Madskp
Forum Replies Created
Viewing 20 posts - 1,541 through 1,560 (of 1,592 total)
  • in reply to: BeoLink Converter 1611 Innovative Configurations #42411
    Madskp
    GOLD Member
    . I also made up a lead to test the PC input of the BL Active, only because I had never tried that before. The PC input worked fine using pins 2, 4, and 7 for Left, Right and Gnd respectively. I could select using ‘PC’ on Beo4 and it worked as a local source, but as soon as I disconnected the ML it stopped working – so there is no simple BL Active standalone option.
    not knowing much about the Beolink active I am s little confused about thisPC connection. It is not mentioned in the user-, reference or servicemanual availeble on Beoworld, and this older thread https://archivedforum.beoworld.org/forums/p/15997/128504.aspx mentions it but with other pin numbers.
    has there been different versions of this product?
    in reply to: Connecting Beogram 2403 to BeoVision 11 #43025
    Madskp
    GOLD Member
    I don’t suppose it’s because there is no picture. I seem to remember something about no sound if there is no picture but I am probably completely wrong!
    it should work ok without picture. I had music playing through the analog  AV connector on my Beoplay V1 (which is the same platform) the other day.
    I use the original B&O mini DIN to scart adapter in my setup.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42409
    Madskp
    GOLD Member
    I came around to try this test, but the Beocord keept playing even though i tried various lengths of long presses.
    Forgot to ask, did you connect the BeoCord’s datalink to the AAL pin 6, rather than the usual Beocord pin 7?
    yes, i have made an adapter to reverse pin 3, 5 and 7 to 1, 4 and 6
    in reply to: BeoLink Converter 1611 Innovative Configurations #42407
    Madskp
    GOLD Member
    That makes perfect sense. It also explains … … why my modified DVD1 turned off after a long press.  DVD1 had full control when connected to AUX/TV socket of BC9500, because the BC9500’s AUX/TV socket must have AAL at Pin 6.  Given that I used a modified SCART lead, the data within SCART must be AAL rather than Datalink. … why my OneRemote has to be programmed to a strange number (starting with 4XX) when connected to either BL1611 or a TV’s SCART socket.  This makes it use AAL rather than Datalink.
    Great. Then we at least seem to have figured out what will work and what will not for that part.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42406
    Madskp
    GOLD Member
    Beolink Handbook shows Masterlink and Obsolete Masterlink wiring, pin 12 is “+ supply voltage” in both case, pin 4 is not connected in Masterlink and “+ supply voltage” too in obsolete Masterlink. Shorting Pin 4 and 12 would therefore mean “the device expect positive voltage on pin 4 but because we have changed our wiring, you have to take it on pin 12”. Right?
    I took a look at the diagrams in the servicemanual for LCS9000/Bl3500MK1, and it actually shows pin 4 being connected to whats called V ml instead of pin 12, so this explains the text from the product configurator. Why it is made this way I cant see a logical reason for
    in reply to: BeoLink Converter 1611 Innovative Configurations #42404
    Madskp
    GOLD Member
    sounds more or less as the experience I had with the BV6, 1611 and Beocord 3500. Didnt try the long press off though. Will test that for my next testing session
    Might be the difference between AAL an AL.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42403
    Madskp
    GOLD Member
    Perhaps the shorting (or otherwise) of ML pins 4 and 12 in early model BL3500s is relevant to our investigations?
    It doesn’t say why they have to be shorted, and weird since pin 4 is normally not connected in masterlink.
    What I can’t make of it is in most normal B&O link use cases the activation of the speaker will be from the speaker it self (or via IR). So the turn on feature might be a non standard thing
    in reply to: BeoLink Converter 1611 Innovative Configurations #42400
    Madskp
    GOLD Member
    Or maybe the BL3500 manual is not showing all the connectors on the W1
    Ok, so I confused my self, and probably also you. I misunderstood the drawing in the Beolab 3500 manual thinking it was showing the connections on the Wireless 1, but it is of course the connections on the BL3500. Sorry for that.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42397
    Madskp
    GOLD Member
    It is mentioned i the specification list in the servicemanual for The BL3500 MK2, and I also have seen manuals for the wireless 1 with drawings where it has Two powerlinks sockets and one Ir socket, and in a user manual for Beolab 3500  it only has one DIN socket and is connected via ML. So guess there must have been at least two versions of the W1
    in reply to: BeoLink Converter 1611 Innovative Configurations #42395
    Madskp
    GOLD Member
    But I’ve also read many times on the forum that the Powerlink socket on the 3500 is there for use with W1. I suppose they were different version of W1 over time, one of which uses Powerlink and the other Masterlink, right? But even then, Why would the Beolab react to a Powerlink connection from W1 only and not any other device?
    in reply to: BeoLink Converter 1611 Innovative Configurations #42394
    Madskp
    GOLD Member
    Just a quick note about triggering the BL3500 with 5V. I did tentatively try 5V to various pins whilst I had a 7-pin cable attached to the MCL socket (ML was disconnected). I tried all voltage injections variations that have been mentioned with ML turned both on and off. BL3500 did not turn on. Given that we now have BL1611 working well, I give up!
    Out of curiosity: Did you try the combination +5V on pin 6 (datalink) and -5V on pin 7 (datalink shield)? I have had some thought about this and cam to the conclusion that the rest of the pins are either not conencted or used for the sound part. Furthermore one of the olde manuals regarding datalink signals mentions high signals in the voltage range 2.1 to 5.5V. But again it is just a thought.
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42958
    Madskp
    GOLD Member
     Of course the downside is that for some reason my Mac forgot it had a paid license to LinkPlayer (the battery died during the 8 long years of storage, so on restart it thought we were in 2000, and then jumped to 2023)… and now the required esellerate.net servers don’t work, so I can’t activate my LinkPlayer copy even though I have the original receipt with a code —this limits functionality to one hour.
    I read some of the threads about Linkplayer back then, but didnt realize (or remember) that it was a paid software with activation. That makes it a little more difficalt to rely on if it is not possible to activate anymoreå
    in reply to: Connecting Beogram 2403 to BeoVision 11 #43022
    Madskp
    GOLD Member
    Connector wise you almost cannot do it wrong on the TV side. The worst that can happen there would be switching left and right channel. But what about the orher end of this cable? Do you have phono connectors or DIN connctor?
    in the TV setup under advanced settings there is a possibility to choos S/P DIF on/off. If it is set to on you might not get analog sound through
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42953
    Madskp
    GOLD Member
    I see your frustration when things are not working as you think it should, and then even on an old and slow computer.
    my earlier experience with the Beoport was with the Windows software from B&O which I found frustrating to use. At the time I didnt have any other Masterlink products, and was used to Winamp for listening to music on the PC, so I might not have seen the benefits.
    My first impression with this BM link is much better, and from your pictures Linkplayer seems to have much more functionality (not that more is always better).  So im optimistic.
    One advantage in my system might be that I re installed the Imac a couple of years ago for some other experiment, so its almost a new installation
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42951
    Madskp
    GOLD Member
    I now have the BM link software (v1.5) up and running with the Beoport connected and a pair of headphones in the Beoport.
    I can control Itunes music play/pause/skip/next album and volume with a BEO4, so guess my hardware part of the setup is working.
    I just realized that the Built in speakers in the Imac is redundant in this setup when the sound output is connected to the Beoport, but then again a pair of Beolabs can do better than the built ins anyday
    in reply to: Playing With Beolink PC2/Beoport and old Mac… #42950
    Madskp
    GOLD Member
    I’ve now BM-link and Linkplayer (Thank you E).
    I now have my old iMac 2006 with Snow Leopard 10.6.8 up and running and have found that I have the BM link Installation files. However a little search for Linkplayer Doesn’t help me, so Maybe you could Hint where you found it?
    Thanks in advance
    in reply to: BeoLink Converter 1611 Innovative Configurations #42389
    Madskp
    GOLD Member
    The BeoLab 3500 Mark 2 was introduced in 2006 from serial number 19343452 Item number 1160X11 is BeoLab 3500 with Master Control Link Item number 1160112 to 1160138 is BeoLab 3500 Mark 2
    then I guess both of Matador’s are MK2.
    On the picture of the BL3500 from the guy with the 5V trigger it seems to me that I can  the Item number to be 1160X11 and therefor and MK1 Version. I guess the SW 1.1 also indicates that it is an early version.
    in reply to: BeoLink Converter 1611 Innovative Configurations #42383
    Madskp
    GOLD Member
    OK now looking in the back of the BL3500 – photos first to give you serial number: IMG_6507 And this one partially shows a useful sticker (on the left) that allows you to check the speaker setup in the service menu – will do that later! IMG_6508
    one thing to look for without opening it could be to measure if pin 2 in the MCL/PL connector is connected to other ground pins or not
    OK so no continuity between 2 and 7, or 2 and anything else! Measuring approx 400 kOhms between 5 and 7, and 3 and 7 so let’s assume 7 is ground , and pin 2 is not connected.
    ok these 2 informations combined indicate that you have a MK1 with the MCL connector. Good to know
    in reply to: BeoLink Converter 1611 Innovative Configurations #42380
    Madskp
    GOLD Member
    That’s what I thought! However, perhaps the BL1611 needs to ‘recognise’ a connected product (older TV or BeoCenter) via the AAL socket (pin 6) so that it knows what sources are available. I ran the setup through the PCG as if connected to a BL1611 and BC2300 in the main room, Beoport and BL3500 in two link rooms: This told me to put BL3500 and Beoport in Opt 6. The was no conflict or lockup with this, but I just couldn’t select (eg) TV or RADIO like I could when Beoport isn’t present. When I tried, the BL3500 just turned quickly on and off (as if looking for a source and not finding it).
    Maybe your software version on the Beolab 3500 is making the trouble here?
    in reply to: BeoLink Converter 1611 Innovative Configurations #42378
    Madskp
    GOLD Member
    @Madskp Yes those solution are the ones we try to avoid. They use the PL mode from service “Menu 0 4 GO” and the speaker is turned off as soon as you touch any key on the remote. Volume is set from the source and to me the more important: you lose the sound adjustments from the BL3500. It is clearly much better to have the 1611 solution. But when you have it, adding an extra source for casual needs with the PL path is something that comes free and can be useful.
    What I take from thoose solutions is the pins used in the DIN connecter for respectivly MCL and PL , not the use case.
