Forum Replies Created
16 October 2022 at 17:30 in reply to: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive #39846
Die_Bogener
BRONZE Member16 October 2022 at 17:14 in reply to: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive #39845Die_Bogener
BRONZE MemberCheck this board and the LED board for broken solder pins/pads. Especially the ground pins… and use a magnifying glass… BL8000 have lots of problems with broken pads. More or less ALL active loudspeaker have this problem. Sound is stress to solder pads, it’s mechanical stress and it is just a matter of time and played volume…
… and for the acid foam. Maybe broken lines in the preamp section…
Die_Bogener
BRONZE MemberWhen i remember right: there is a timer function in the drawer motor control.
It is started for around 2 seconds , in -and out, toggled.
It does not detect overload or a position. Just 2 seconds motor on…
I think: typical cap problem in the motor control…
Die_Bogener
BRONZE MemberYou have cleaned the acid of the smd caps?
Die_Bogener
BRONZE MemberTantalum ist very expensive, big and very longliving… 🙂
Tantalum hates spikes, overload and mechanical shocks. But this is here not the problem. Much better than this smd elko crap…
the rubber is done because of mechanical tolerances. The screen rubber will also work, but not so long… silicon screen rubber oxidates faster, but will also work for this.
It is also something like a fuse. Inside the case is a carbon paint for capacitive action. You should check it for cuts and breaks. It can be repaired with silver for windshields.
Die_Bogener
BRONZE MemberCaps make shorts and this depends on the voltage and temperature…
You have heard about “selfhealing caps” with polystyrene caps? Some elko caps do the same … and trick you out. It will happen again.
Die_Bogener
BRONZE MemberMetall oxide or wire resistors dont burn… coal resistors do burn.
Die_Bogener
BRONZE MemberThere are 2 brown caps, the 220uf is prone to fail… yes, with shorts killing the resistor.
Die_Bogener
BRONZE MemberI have repaired dozens of them. It’s always the same. Caps defect.
Especially the SMD ones on the ir unit are the worst ever…
Check the capacity of them very, very exactly. There is a ” .. , ..”
I replaced them with X7R SMD caps … no electrolyth any more…
Die_Bogener
BRONZE MemberThe motor is running as long as the source is tape … playing or stopped, the motor is running.
If source is different to tape, then the motor stops.
Contact… make photo !?!
Die_Bogener
BRONZE MemberWithout load… yes.
It’s a 2-coil transformer, for around 2 x 20V 150mA .
Die_Bogener
BRONZE MemberHmmm, the left one is ok.
The right one is somehow “blocked”, there is a hard stop in the membran. Maybe it was overload or somebody crashed into the loudspeaker.
Does it move by hand?
Die_Bogener
BRONZE MemberYou start a Beogram to play without a record?
Nice, you will destroy the MMC if it continues.
That’s a safety feature.
Die_Bogener
BRONZE MemberA telephone can make this noise when it checks the net connections.
“Bsssss bada bada bada….”
Even a brandnew Overture will show this sound, it was never designed to withstand this emv noise.
Also a computer or router can cause these problem, also some bad LED lights from fareast…
Die_Bogener
BRONZE MemberHmmm… my experience is complete different.
Offering new spare parts in Ebay is more or less a disaster. No interest at all. Now offered for 4 years.
Complete new VX loading gear inclusive cassette loading mechanism… 19,-€ to expensive. 1 sold after 18 month.
VX capstan motor, drive spare parts, new power supplies, revised boards, cabinetts, upgraded power supplies … nothing.
New Beocord motors 30€… nothing.
Stopped. Too expensive…
Instead: people buy a 80€ scrap Overture and want it repaired for even less. Go somewhere else…
But: if a B&O owner loves his equipment and brings it to my workshop in real life… no problem at all. Some of them are driving 600km for this repair and we became close friends for many years, it makes a lot of joy to meet again and to talk about B&O, playing music when the equipment and we were young. And to talk about the next old toy to buy and play with… 🙂
Die_Bogener
BRONZE MemberDie_Bogener
BRONZE MemberBeocord and Beogram do not need any modification, they already work 2-way… they are just telling the master title number or track.
The master can send these data to the MCP and show them. The BM5500 is just compatible with the MCP, not BL7000 or BL5000.
The BM5500 has just a 16K Eprom, the later BM6500/7000 a 64K Eprom. So they are not compatible without modification.
There is/was a BM5500 BL7000 64K file available for an upgrade if modified with a BM6500 cpu.
If you don’t need timer programing: the BL1000 is much better than the Beo4 for the BM5500, easier and faster.
Die_Bogener
BRONZE MemberThe MMCx cartridges sound depends very much on the weight or load. 0,8gramm to 1,5gramm, depending on its construction. You can play with the load…
… or get a good libra.
The RIAA is also important. Some use filter caps on the input side against noise. This is not good. You have a schematic?
Die_Bogener
BRONZE MemberFor music you dont need more than 2 good speakers. Any speaker more makes it worse.
Music and something like Dolby 5.1 is not working. It sounds great some hours and then you notice: there is something wrong. Even if it was recorded in Dolby, you will hear the difference, it just takes some time … and then you will sell it or scrap it.
For TV it doesn’t care, there is no music, just noise… bumbumrattatatabigbadabooom
