the app/Beoremote One……not the 7000/9000!
    The 7000/9000 must be controlled with the Beo4.
    One advantage of connecting the 7000/9000 to the Core is that the Core has autodetection of the incoming signal = it turns on when the 7000/9000 starts playing.
    The other way ‘round the 7000/9000 will have to be turned on manually/Beo4.
    The Transmitter must be connected to where the actual sound output would be.
    P.S.
    B&O has made a (now obsolete) ML/NL Converter for connecting these two device generations.
    That would offer additional benefits in terms of controlling everything with the app/Beoremote One.
    in reply to: NetRadio on BV11 #52675
    Millemis
    There hasn’t been any updates for ages.
    Netradio runs on my V1 (and did on my old Avant 1st Gen), which is basically the same platform as the BV11.
    I can not recall what I did….it is almost 10 years ago – it was no problem to get it running.
    Let me think for a while – or maybe someone else can comment.
    in reply to: NetRadio on BV11 #52673
    Millemis
    As far as I am aware all BV11’s were born with the Netradio function.
    In the early-early days of the Beoplay V1 this had to be updated to get netradio.
    Might be a dumb question….but are you sure that the tv of your relative is connected to the homenetwork/internet?
    Millemis
    Ohhh – that is what you meant…..
    P.S.
    I could not find a way to upload a PDF file that explains this.
    So here is a part of it as a picture.
    IMG_0849
    in reply to: Beosound Core – connectivity and alternatives #49993
    Millemis
    The ‘DPL’ port….the mysterious ‘DPL’ port ?
    Noone really knows – or has revealed – what they thought of back then.
    Most likely it is a port, that should support a digital output ( = no input port!), that could have been used, if they had developed further down that route.
    DPL means digital powerlink – which is used on the BL90’s/50’s for the connection between both speakers.
    In an update, at some point it was converted into a port for an ir-eye.
    This however, is rarely used, since all newer devices (including the Core) uses bluetooth for controlling.
    I guess we won’t see any changes there (for the Core as is) – the development of a newer version is rumoured.
    in reply to: Beosound Core – connectivity and alternatives #49991
    Millemis
    Is it possible to plug a non-B&O analogue source into a powerlink input with some kind of adaptor cable?
    No, the PL is an output….for connecting the Beolabs.
    in reply to: Deezer login on TV #52627
    Millemis
    You probably mean the Deezer app in the SmartTV part of the Bsys4 (?)
    As you may have noticed with the other apps there, this platform is obsolete….basicly no longer working.
    In order to get Deezer  to play on the BSys4, you will need an external device connected there with the Deezer app installed e.g. an AppleTV, a GoogleTV/Chromecast…….
    Another way is to have a NetworkLinked B&O device in the setup, start playback of Deezer there and then Join in on the BSys4.
    Using an Essence MK2 or the Core integrated with the BSys4 would even give you Deezer as a selectable source in the menu of the BSys4.
    in reply to: New product launch – beosound theatre? #38489
    Millemis
    Thanks – that worked!
    Seems to be an easter egg ? placed by the app team….
    …..to keep us guessing what has changed with every new version.
    in reply to: New product launch – beosound theatre? #38487
    Millemis
    ….how?
    My app is updated to latest (of today) beta version – I am on iOS.
    Millemis
    Ein Switch – mit den passenden Adapterkabeln – in diesem Stil wäre das einfachste.
    I denke es ist machbar im Alltag!
    IMG_2676
    in reply to: Update Beosound 4 mit DAB+ #40779
    Millemis
    Spotify habe ich noch nicht versucht – lohnt sich das? Die lokale DLNA Bibliothek klingt auch nicht so gut wie Deezer – sie ist zwar da, so als Feigenblatt, aber die ganze Musi bekomme ich auch per Streaming. Was mir noch fehlt ist das Mood-Rädchen der Moment oder auch der Flow – das habe ich noch nicht gefunden.
    Zu Deezer Flow kann ich nicht viel sagen, aber die Funktion ist wohl in der App integriert.
    Dazu mögen andere Auskunft geben.
    Mach doch mal einen neuen Post zu diesem Thema (am besten in englisch).
    Ich selber benutze seit Jahren Spotify Premium – bin zufrieden!
    Auserdem noch Apple Music – aber meist mit der AppleTV/Music-app um Mehrkanal/Atmos zu hören und dann noch für meine Kopfhörer.
    Die Musik auf meinem NAS höre ich mittlerweile selten.
    Meine CD’s höre ich gelegenlich, aber nicht oft.
    Viel Spaß bei dem neuen Setup – schön das ich helfen konnte.
    P.S.
    Ich nehme an, daß du jetzt auch dein/e Lieblingsradioprogram/me auf den MyButtons der Beoremote festgelegt hast.
    Millemis
    I’d say….if you want a convenient solution, you can have 2 devices controlled.
    As already noted, one must be in Option 4 (means pushing the Link butoon before the actual sorce button.
    All other devices must be in Option 0 and will then have to be contolled manually on the device.
    This ‘problem’ has been solved with the newer devices and the Beoremote One/bt, as each device can be adressed individually from one remote.
    in reply to: Can’t add Beolit 12 to the B&O App – crashes #52482
    Millemis
    You probably won’t succeed unless you connect the device via ethernet cable to your homenetwork.
    Usually updating the software (of the Beolit 12/Beoplay A8) solves this problem…..once you have gained access to it.
