etype76
Forum Replies Created
Viewing 20 posts - 41 through 60 (of 80 total)
  • in reply to: Top audio, missed opportunities, B&O & new customers #48500
    etype76
    I like some of Techmoan’s videos, I have experienced plenty of the audio gear he gets in over the years. His first A1 video commented how rare it was for him to consider a 200quid bluetooth speaker but noted how good modern tiny speakers can be. He certainly doesn’t promote B&O and yes it is a shame that some software bugs diminish the experience. I would also agree with him that a video about a portable bluetooth speaker is a dull subject indeed in most cases.
    As for the B&O price hikes, I nearly fell off my chair. I checked on Sept 1st and here in Japan no change and then this morning on the 2nd…wallop! What I paid last year 1,000,040 yen is now 1,432,000yen (not including the TV vesa mount). Faced with that price today, I simply wouldn’t buy it. I had hoped B&O would release some satellite speakers for the Theatre at an “accessible” price point but I think if they do, the price will be eye-watering. I am  glad to have had my nose touch the hem of a VHNWI’s garment but it may be the last.
    I also don’t buy that A1s/Explore/Emerge etc are gateways for future VHNWIs. Those people could have been using Jabra or Anker and still walk into B&O and come out having spent $150,000 in the blink of an eye. I don’t believe they hold “brand loyalty”, not for B&O anyway.
    in reply to: New product launch – beosound theatre? #38333
    etype76
    v2.5.3
    in reply to: New product launch – beosound theatre? #38331
    etype76
    I see new Theatre software is available for a non-beta like me. Busy at the minute but will check it out at the weekend.
    IMG_5977
    in reply to: Beogram TX preamp? #46611
    etype76
    I think your cables might be good then if they’re already RCA, I know the TX is newer than my models. I misunderstood your first post when you said you got one you meant TX not a preamp. But yes, you’ll need a phono preamp. There are many on the market. Project do them, Ortofon, I have a Creek OBH-15. There are more reasonable ones too on Amazon or such.
    in reply to: Beogram TX preamp? #46609
    etype76
    What “preamp” do you have exactly? And where are you connecting it on the tube amp? I’ve never had an issue with getting my Beogram 8000/8002 to work with various setups.
    I have the din cable from my Beogram to a din>RCA adaptor which goes into the input on the PHONO Preamplifier then RCA output to my amplifier. Are you sure that you are using a phono preamplifier? As that is not the same as a preamplifier. Sorry if I’m being obvious, I don’t know how deep you are into the Beogram/vinyl world!
    etype76
    (The m3 Millemissen’s great idea!) The M3 is wired to the home network and I use Beolink multiroom to play the record player
    Actually the idea came from Henrik of the BOTF – maybe he even had it from a member of the BOTF. So kudos goes to Henrik….I was just the messenger.
    Well then, credit to Henrik too. I guess the OP wouldn’t need the m3 with a Beosound 2? What I would say, yes get a decent phono preamp. I know there are a lot of differing thoughts here and I guess it depends how much vinyl you listen to but a link to a $60 Amazon phono preamp wouldn’t cut it for me and I’ve noticed big improvements on good line-in cable and a solid preamp.
    etype76
    I didn’t get much difference when I switched between line-in sensitivity so I stuck with ‘medium’.
    For pure audio, you’d be better going the 28s route. I went with the Theatre and have a couple of BL3s as rears. It took me a long time to get a sound I liked from my Beogram record player with this setup and it is still a work in progress really.
    I have the Beogram (no internal phono preamp) connected to an external phono preamp, then a 1 meter decent RCA to mini Jack cable to a Beoplay M3 with volume set to 0. (The m3 Millemissen’s great idea!)  The M3 is wired to the home network and I use Beolink multiroom to play the record player through Theatre and sometimes just BL3s as I can assign speaker groups. I use BR One for volume, and Join function for multiroom.
    alternatively I could use 12m of line-in cable to the Theatre but when I tried that, did not sound good.
    in reply to: New Wireless Speaker Beosound A5? #45419
    etype76
    The specs seem great and I like the dark oak. I am just struggling to see where this fits into the product line or what need it is actually fulfilling. There is the level, Balance, Beolit, Beosound 2. It’s not for me anyway.
    in reply to: Hum and buzz on BL3s to Theatre #44622
    etype76
    Thanks, I recall that in the manual but I always thought that MK2 was compatible with everything and being the thicker type was less susceptible to noise.
    in reply to: Beosound Theater usb-c line-in #44374
    etype76
    This is the B&O one I ordered from the dealer. Works fine. Can your dealer not order you one?
    CCDAF12C-4764-43D5-B182-47DD6946AA77
    in reply to: New product launch – beosound theatre? #38207
    etype76
    etype76 wrote: ‘I mean BG>phono preamp > preamplifier>theatre’ If there already is a ‘phono preamp’, there will be no need for further preamping. That is the way any BG must be setup to a line-input. I was just curious, if etype76 wanted something extra to manipulate the signal – some people want to add tube preamps and alike, when they want to listen to vinyl. MM
    yes, this what I am thinking; a tube preamplifier for the phono preamp and, say, a CD player in the future.
    in reply to: New product launch – beosound theatre? #38203
    etype76
    Hi all,
    if I wanted to add a preamplifier to my Beogram with the existing connected phono preamp to Theatre, is this possible? I mean BG>phono preamp > preamplifier>theatre.
    thx
    in reply to: New product launch – beosound theatre? #38197
    etype76
    I’m on 2.3.4 with a pair of 3s connected via PL. I haven’t had any dropped speakers or rebooting issues so far. Weird. Hope those who do get it sorted soon.
    in reply to: New product launch – beosound theatre? #38167
    etype76
    Ya just 4 pieces and a tool to change a battery. Must better than a USB C port that is in every house already.
    For me, yes. Id rather change the batteries every 3 months or so than charge it every week.
    in reply to: New product launch – beosound theatre? #38165
    etype76
    I’m new to the BR1 too and have yet to see the initial Varta batteries die. They were fairly simple to install. TBH I just buy a pack of Duracell ultra from Costco and I’m glad there’s no charger, cables, connectors or other broccoli (unnecessary paraphernalia) with the remote.
    in reply to: Meeting a B&O “Super fan”! #43512
    etype76
    I enjoyed this. As a Beogram lover, jealous of the black 7000. Made me laugh the 4000 tucked under the coffee table. Yes, space tends to be an issue .
    in reply to: New product launch – beosound theatre? #38121
    etype76
    I get it now. I just started all over again and see the + sign. It’s late so I’ll sort it out tomorrow. Thx Mr. 10 percent for pointing me in the right direction. 🙂
    in reply to: New product launch – beosound theatre? #38120
    etype76
    The Theatre will recognise the number of powerlink connections connected. In my example, I have 4 “+”. If only connecting a single pair of BL3 with a splitter, you will show only 1 “+”. Press the +, add a speaker. Press the new +! Add second speaker then follow instructions to set channels (music plays in each speaker), the follow room sense
    What screen is that? I don’t get any “+”. Even when I go to product settings>connected speakers.
    DAB3B7E3-7D71-45D9-AE29-47271991B656
    in reply to: New product launch – beosound theatre? #38118
    etype76
    Attempting to connect 2 Beolab 3s to the theatre as rears (left and right back). I am using mkII Powerlink cables going into a Rj45 splitter into PL1 socket on the Theatre. When I add the speakers it seems the theatre only thinks there is one. I thought one PL socket accommodated 2 speakers? I get sound from both but when I assign roles, I can only choose left or right. Do I have to now buy another Rj45 adapter and have one speaker going into PL2 then?
    cheers
    in reply to: The Halo still a viable choice? #41431
    etype76
    Quite an impassioned thread I inadvertently started.
    I thought I should give an update. In the end, I went for the Beoremote one. It fits my relatively simple setup of Theatre for TV and music. I also didn’t fancy having another device that needs to be frequently charged. I am still waiting on it as I ordered it on Dec 23. Perhaps in a future home I’ll have the BLI and make way for a Halo but until then…
