matador
Forum Replies Created
Viewing 20 posts - 41 through 60 (of 845 total)
  • in reply to: WANTED: BEOLAB 8002 White/Silver #70394
    matador
    I second Tignum advice,
    It would be easier and more efficient to recloth an “anycolor” pair. It will cost the money for a pair a pantyhose and a double side tape, plus a couple of hours of work: the procedure is very well detailled in the BWII (or I) forum.
    Obvisously any original cloth will be transparent and ugly by now, just look at the fabric on silver Beovision Avant.
    That would mean you need to recloth it anyway.
    in reply to: 9500 v/u meter #70008
    matador
    Beosystem 7700 works the same way: Led meters on only in REC mode.
    That’s a bit dissapointing since all the gorgeous pictures in catalogs are with the meters on.
    in reply to: Sound quality difference on Beovision and Core #70007
    matador
    *Duplicate threads removed.
    in reply to: Beo5/ Beo 6 Remote Controller software #69699
    matador
    Lot of documentation in BWII including a comprehensive guide from a fellow beoworlder.
    Also lot of threads, templates, tips and tricks and also free codes.
    Learning to program the remote is not an easy ride but it is very rewarding: Play with it and come back here with specific questions once you’re really stuck.
    Have fun!
    in reply to: Does anyone recognise this power supply? #69698
    matador
    If you still have the BeoSound 2 charger I would be interested to purchase it of you if you have no use for it. Happy to pay packing and postage cost to Australia.
    Regards
    JOHN
    Hi John. Got one. Let’s talk in PM if you’re still interested.
    in reply to: DIY Beolab 8000 Wood frets (STLs included). #69536
    matador
    How many % should I scale it up?
    Common Issue, yes. Documented in the thread. I can’t rememnber right now but it must be like 10%, 100% or 1000% = A multiple of ten.
    Again, the size of the final object is shown in the thread: please read it all!
    in reply to: B&O U70 headphones #69255
    matador
    Not a really helpful answer but yes, the driver might be dead, I’ve had one dead myself. And they’re special drivers, not  traditional drivers with membrane and difficult to source.
    matador
    Well, no luck.
    After multiple resets and pairing after unpairing the issue is still there: As soon as the music stop (end of an album), when the music resume the sound is chopped.
    I then need to select another sound output and the Beolit 20 again to have continuous sound.
    (the issue may be on the Mac side since it sometimes ask me for a pincode to connect to the BL20).
    matador
    Thank you Mads,
    Make sense since it is a rented home.
    I’ve reset the unit and it seems to work right now. But I will report on the long run as it seems to me to be a usefull intel.
    This is Beoworld!
    in reply to: Flash Your B&O – new(er) thread! #68899
    matador
    I so much in love of the design.
    I bet you are! Those things are so beautiful next to any plant specially gold ones. And the silver plus marble! OMG.
    in reply to: Beo6 Touch Screen #68876
    matador
    More likely a touch screen default that is not “usual” but “common”.
    AFAIK, no easy solution: dead is dead.
    BUT!
    I own a Beo6 with totally unresponsive touch screen and have program it like some sort of Beo4 and it works well.
    You’ve got like 18 hard commands to play with and if you can program the remote to display the commands like the beo4 screen would, in color and in full 360×240 pixels!
    Heaven…
    Hope this helps.
    in reply to: Beoremote One for my equipment #68696
    matador
    broken (and unfortunately irreparable) Beosound 9000
    How is that?
    (I’ve searched your topics but didnt find anything related!)
    in reply to: Beocenter 2300 #68280
    matador
    CD does not spin. Laser replaced with no result. Any good ideas?
    Any politness? Like maybe “hello”, ‘hi there”, “thank you”… Things like that?
    This forum is not GPT driven and you’re lucky a more friendly member than me did answer.
    Anyway…
    in reply to: Beosound 9000 MKII – CD spinning in reverse #68057
    matador
    How was the laser changed, by whom and sourced where?
    in reply to: Réparer du B&O ce n’est pas évident ;) #68024
    matador
    Bonjour et bienvenue sur Beoworld.
    En effet, c’est plutôt rassurant de voir l’appareil correctement remonté parce que la première photo était pour le moins inquiétante !
    J’ai commencé moi aussi par une 2500 et je me souviens en effet de la difficulté à remonter le cable des portes. Une fois qu’on l’a fait et qu’on a compris l’astuce (le petit ressort) on est prêt à recommencer, mais on évite quand même !
    Aujourd’hui j’ai une collection un peu trop encombrante dont je me sépare peu à peu. Attention donc à ce qu’on appelle ici le BeoVirus.
    Très rapidement vous vous rendrez compte de l’importante documentation technique disponible et de la conception très rusée de ces appareils et vous trouverez certainement que, loin de ne pas être évident, les réparations sont addictives !
    D’ici là n’hésitez pas à parcourir les pages de ce forum et des deux anciens forum archivés, ces sont des mines d’informations et de ressources incroyablement riche.
    Bon voyage parmi nous.
    in reply to: B&O in Movies, TV Shows or similar… #67944
    matador
    Danish TV Show “Carmen Curlers” located in Danemark. Part of the action is in a Radio Shop.
    I’m unable to identify any item but the B&O logo is obvious in many shots.
    in reply to: Beosound 5 – network connection? #66990
    matador
    There’s number of threads about BS5 loosing internet connection. I can’t remember if the solution is simple or complicated but it does exist.
    I remember a thread in trhe old forum (I cant fond it right now) where the guy (french by the way) found a solution and wanted to sell it to members.
    I think the problem comes from a corrupted file in the linux framework behind the BS5 software.
    Of course your problem can be different.
    Good luck.
    in reply to: BEOSOUND MOMENT: RISK OF FIRE AND EXPLOSION #66882
    matador
    Please remove all the AI(?) prompts of your post.
    Cleaned…
    in reply to: Best B&O solution for Desktop setup? #66858
    matador
    It’s a self made amplifier…
    https://forum.beoworld.org/forums/topic/bo-inspired-amplifier/
    in reply to: B&O in Movies, TV Shows or similar… #66739
    matador
    The Movie Companion.  They have a beosound 3000 hooked up to a Mcintosh and show a close up.
    That one must be double checked by Members Guy and Madskp before moderation gives a go….            😀
