Forum Replies Created
TignumGOLD MemberHoi Martin,
Zie ook deze discussie: https://forum.beoworld.org/forums/topic/3-out-of-4-beolab-8000-not-working-anymore/.
B&O is kennelijk al voor de mk2 met witte foam gestart, check voor de zekerheid je serienummers (of evt je speakers). Als je toch zwarte foam hebt zou ik het meteen (laten) vervangen!
Succes en groet,
Johan
TignumGOLD MemberHello Ruwi,
That can be annoying! I did once replace the fan in a BV6 which helped a lot (they are standard computer fans). The fans are there for a reason I would say.
The BV10 has fan settings in the service menu. The Service Menu is activated in the following way:
The Service Menu must be activated while the TV SETUP menu is displayed.
Beo4: the Service Menu is activated by pressing 0 0 GO within 3 s.
Maybe you can play a bit with the settings. I would take a photograph of the standard settings.
Let us know how you get on!
Regards, Johan
TignumGOLD MemberHello Steven,
Yep that sticky soft-touch finish is nasty now. Some products allow to rub it off with methylated spirit.
Here in the Netherlands the market seems slow: BS4s offered for EUR 175 don’t seem to get sold very fast. Fixing it, or especially, having it fixed before selling does not seem worth it. Maybe offer it on a sales website for pick-up, and an enthusiast could be made happy?
Best of course is, that by roaming around BeoWorld, you get the BeoVirus again and decide to revive and enjoy it! 🙂
Regards,
Johan
TignumGOLD MemberHello Amine, nice speakers. And big!
Often drivers were made specifically for B&O speakers, so finding a substitute with the same characteristics will not be so easy. I reckon finding a donor set (with the aim of making one great set out of two bad ones) is your best bet. Foam & rubber surrounds can be obtained from https://www.repairyourspeakers.com/en/, capacitor kits from https://www.dksoundparts.com/product-category/beovox/beovox-redline-rl140/. Sometimes magnets should be reglued (there are threads in the forum). When becoming a silver or gold member you can get to the service manuals (perhaps the same drivers are used in other RL speakers too?)
Hope this helps (a bit).
Regards,
Johan
TignumGOLD MemberHi, for what is worth: I mainly use the Apple TV 4K to watch content, and have it set to output Dolby Digital 5.1. The LG is set to ‘passthrough’. Works a treat!
Regards, Johan
TignumGOLD MemberHi Ravsted,
Not sure about the shorting, it does not sound logical tbh, as in all pinouts they are kept separate.
FYI I went the other way: I did cut a few DIN-DIN PL cables in two, and crimped RJ45s to the cut ends. Finicky but I hate soldering!
Regards,
Johan
TignumGOLD MemberHello Charlie,
Nice project! I use an LG oled (C9) with the BS3 and I very much like the picture quality of it. The black is really black.
Be aware that the BS3 has no HDMI ARC (audio return channel) capability. If you want to use the HDMI input sockets of the BS3 for audio, your TV must have a normal HDMI OUTput, or it will not work. I think such TVs are rare, if they exist. I use the optical SPDIF output of the LG, converted into coax and feed that into the BS3. You might find a box that strips the audio signal from the TV’s ARC (that your TV for sure will have) and feeds into an HDMI input of the BS3. There are multiple threads about this.
Indeed you will need to connect the BS3 DVI or HDMI output with the TV for menu access, but of course can make use it for your SCART devices. They will not play 4K anyway. I connected an Apple TV to my LG directly for high resolution picture, making my TV the video hub, and the BS3 the audio hub.
For your MasterLink questions I would say that the regular MasterLink (im)possibilities do not change.
When controlled over IR, daily management of the new TV could be done over PUC! Then you will hardly notice you do not have a B&O TV :-).
Regards,
Johan
TignumGOLD MemberHello Michele, great that you are a happy BS3 user too now!
The PowerLink sockets of the BS3 can be used for two of the channels of the surround system: one on pin 3 (normally used for L) and one on pin 5 (normally used for R).
In the menu you will assign a channel to a pin, and it can very well be that you have assigned your Right Front to pin 3 of one of the sockets, and your Left Front to pin 3 of another socket, so both speakers need to be set to L Perfectly normal!
Hope this helps,
Regards, Johan
TignumGOLD MemberOn Netflix there is a series now called Amsterdam Empire. A bit of interaction with BeoLabs going on!
(sorry attached for now as inserting (uploading) fails)
You must be logged in to view attached files.Location: Netherlands
TignumGOLD MemberHi Michael, hi Yann, I happen to have the V2 too. Maybe useful?
I cannot tell what the red wire is.
Good luck!
Johan
TignumGOLD Member TignumGOLD Member TignumGOLD Member TignumGOLD MemberHi, +1 with Ravsted: check this thread too: https://archivedforum2.beoworld.org/forums/t/36445.aspx,
I have a 7-32 stand spare (the 4091 floorstand), but it is in the Netherlands…
I own both stands actually and was curious for the heights.
My BV7-32 stand measures about 87cm (top of the footplate to top of the interface).
My BV10-40 stand measures about 62cm there, with an 8cm gap between footplate and TV.
So using this stand for a 10-40 would actually result in (87-62)+8=33 cm gap! Too much and ugly. Maybe the lower 4092 fits? Or shorten the pole handyman style?
Regards, Johan
22 October 2025 at 16:03 in reply to: Recommendation homecinema setup : BL8000+BL7.2+BL3+sub vs BL9+BL7.2+BL3 #70611 TignumGOLD MemberHello Chema,
I trust the BL9s are better than the 8000s. But I am not so fond of how they look. So my setup has BL8000, BL7-1 & BL2 with a BeoSystem 3. And I enjoy it every day.
Just to make choices harder 😋.
Wishing you wisdom, regards, Johan.
20 October 2025 at 20:42 in reply to: BeoLab 9 – full disassembly to remove sticky soft-touch paint? #70598 TignumGOLD MemberHi, yes I use two in stereo with a BeoLink Converter in my garage. And this (once) 6000 euro ALT sound system sounds good to my ears!
I think I got each of them for 50 or so. Be aware to only feed them left OR right when you want to play two in stereo.
Keep us posted on your BL9 endeavours!
Regards, Johan
18 October 2025 at 14:24 in reply to: BeoLab 9 – full disassembly to remove sticky soft-touch paint? #70569 TignumGOLD MemberHey Joe,
I think the BL3s look fantastic!
I cannot help with information about the BL9s, but in case the ribbed parts are made of aluminium, you could consider to have them powdercoated. I have done that with Beo4s and BL7-4s. Then you can choose various colors and gloss/matt/structured options (and don’t forget to put screws in threaded holes before blasting/coating).
I guess it depends on the color of the fabric and your preference eventually.
See below an image of a 7-4.
Good luck!
Regards, Johan
TignumGOLD Member“2)apart from that I cannot seem to connect to the network.”
Hello Avalon Martin, nice acquisition!
I do not use Beoconnect, and just transfer files to the ‘Music’ folder on the BM5 using my Mac’s possibility to ‘Connect to server’. There i use the BM5’s IP address, username and password (that you can set elsewhere in the menu). I trust a similar option is available on Windows PCs.
Good luck!
Regards, Johan
18 October 2025 at 09:50 in reply to: Beomaster 5 pauses between tracks during HDD/SDD playback #70551 TignumGOLD MemberHello Joris,
Sorry cannot help you here – I don’t own a CD drive for the BS5. Hope others can.
Regards, Johan
TignumGOLD MemberOne more thought Louis, if you end up redoing the frets: when applying new white fabric to a black plastic frame, the black might show through. Perhaps then primer/paint the frames white first.
This is the fabric I used (in black though) to refresh my 8000s https://www.akustikstoff.com/en/Find-Speaker-Cloth/Speaker-Cloth-Standard-White-11::15992.html#horizontalTab4.
Let us know how things develop! White ones look amazing!
Regards,
Johan
