Rolf2
Forum Replies Created
Viewing 7 posts - 121 through 127 (of 127 total)
  • in reply to: B&O Radio Migration Available now #41037
    Rolf2
    GOLD Member
    I just made a search in the B&O app on the word “Christmas” in both TuneIn and B&O Radio.. B&O Radio = 10 hits TuneIn = 31 hits
    Interesting comparison. I did it as well and came up with 33 in TuneIn. In B&O radio I let the search run and received 10 hits. Then I spotted a button on the far right side below the search field named “search for international radio stations” (my, most likely clumsy, translation into english). Pushing it, another 10 hits were available. Of those, 2 were the same as in the previous, most likely “international” search, 8 were different, so I received a total of 18 different hits. What I find funny, in both searches national radio stations were found. It may be that the search success depends on some kind of category the radio station is tagged to?
    Also, I found that if you add another word in front or after “christmas”, you receive additional and different hits, e. g. “christmas rock”. In any case, there are a maximum of ten hits, so the number of search results seems to be restricted but not the number of radio stations?
    Kind regards,
    Rolf
    Favourite Product: BeoSystem 4500
    in reply to: B&O Radio Migration Available now #41033
    Rolf2
    GOLD Member
    I did it and regret it. 80% of the stations I listen to in TuneIn are not in B&O Radio which I am very very unhappy about.
    That ´s unfortunate. I operate an Emerge since a few weeks, my only Mozart based device so far. I found all of my preferred stations in B&O radio. I hope they update your stations soon, you ´re missing a lot. Is the migration reversible?
    Kind regards,
    Rolf
    in reply to: B&O Radio Migration Available now #41032
    Rolf2
    GOLD Member
    Honestly….I’d wait a while. This does not seem to be 100% working yet. I did this a couple of weeks ago (beta update), when it was offered. See this thread: https://forum.beoworld.org/forums/topic/bo-radio-2/ One of my devices however, had not been automaticly updated, so I had to do this manually today. After that I again was prompted to migrate (although I already had done that back then and my other devices were working well with the B&O Radio). The first time I did it, my stations were completely mixed up – I had to delete all and build the list from scratch again. Naive as I am, I thought they had sorted this issue, so I did it once again……….with the same result as the first time. Because the list in the app is global for all (supported) devices, I now have to build the list once again ? So, not saying that one should not do it now. But you should be aware that you may face the same problems and that you maybe will have to spend time recovering the list in the new B&O Radio afterwards. I am very interested in hearing about the experience of other users….maybe this is just so in my case ? MM
    Thank you for Sharing your experience. In my app every single device asks for migration confirmation. In the „beta case“ (thanks for the link) you are displaying that the migration will convert all devices present in the network at once (that´s how I understood it). Do you know, if this is still the case or can be done now device by device?
    Kind regards,
    Rolf
    in reply to: B&O Radio Migration Available now #41031
    Rolf2
    GOLD Member
    I had a update to my Eclipse soundcenter yesterday and went looking for changes. I noticed that B&O Radio was now a source that I can make specific changes to in the B&O App on the Eclipse. When I opened the B&O App on my phone it said I could migrate Tunein sources to B&O Radio but when I try to play a B&O Radio station I get told not supported on the chosen device, the Eclipse. Paul
    Thanks for your information. I noticed that my Eclipse did an update on the Soundcenter but had not looked into it. So I better be careful and wait a little.
    Kind regards,
    Rolf
    in reply to: B&O Radio Migration Available now #41024
    Rolf2
    GOLD Member
    Also available for the Moment!
    in reply to: New Software Edge/Shape/Core/BS1/BS2/A9 (mk3/4) #40347
    Rolf2
    GOLD Member
    For my Essence MK II an update was in the app this evening and it is now on 2.1.50867. I do not know what the update has changed. Although I have the „automatic update“ function enabled, I had to trigger it manually. I will keep an eye on it.
    Beosound 2 updated as described in previous post to 2.1.50871. Emerge is still on 1.8.10017.
    in reply to: BL3 on table stands pls help #35971
    Rolf2
    GOLD Member
    Hi libor,
    I can confirm a total height of 32 cm as Johan has displayed. I have the BL 3 on table stands in our bookshelf. In my case, I was able to build the bookshelf around the speakers :-).
    The round base plate is 6 mm thick and it stands on rubber feet which take appr. 0,5 – 1 mm in height (I cannot measure more accurate, sorry).
    I hope it helps.
    Kind regards,
    Rolf
