Forum Replies Created
andy_js
GOLD MemberASE products support at most CD quality (16-bit/44.1Khz) which is enough for Spotify Lossless. If they wanted to add support for it they could probably do it fairly easily.
andy_js
GOLD MemberT.W.G wrote:
Please remove all the AI(?) prompts of your post.
Cleaned…That was markup and it wasn’t visible in the editor. I don’t think the forum is configured properly. If it is this will show up as bold, and this will show up as italic.
andy_js
GOLD MemberI bought a Moment – not that long ago – it really is not a good product – I now use it as a way to play my Amazon Echo Dot through Beolab 4000s! I am about to get a simpler device to do this so the Moment will be relegated to display only! No battery issues at present but I am sure it will do. I share your disdain!
Confess I also have a BV11 – less enamoured with that than you are – remote not easy to use in the dark and the drama turning it on with the Bang & Olufsen coming up before anything happens – confess the other sets in the house are now LG as they just turn on immediately. I have one that works with a B&O stage and is fine. I regret getting rid of the BV5 which still worked fine but connectivity was becoming tricky. Though of course my BC2 does not really connect to the BV11 as not HDMI – only sound.
The speakers are all fine though!
There’s a Quick Start option in the settings on the BV11 which you can use to set a period of time where the TV should be available to start quickly. I think I had it set to between 8am and 12am on mine and it really does make a difference. You won’t see the B&O logo when you turn it on and you’ll still get to see the curtains open. The TV will use more power in standby but it’s probably not worth thinking about. This also makes a big difference when you go to add the TV to a multiroom experience.
11 May 2025 at 19:29 in reply to: End of the road for Deezer? Move to Tidal? It’s all Elon Musk’s fault! #65533andy_js
GOLD MemberMy 1st gen BeoSound 1 and 2 both got updated with Tidal support and it seems to work pretty well. My BeoSound Stage got an update adding Tidal support but it just keeps skipping through the queue without playing anything. I’m grateful to B&O for adding support for Tidal, which they should’ve done much sooner. I just wish they would test their stuff properly, because the only thing worse than not pushing software updates to older products is pushing software updates that introduce new bugs. It seems like the Harmony also got the same update, though I don’t own one of those, and with B&O jacking the prices right up I don’t think I ever will, as much as I might want one.
andy_js
GOLD MemberI think this is more than simply a bad cable, which makes no sense anyway considering that it was working fine before. The first sign of trouble is usually the remote which stops working. This suggests that it’s the ethernet connection between the TV and Stage which isn’t working correctly. I think that’s what the message that appears on the TV is referring to.
With regards to there not being more reports about this, I would guess that only a small percentage of Stage owners are using it with a Beoremote One and a compatible TV. B&O is also known to stagger the rollout of software updates to reduce the blast radius when their QA drops the ball, which seems to happen several of times a year.
I really wish they would leave things alone when they’re working and test their bloody software properly.
andy_js
GOLD MemberI wanted to make a note somewhere of a bug I’ve been running into with the Beosound Stage: it seems that if I turn my TV off using the Beoremote in the evening I’m not able to turn it on again using the remote or the app, but I’ve discovered using the app to put the Beosound Stage into standby seems to get it out of this state, and after that I’m able to control it again using both the remote and the app. Sending the AllStandby command to the Beosound Stage using beoutil also seems to pull it out of this weird state. I will open a ticket with B&O when I get a chance but I have not been impressed with their support so far. They will probably ask for something dumb like a screenshot from the app.
andy_js
GOLD MemberI believe it sits under the Theatre in the line up but I don’t know if it’s something completely new or an update to the Stage. I don’t have a lot of details.
andy_js
GOLD MemberMy guess is that the update is being released in anticipation of the new soundbar.
andy_js
GOLD MemberHere are some screenshots showing a multiroom “experience”:
andy_js
GOLD MemberThat’s probably because the Mozart products use ControlLink instead of the BeoRemote API that the earlier products used.
andy_js
GOLD MemberI have a prototype web frontend for B&O products and I might share some screenshots of if people are interested. It has support for discovering active “experiences” as B&O used to call them, shows the track info and artwork for music, has basic playback controls, and allows you to adjust the volume of each “listener” or product joined to an experience. It’s basic but doesn’t look too bad.
In the course of coding this up I’ve found several bugs in the speakers firmware. The most egregious are:
- Speakers randomly stop producing sound when they finish one track and move to the next one. There doesn’t appear to be any way to detect this, because they still give progress updates and report themselves as not being muted. Adjusting the volume doesn’t help, but pausing the speaker and unpausing it seemed like it did. Because the speakers are moving through the track even though they aren’t producing any sound, you end up missing out on whatever they should’ve played, unless you start the track from the beginning again. This is pretty bad IMO and should never have escaped B&O’s internal QA.
- Speakers suddenly forget they are part of an “experience”. This caused me some serious head scratching and thought for sure I had a bug in my code. I had music playing on my BeoSound Stage and then joined my BeoSound 2 to it, but for some reason only the BeoSound 2 was reporting itself as having an active source (the one playing from the BeoSound Stage), yet both were playing music, something I can easily verify with my own two ears. This also confused B&O’s own app, which showed the BeoSound Stage as having “No source”. Other folks may have seen this as well.
I’m going to file bugs with B&O because this really isn’t good enough, and I’m quite sure these bugs haven’t always been in the firmware of these speakers.
andy_js
GOLD MemberThat wouldn’t surprise me. In my experience B&O products have a lot of software bugs that the app would need to work around if it wanted to provide a consistent user experience on top of them. This could be a quirk of the ML/NL converter that older app versions had special handling for. It’s also possible they broke something in a firmware update without realising it. They don’t seem to test their software properly.
One of my other B&O related coding projects is a piece of software that simulates a BeoSound Moment. It shows up in the B&O app and can be controlled by it, but it doesn’t actually play any music yet. I hacked it up to better understand how beolink multiroom audio works, with the intention of writing a small app for Mac OS that would allow me to join my Mac to audio playing from a BeoSound in another room. If I took that software and combined it with the ML Streamer Tinker Edition (see here https://hallaudio.com/en/produkter/the-ml-collection/ml-streamer-tinker-edition/) it could be used to build a totally open-source ML/NL converter replacement. Support for Airplay, Tidal, etc, could all probably be added as well, providing a nice upgrade over the official ML/NL converter.
andy_js
GOLD MemberTo run beoutil from the current directory you will need to prefix the command with “./” so it ends up looking like “./beoutil”. The dot here refers to the current directory. To run beoutil from ~/go/bin (the tilde here refers to your home directory) you would type “~/go/bin/beoutil”. I recommend the latter because it will work regardless of the current directory. I don’t mind the questions so don’t sweat it.
andy_js
GOLD MemberGo binaries are normally installed into ~/go/bin. Try ~/go/bin/beoutil.
andy_js
GOLD MemberAs ridiculous as the need for it is, I’ve written a utility the you can use to clear the play queue on pre-Mozart products. It’s available here:
andy_js
GOLD MemberPart of the fixes I pushed involved correcting some mistakes in the README file. You should have better luck if you try this:
go install github.com/andy-js/beoutil/beoutil@latest
Or
git clone https://github.com/andy-js/beoutil.git
cd beoutil/beoutil
go installandy_js
GOLD MemberNo problem! I’m glad someone else thinks this utility might be useful. I’ve pushed some fixes that should resolve your problems. Both installation methods should now work.
andy_js
GOLD MemberI wonder if they are getting ready to release an update that allows these to be used in a surround sound setup wirelessly. That might explain why the BeoConnect Core only has one powerlink port.
andy_js
GOLD MemberI’m not fortunate enough to own a pair of Beolab 50 but I have seen a number of bugs in the non-Beta app recently, such as:
– After beginning playback on a speaker the volume bar is empty. Changing the volume on the device itself causes the app to update.
– The playback controls for a device (usually my BeoSound stage) don’t work so I have to use the remote.
The app is certainly better than some of them, but it does not make me feel good as a customer to be finding issues that should have been caught by QA.
andy_js
GOLD MemberI would like to see them produce a new turntable and think that one could be quite profitable for them if they did, but I expect they will release a 100” beovision (for €100,000) and slap themselves on the back for a job well done.
