Forum Replies Created
chartzBRONZE MemberTrouble is, B&O regularly sent additions to their service manuals. Perhaps this mod was done after one of them, who knows.
chartzBRONZE MemberGood!
Uploading pictures is easy. You can set the size easily here, at bottom right:
chartzBRONZE MemberGood luck and remember, we love pictures here.
chartzBRONZE MemberThere is no quick fix, unfortunately. Check the treble amp, its level trimmer, and the wiring too.
chartzBRONZE MemberNo doubt, the mighty MS-150s.
Then a pair of Pentas, both missing in my collection.
11 October 2022 at 06:07 in reply to: Strategy for Changing Capacitors and Trim Pots on FM Tuner #39361 chartzBRONZE MemberTo me it’s the precision delta too yes. It would a very tiny tolerance in this case!
Found this:
chartzBRONZE MemberBonjour Guy, et bienvenue ?
Sois plus précis : de quoi parle-t-on exactement ?
Je ne vois pas du tout où sont ces résistances.
chartzBRONZE MemberI’d say an erratic bulb perhaps? When it’s on its way out the deck will have the strangest behaviours…
chartzBRONZE MemberHi,
I have yet to find an original stylus that is still good, several decades after they were produced. Don’t expect anything from old cartridges. They just don’t work.
chartzBRONZE MemberGood job. Little things, always ☺️
chartzBRONZE MemberNice book. Unavailable at the moment, unfortunately.
5 October 2022 at 05:35 in reply to: Strategy for Changing Capacitors and Trim Pots on FM Tuner #39359 chartzBRONZE MemberOh good! I read too quickly. All-in-one then. This thing is incredibly cheap. Have fun and share!
4 October 2022 at 20:15 in reply to: Strategy for Changing Capacitors and Trim Pots on FM Tuner #39357 chartzBRONZE MemberOh yes, this was solved and documented!
You’ll need more than an oscilloscope, like a HF generator, a distortion meter…
This is something we have done here for a long time. Since 2009 AFAIC, even if the workbench is not exactly what it used to be.
Always glad that what we have done over the years should still be useful to someone like you!A certain Dillen fellow of this parish is responsible for much of it, by the way! ?????? I for one learnt a lot from him and from a certain M. Jarman about B&O ☺️ (and from many others too obviously).
Jacques
chartzBRONZE MemberI remember I had to replace the IR diode in one of my decks. An easy task, if it comes to that!
This should be in the Workbench, where it’s really at as regards repairs.
Check your connections, and the bulbs, especially the one in the control panel, and if good, check adjustment as per service manual (5-3).
chartzBRONZE MemberI’d say fair. Will do better next time! A bit teck oil and final polishing will finish it off nicely.
There are no corners here. Same with the BM 8000, the plastic pieces take care of the angle, and that makes the task much easier!
The Beogram is more difficult!
There is a special tool for that mind you.
chartzBRONZE MemberFirst trim done.
The old veneer peels off easily when heated with an iron. Then white spirit removes the old glue residue.
Will do the cheeks later!
This Beomaster has now been working for many hours a day for the whole week. No issues noted, and I keep being amazed at how sensitive the tuner section is.
chartzBRONZE MemberIndeed ☺️
