carolpa
Forum Replies Created
Viewing 20 posts - 241 through 260 (of 375 total)
  • in reply to: BEOLINK BEOSOUND MOMENT WITH BEOLINK #46145
    carolpa
    Only, I can’t select the A9 speaker in multiroom from the moment tablet ? I can only use the multiroom with the B&O app.
    this feature has never been available on the Moment.
    if the A9 plays f.e. Music the Link is shown (if both are in the same network) on the Moment. Then by selecting the A9 in the Link page, the Moment joins the A9.
    The opposite: selecting the A9 to join on the Moment tablet is not possible. You need a remote, the app or join manually for the A9, if the Moment is playing something.
    Note: this was normal behaviour when NL was introduced; every device could manually join other NL devices. This was the method for the Moment.
    in reply to: Halo and Theatre? #46288
    carolpa
    the Halo doesn’t control the Theatre?
    not correct, it actually does!
    Schermafbeelding 2023-05-04 190325Schermafbeelding 2023-05-04 190410
    sorry MR10%, I saw your photo’s after I logged in to post mine.
    carolpa
    Beosound/Beolab with AI – a system with its own mind.
    in reply to: Multiroom cutting out after 10 minutes #46112
    carolpa
    When playing records from my Beogram 7000 wired up to my Avant 55 and then over multiroom to my Beosound Balance pair in another room, it works perfectly to start with, but cuts out after about 10 minutes each and every time. Any suggestions for a fix would be most welcome!
    energy saving active?
    in reply to: Beomaster 7000 not responding to Beo4 #45772
    carolpa
    or the Beo4 is set to continuously control a device set in option 4.
    then search for “config” in list of the Beo4 and type “2002” to reset the Beo4 to normal functionality.
    in reply to: beosound moment #45101
    carolpa
    leave the Moment Hub off the Soundheart until it’s battery is drained completely.
    put the Hub back on the Soundheart and follow bnousr 6 steps.
    edited:
    wait some time to let the battery recharge a bit.
    reset the the Hub (see above) with a pin/paperclip.
    in reply to: Will a Beo4 remote work on an old AV9000 TV ? #45240
    carolpa
    strait answer: yes….. but
    you will not have all (additional) functions available with the Beo4 and depending on your Beo4 (with or without joystick) the operation can be different than expected.
    in reply to: Mozart Stereo Pairs #44993
    carolpa
    Morten, I can’t see the version beyond 2.5.3… so I assume it is 2.5.3.131. I do run LC3+. I see it was upgraded fairly recently so maybe the dropouts I recall are from before the upgrade. I’ll keep this in mind. Thanks for the information. Stan
    to see the builds goto the “men” icon in the right above corner, goto chose Support, then Setup overview. Select f.e. the Balance: the sw version complete with build is shown.
    in reply to: BLC Service Manual? #45013
    carolpa
    Apologies but the BLC converter service manual is not in either the old or new manuals library. If your correct membership status is not showing please send Keith a PM asking him to update.
    I have a Dutch BLC service manual…. and I think I downloaded it from this site…..
    So if it is gone lost I can send you a copy.
    in reply to: Three generations of link-system #39251
    carolpa
    If someone really wants to integrate the Beosound 5 to the setup (with ML and NL), the BS/S5 is the way to go. P.S. I have never heard a fan in the BM5 and the box can be hidden away. MM
    But….. if one use a BS5 or a BS5e one can change the source with a remote, to change a Radio Station or an Album (DLNA collection) you still have to physical go to the BS and set the station or Album. Independently if it is linked in NL or ML or Line In connected to a BLC.
    NB: I know there is a Beo6 , I have one. A really nice remote but not really working with a larger collection. With other words IMO not a solution in a NL or ML system.
    in reply to: Three generations of link-system #39247
    carolpa
    @Carolpa Sure, that will work…..has been done with different devices several times. That is pretty easy! But I did not understand that that was meant. ’Adding’ something/the Encore to a BLC should also mean being able to use and control the individual sources (of the Encore) within the NL/ML setup. MM
    Several years ago I tried the usb of both, BLC and BS5e, in search of access to the BS5e. No luck…. presumably or better surely the lack of the correct software.
    the BS5e was and is a very closed system in B&0 terms
    in reply to: Three generations of link-system #39245
    carolpa
    ’….feed an Encore into a BLC’ – that sounds like an interesting project, since the Encore has no ML or alike ?
    quite easy!
    Buy a PL to Line In  cable. Connect the PL of the BS5e Line in to the BLC.
    I connected the BS5e to my BS9000 BLC. Set to volume to approximate 90%, then it works just fine!
    Pity I can not reprogramme the LINE IN to another name.
    I am still under the impression, that originally B&o had the intention to use the BLC as BS5e and NL in between. But it never happened (as with the latest BV7, the Essense mkI)
    @bnousr
    , you’re welcome.
    in reply to: Masterlink setup / NL / 3 devices in the same room #44807
    carolpa
    Here’s the network topography: B&O Network
    just to be precise: the connection BS5 – Beolink Converter NL/ML (BLC) is not a NL (Network Link) connection.
    I would try Stefan’s alternative:
    BS5 – NO AUDIO master
    BS3000 – option 0
    BLC set as V.Master (with connected IR eye if remote is nesessary);  set visible to NL : cd, radio, n.radio, n.music (with IR eye set the IR mapping)
    additional option; but with a total different setup outcome
    Beoplay A6: goto settings/beolink/link to other products; set primary product as BLC
    Beoplay A6: goto “your sources” or “your content” (my settings are in Dutch) / sources/local list; check the sources of the BLC sources.
    Now ALL the BLC sources are an integrated source of the A6. You can start a source on the A6 and JOIN the BLC (then optional stby the A6)
    in reply to: Three generations of link-system #39241
    carolpa
    Kind of interesting having the BS6500 playing using infront of me together with the BL3500 on the wall behind me but yes there is a slight echo but sounds a bit like concert hall effect (then don’t indent to play the speakers on the same time).
    connect the speakers to the BLC instead to get rid of the echo.
    in reply to: Three generations of link-system #39236
    carolpa
    bnousr2.1.001
    this should work.
    remarks:
    -. do not make the source Radio of the BM6500 available to NL
    -. add N.Music as source visible to ML
    -. if one doesn’t use remotes but solomnly the B&o app or Halo the the IR mapping isn’t necessary.
    I do think a two BLC solution is also possible but sharply depends on how the Radio mapping is set.
    in reply to: BV6-26 – use of DVI Socket #44695
    carolpa
    What signal is going out of your PC? Interlaced, as it should be for the BV6, or progressive?
    in reply to: Essence MK2 not connecting to DLNA server #44734
    carolpa
    In my setup, the Essences are in the .30 VLAN and the Synology DNLA server in the .50 VLAN, but there is a route between the two VLANs.
    You have to make the dlna server visible in your .30 vlan otherwise the essences can’t connect.
    in reply to: Beosound Theatre – The quest for rear speakers #44465
    carolpa
    C If I am missing anything I would just love to get a hint or suggestion.
    Be aware that if you PL chain both BL5 and the BL3 you will end having the same channel in one of the BL5 and the BL3!
    That’s the same between the PL of the switch and the BST.
    for 3 speakers connected to the BST you need minimal two PL cables if every speaker should have its own channel playing.
    in reply to: Beosound Theatre – The quest for rear speakers #44456
    carolpa
    What if, if it is possible, PL connect both BL5 directly (eventually chained) to the BST. Make a pre setting “stereo” and switch of all other speakers except the BS5.
    Then use the BST to play your music with the “stereo” pre-set. You could NL connect a BS Core and Join the BST for stereo listening additional (but necessary ??).
    in reply to: Connecting to BM5 with a Mac #43527
    carolpa
    https://support.apple.com/nl-nl/guide/mac-help/mchlp1659/mac
    Did anyone set the correct file sharing on the Mac already? See link..
    if you get the page in dutch – open the dutch page and change “nl” in “en” (twice)
