Forum Replies Created
Die_Bogener
BRONZE MemberA dying cap in the sound path will not react within a couple of seconds… dead is dead. Only some heat can change this fact for some time.
No, this behaviour is typical for the muting relay. Clean the contacts either with contact cleaner or very fine sanding paper or a special contact file.
You can test this fault with the second unmuted pair of loudspeaker plugs. If there is no problem, it’s the relais. If the problem consists also on the unmuted path, it’s a cap problem.
Die_Bogener
BRONZE MemberYou need a Beolink 7000 “RDS”…
Has it “RDS”?
Not all BL7000 can handle RDS.
Die_Bogener
BRONZE Member“on the diodes…” or around the diodes?
“At” means dead diodes… at least one has died.
… and yes, there are around 40V around them. TR10 is the switch to fire them up…
… and a dead C19 can fire them… literally until they crack.
Die_Bogener
BRONZE MemberDie_Bogener
BRONZE MemberHave you checked the lithium cell 3V and the option programming?
The display is ok?
The ir sender use a pretty high voltage… 32V when i remember right… and the axial caps are pretty old. I found already some of them with a short, and a burnt resistor on the display.
But it can also be dirt on the red plexy glas.
Die_Bogener
BRONZE MemberThe transistor is not the problem.
Replacement necessary of both? No!
But both of them must be ok. The amplifier factor must fit together. There is no use of a transistor with factor 20 fitted with another one with 100. This will not work. They must form a pair with the same amplifier factors.
Just for testing and find the fault? Just replace it… and replace it later by the real one.
Next problem: did you adjust the no-load-current? A potentiometer, adjusting the current when running in standby?
No? OK, then the next transistor will fail also.
Power amps are always problematic. Because of that, use a light bulb in the powersupply… better 2x in the positiv and negativ supply. When the light goes on, you have a problem. Or you have found the problem.
Use a 5W 12V or even 2-3 in line depending on the size of the amp … at least it will limit the smoke.
Die_Bogener
BRONZE MemberSorry, it’s not a couple, it’s a lot of them. Around 50-80…
… and the ones around the Dolby Chip are the reason for the bad dull sound. There you need MKS Wima +/-5 tolerance… and the the sound will be great instead +50/-20% electrolyth series crap.
Selected +/- 1% MKS non magnetic in the complete sound path … and it will play audiophil.
That’s hard work for some days and it’s not easy to get the material or do the measurements…
The upgraded Beocord 7000 can play and record from a CD and no one can tell, what is now playing…tape or CD. Only a very few people can do this…
This one has just some of the modifications (~30%)… just an impression what is inside and what is to do.
Die_Bogener
BRONZE MemberThe switches can have oxidation. There ist just a switch going to the 8155 port chip, nothing elase but a cap an d a resistor.
The switch itself can have a problem. You can measure it, resistor 0 or very high.
But what helps: replacement or some current around 200-500mA… the current will clean it. But only if disassembled or the cpu will die.
Second possibility: there is a connector from the front pcb to the cpu board. The connector can have the same oxidation, but can be cleaned.
Die_Bogener
BRONZE MemberHeads defect?
99%= NO
Caps defect, quite normal.
Electrolyth and tantalum caps fail after this long time, that’s quite normal.
Die_Bogener
BRONZE MemberMX6000?
On the MX stand?
Maybe the Playstation under the MX in a shelf?
Then a pair of BL6000 will do a great job.
It is important, that the hight of the picture tube meets the output of the loudspeaker.
It is disturbing, when the picture and the sound come from different locations, especially when the hight does not fit together or is to far away.
MX on a stand, BL6000 left/right to it. Lot of fun. 🙂
The MX6000 can program the internal and external speakers as something like a sound stage. The stereo signal becomes wider and the effect is, that you can locate objects by hearing the position and not only by seeing them on the screen. It’s much more realistic.
Die_Bogener
BRONZE MemberMaybe a old timer programming in memory?
24 December 2022 at 18:56 in reply to: Beolab 4000 – Taugen die was? Vergleich mit Beolab 6000 etc.. #34457Die_Bogener
BRONZE MemberOh oh…
Kabel Voodoo. Was soll’s… aber komisch, am Hybridverstärker gings glatt vorbei. Da sind die Beinchen noch viel viel dünner … das ist dann die Sicherung dafür. 🙂
Die gezeigten Elkos kann und sollte man nach 30 Jahren machen. Ok.
Aber a bisserl mehra Soundweg gibt’s da schon noch… aber der ist nach dieser Kur wenigstens nicht kaputt 8)
Naja, ich hoffe nur, dass nie einer mit sowas zur Reparatur kommt. Das fällt dann unter Totalschaden.
Mit Klebeband reingetüdelte Elkos aus der Stromversorgung. Wofür die Schaumstoffringe sind, hat da ebenfalls jemand wieder nicht geschnallt. Grausam…
Wie der Klang sich da verbessern soll…. hmmm, auch Voodoo? Geht nich’ anders…
Die_Bogener
BRONZE MemberUps…
da hat jemand die Kühlluftöffnung vom Verstärker zubetoniert. Die Atmung eines Lautsprechers so zu behindern hat schwere Vor- und noch mehr Nachteile. Nur den Vorhub zu fördern und den Rückhub zu behindern per festem Filz heißt schlicht, von Bassreflex nicht viel verstanden zu haben… nur noch 50% Bassvolumen.
Und Kabel Voodoo ist echt Glaubenssache. Kann man machen, aber es geht wesentlich einfacher… Schaltplan lesen und unnötiges Zeug rauswerfen. Alleine was man serienmäßig ohne den geringsten Aufwand rauswerfen kann… und kostet nix ausser etwas Arbeit.
Das Einzige, was man empfehlen kann: Mundorf macht echt gutes Zeug… leider viel zu groß für die kleine 6000er und weil ohne passive Weiche… für diePenta geht’s bestens.
… und raus mit Elkos. Das wurde richtig erkannt, die sind allesamt fällig nach dieser Zeit.
Elna Silmic ist OK, Nichicon ist das Material was ich meistens rabenschwarz oxydiert rauslöten darf… werd’ also den Teufel tun und den neuen Belzebub wieder einlöten. Warum sich mit 2000 Stunden zufrieden geben wenn man doch 10.000h mit Panasonic FR und mehr haben kann?
Wenigstens ist das Platinenmaterial der 6000er etwas resistenter.
Die_Bogener
BRONZE MemberAustausch elektronischer Komponenten wie Chips und Kondensatoren…
Serie B&O für den Opamp LM837 in den hochwertigen Bereichen: Klirrfaktor 0,0015% mit Rauschabstand 90 dB, ansonsten deutlich schlechter…
Burr-Brown OPA 2132: Klirrfaktor 0,00008 % mit Rauschabstand 130 dB
Austausch aller Elkos +50%-20% gegen +/-5% nichtmagnetische MKS Folien
Entfernen aller parasitären Schaltungsteile um genau diese “Sparschäden” wegzudämpfen…
Danach geht einiges.
Stelle nur mal ohne Quellenwahl auf maximale Lautstärke und betätige den Lautstärke Regler an der Fernbedienung. Man hört den Datenbus der Chips zirpen und quieken … Diiiidadaddadiii… deutlich zu hören.
Mit Mod zirpt dann garnix. Ruhe, das reine unverfälschte Signal.
Die Standardeinstellung bei den üblichen B&O Anlagen: Höhen rein, Bass rein… und als schlimmstes: Loudness… man will ja Bass und irgendwas verstehen.
Danach: Bass 0, Höhen 0, Loudness aus. Keinerlei Klangveränderung, kristallklare Höhen, abgrundtiefer Bass und ein richtiges Volumen … genau so, wie Aufnahme mal war.
Hör dir auf einer audiophilen Anlage mal “Hotel California” an, und dann Serie. Dann weiß man den Unterschied. Dann ist Serie tot…
18 December 2022 at 10:13 in reply to: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive #39861Die_Bogener
BRONZE MemberThe voltage/load of the 2x18V is not quite symmetric, the load is unsymmetric… around ~20V is ok.
The problem does not move with exchanging the power boards?
If no movement, the problem is not the power supply…
Probably the amplifier itself… broken line, defect cap… check the +/- 15V supply. The on/off logic is on the amplifier…
Die_Bogener
BRONZE MemberA Penta has 300W output… your neighbourhood will know every detail of your songs…
It’s the adjustment of the “no load current” potentiometer … or the poti itself is defect… overheating the amp. Touch the metal of the amp, it becomes pretty hot with this defect.
Die_Bogener
BRONZE MemberI use a special transformer, switchable in 10V steps… 10 – 240V, with Volt and Ampere Display.
Instead of a fuse a 220V light bulb can help, if there is a shortcut problem… a light goes on.
Die_Bogener
BRONZE MemberDie 8000er hören sich schon gut an, aber wie bei vielen B&O Sachen wurde wert auf Schönheit und Optik gelegt, weniger auf den Klang. Für mittlere Räume sind sie serienmäßig ok, für einen Fernseher reichen sie dicke. Für viel Baß sind sie eher … schmächtig.
Serienmäßig zersetzt sich jetzt der Schaumstoff darin, ich sag nur schwarze Pampe. Nett…
Nach 30 Jahren ist auch der Standby Trafo meist defekt. Kein Problem wenn man sich damit auskennt.
Die Elkos im Soundweg sind eine Zumutung, auch nach 30 Jahren nicht mehr ok, aber auch das ist problemlos machbar mit dem Lötkolben.
Die Platinen haben gut 4-5 Revisionen, manche sind brüchig wie ein Keks und kaum machbar, echt ein Ärgernis. Frühe Versionen haben Material, das kaum noch lötbar ist…
Oft sind sie in wunderbarem optischen Zustand zu bekommen, manchmal waren sie auch für Hund/Katze der Bieselbaum. Alles schon dagewesen … dann rinnt innen die Soße. Eklig. Aber das gibt’s mit vielen Säulenlautsprechern. Jedenfalls mache ich keine 8000er mit rostigem Standfuß…
Ob Mark 1 oder 2… egal. Beide Versionen kann man auf/umrüsten, Audiophil ist erreichbar, ist halt Arbeit, aber alles problemlos machbar. Dann spielen aber die meisten B&O Sachen in einer völlig anderen Liga… aber eben nicht ab Werk. Zumindest nicht die Hardware von 1970-2000… aber es geht sehr viel damit.
6 December 2022 at 16:28 in reply to: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive #39859Die_Bogener
BRONZE MemberCheck the standby trafo. 2x 18V~
5 December 2022 at 16:53 in reply to: Beolab, Beovox Pentas – Ein Lautsprecher für die Ewigkeit #33973Die_Bogener
BRONZE MemberJa.
Die Schaumstoffsicke ist zwar minimal leichter, sie ist aber steiffer… weil dicker und neu sogar deutlich steiffer. Sie muss quasi erst eingespielt werden und weichgeklopft werden.
Halte mal die Schaumsicke in der Hand, waagrecht… sie bleibt waagrecht stehen. Die Gummisicke dagegen hängt nahezu schlaff runter oder will es zumindest tun.
Wenn man sich auch ansieht, wieviel Hub der Mitteltöner macht… minimal. Das ist kein Tieftöner, dem man zusehen kann und auch mal einen Zentimeter macht. Der Mitteltöner macht bestenfalls mal Zehntel Millimeter, gerade soviel, dass man ihn mit der Hand spüren kann.
Ich habe keinerlei negativen Effekt mit der Gummimembran gehört oder bemerkt. Sie klingen nach wie vor hervorragend…
ÖHMMMM… wenn ich mir die Kleberpanscherei mancher Videos ansehe, gibt es viel mehr zu reklamieren, das oben verlinkte Video ist OK und sogar gut gemacht.
Meistens wird das Chassis kaum bis garnicht gereinigt, es bleiben Mengen an Altmaterial am Rahmen sowie der Membrane dran. Alter Kleber, alter Schaum… es wird nur drübergekleistert und draufgematscht. DAS ist Pfusch… und Pfusch wiegt auch was und hält auch nicht. Das kann man sich dann schenken…
Die technischen Werte der Pentas…??? Hmmm, wenn ich mir die Penta im Original anhöre, höre ich nur einen muffigen großen Lautsprecher der in Bubble Folie eingepackt ist. Dumpf, laut, sehr wenig Höhen.
Also von dem her ist mit Pentas erstaunlich wenig zu wollen. Sich da über Sicken zu unterhalten: das ist pillepalle egal.
Gibt man dagegen der Penta eine Frequenzweiche, die den theoretisch berechneten Werten im Schaltplan entspricht, ändert sich das gewaltig. Die Serienwerte sind mit magnetischen Röderstein Bipolar-Elkos bestückt, Toleranz +50% -20%. Darüber sollte man sich mal unterhalten… das ist 80er Jahre Schrott.
Bestückt man die Penta mit +/-5% Material… ok, wir unterhalten uns da über 300 Euro an Material und nehmen dafür MKT Folien, dann klingt das schon mal völlig anders. Die Folie ist schon mal weg vom Lautsprecher. Gibt dann auch etwas besseres nicht-magnetisches Material, spitzen schon mal die Ohren… da kommt dann was rüber. Das sind dann aber schon 300-500 Euro Material.
Rechnet man dann auch nochmal die Dämpfungswerte der Hoch- und Mitteltöner nach, warum mit magnetischen Draht-Hochlast Widerständen so wenig Klarheit rüberkommt… alles klar. Kann man ja auch mittlerweile induktiv rausmessen, was so ein Widerstand anrichtet.
Jep, und wenn man das richtig gerechnet hat, den Mist rausgelötet hat: dann hat man eine Penta, die sich hören läßt. Audiophil sogar. Dann können wir uns unterhalten über Schaumstoff oder Gummi. Und Gummi ist dann besser 🙂
