Forum Replies Created
RobertBRONZE MemberSTB Brackets have a solution for upgrading the Eclipse MKI to LG C2, C3, and C4:) They have removed it from the shop for now – they write that they are working on a better upgrade together with B&O for the MKI. Good news!
https://www.stbbrackets.co.uk/product/beovision-eclipse-lg-c4-upgrade-adapter/
RobertBRONZE MemberHi,
I checked the voltages yesterday, (Settings -> Sound & BeoLink -> Service -> voltages ), and it looked okay – no red numbers.
The stand is still missing from the Beoremote, the App and inside the menu (setting -> Sound & Beolink)
Tried to unplug the stand from the soundcenter one more time yesterday, and then it works for some time, but wont wake up after one hour or so…
/Robert
Robert
BRONZE MemberThe stand is missing from the menu (setting -> Sound & Beolink)
I havent checked the voltages, will do that later today!
Thanks!
/Robert
Robert
BRONZE MemberHi!
I think its mostly made out of plastic, with a thin layer of aluminum on the outside. Sounds great – very happy with the one i got in black/brass
Robert
BRONZE MemberRobert
BRONZE MemberNor a fake wall. It’s a 122 year old wall that I opened and closed again for the cabels. Here you have pictures:
Robert
BRONZE MemberI’m super happy with my Contour. Picture, sound, looks and user experience is 10/10.
I only use Apple TV, its hidden in a «hole» on the backside of the Stage. That gives me a clean look placed on the wall.
I’m not a tv/movie guy, I use much more time with music, and that is a separate setup (BL18/19) that I don’t want a between.
If I only had one livingroom, then I would have needed a BeoVision with connections for speaker, but for my case, this tv is all I ned….for now:)
Robert
BRONZE MemberMy setup:)
/RobertRobert
BRONZE MemberHi!
Maybe it so simple (and difficult) as speaker placement? The BL20 is a full range speaker, but the lowest frequency may not be possible to hear in your listening position.. Thats the great thing with subwoofers, they can be placed where the bass fills the room (or your listening position) the best. While the speakers is placed for best imaging and stereo seperation.
Just for a test – try to use the subwoofer-trick to place one of your BL20. Place it your listening position and walk around the room and find where the bass is best – then put the speaker at that spot./Robert
