AdamS
Forum Replies Created
Viewing 5 posts - 161 through 165 (of 165 total)
  • in reply to: Physically SEEING new Bang & Olufsen products #33637
    AdamS
    I do relay on viewing products in the flesh at a local dealer. Many’s the time I’ve looked at a picture of a new item and not been impressed, only to fall in love with it in the flesh!
    in reply to: BeoVox S80: which glue for mid-tone driver repair? #33683
    AdamS
    Surely the ScanSpeak mentioned is the replacement for the later midrange unit with the black dome? The picture above is the earlier unit with the clear dome, which is not the same.
    As an aside, is the ScanSpeak an exact replacement for the later unit? I’m tempted if so as I have another noisy midrange driver on my MS150.2s.
    To the OP – for glue I would just use standard PVA. It allows for easy positioning and will hold the dome in place fine when it sets.
    in reply to: Worst Value for Money B&O Product? #33648
    AdamS
    I have to agree on the Beosound 2 MP3 player. I have one as my wife bought me one as a Christmas present but I have never used it and it’s only ever been out of the box for me to go “oooh” and “aaah” over it. That said, i still can’t quite bring myself to sell it!
    in reply to: What are you working on now? #33325
    AdamS
    Update – I’ve found where the  mystery spring goes. It connects between a peg on the top plate and a metal bracket that is missing!
    What the hell sort of trauma has this 8004 been through?!
    in reply to: What are you working on now? #33324
    AdamS
    I’m fettling a Beocord 8004 currently. The biggest headache has been trying to work out where the mystery leftover spring sitting on my workbench after the belt change came from! At this rate, I’m going to have to pull the mechanism out of my own 8004 and do a side-by-side comparison.
    I’m also trying to acquire two new relays for a Beomaster 8000. RS have had them as “due in stock March 2022” since January, so I’ve been waiting patiently. They duly appeared, I put my order in and the stock went overnight – now showing “due September 2022”.
    Luckily I’ve found them at Digi-Key but had to sneakily order them through work…
