hcraig244
Forum Replies Created
Viewing 20 posts - 301 through 320 (of 337 total)
  • in reply to: Beomaster 5000 #33937
    hcraig244
    SILVER Member
    This was interesting….on removing the front panel for shipping to Frede I discovered a wad of folded paper wedged between the panel and the chassis……..cant imagine what it was doing there?
    P1016782
    in reply to: Beomaster 5000 #33936
    hcraig244
    SILVER Member
    And I have now discovered the basis for the “restored by seller” claim on ebay……
    P1016788
    in reply to: Beomaster 5000 #33935
    hcraig244
    SILVER Member
    This is what was living beneath the bottom cover…….
    P1016789
    in reply to: Beomaster 5000 #33934
    hcraig244
    SILVER Member
    Side panels have also had a clean up and a coat of primer applied…..P1016779
    in reply to: Beomaster 5000 #33933
    hcraig244
    SILVER Member
    Cabinet top veneer finished, shame to stain it actually….I quite like the iroko wood grain, but will have to match the Beolab or it will look odd.P1016777
    in reply to: Where are my PMs? #34232
    hcraig244
    SILVER Member
    I can see and click on the links to the pictures in my archived threads……I think they are all there?
    in reply to: Beomaster 5000 #33932
    hcraig244
    SILVER Member
    Oh…..and this has arrived from Frede……such excellent work, was a little miffed at having to pay import duty on it now that we are free from the EU ;¬)P1016775
    in reply to: Beomaster 5000 #33931
    hcraig244
    SILVER Member
    This is a slow and painstaking exercise requiring a lot of sanding and swearing…….cant hurry the glue drying process either….P1016771
    in reply to: Beomaster 5000 #33930
    hcraig244
    SILVER Member
    I’ve decided on this african iroko veneer…..will need to stain it in order to darken it down to match the Beogram 5000 it will be paired with P1016768
    in reply to: Beomaster 5000 #33929
    hcraig244
    SILVER Member
    made a start on the cabinet top, was in a bit of a mess so re shaped the smashed corners ready for veneering…..P1016765
    in reply to: Beomaster 5000 #33927
    hcraig244
    SILVER Member
    this is the internals…..was sold as “restored by seller”…………..
    P1016773
    in reply to: Looking for help Beocord 5000 #34158
    hcraig244
    SILVER Member
    I’m pretty sure the dust cover is meant to close under the spring tension, mine does and I think its normal operation…..lifting the lid manually and the spring closes it ;¬)
    Craig
    in reply to: Beomaster 6000 Type 2702 service manual #34015
    hcraig244
    SILVER Member
    Are you sure its not the 21vdc that is fed from PCB2 ?
    I have had a problem with the voltage regulator for the 21vdc in  the past
    Craig
    in reply to: Beomaster 5000 #33926
    hcraig244
    SILVER Member
    Making a start on “the low hanging fruit”,IMG_2079 to quote a project manager I once worked with. A friend of mine spent some time cleaning up the curser.  Interestingly this piece isn’t anodised like the face plate, which is probably why it oxidised so badly, I’m told that one can determine if something has been anodised by the use of a multimeter set to ohms……if something is anodised it wont conduct?….I will test this. New felt pads will be included too.
    in reply to: Beomaster 5000 #33925
    hcraig244
    SILVER Member
    Sold as fully functional…….however I think a bit of cleaning (quite a bit actually) and replacing of dried out capacitors will be required before power is connected, some replacement veneer too I’m thinking
    s-l1600 (2)
    in reply to: Beomaster 5000 #33924
    hcraig244
    SILVER Member
    Its in a bit of a state…..looks like its been through the wars
    s-l1600 (1)
    in reply to: missing BG4000 #33050
    hcraig244
    SILVER Member
    So ready to be returned to its home……been quite a journey, the success is largely due to Manfys inspiration and guidance  regarding the voltage regulator and toroidal transformer.
    Its good to know that a failed transformer isn’t the end of the road for a BG4000
    P1016764
    in reply to: missing BG4000 #33049
    hcraig244
    SILVER Member
    Played over the weekend without fault………P1016760
    in reply to: missing BG4000 #33048
    hcraig244
    SILVER Member
    Installed the voltage regulator, bolted to the chassis, no additional heatsink required….gave her a spin and nothing is getting more than lukewarm….Martin recommends removing 2TR6 from the circuit board due to overheating causing the 6vdc supply to become unstable…..so I’m good with this, good test required and that should be that!P1016759
    in reply to: missing BG4000 #33047
    hcraig244
    SILVER Member
    Resistor received, however I ordered a 3w component and received a 25w instead……bit overkill but quite adequate….P1016757
