Forum Replies Created
MillemisBRONZE MemberBest consult an installer.
They might have installed one of these recently – maybe they have the spare parts.Location: Flensborg————Danmark
MillemisBRONZE Member MillemisBRONZE MemberCould you maybe describe what you actually have!
Maybe someone else can chime in ?
It is a long time since I dealt with that – do not remember exactly.
I’d have to stand in front of one to recall it.However this is what it looks like, when installed:
MMLocation: Flensborg————Danmark
24 January 2025 at 08:56 in reply to: Speech Intelligibility issue with AppleTV and surround settings 5.1 and 7.1 #63042 MillemisBRONZE MemberI agree regarding the settings of the ATV!
Furthermore please read the article that Geoff Martin wrote years ago on his website.
Here are the main points:
”……you still find that the dialogue is a little hard to understand, and the surrounds are a little hot (this is often the case when your sofa and the surround loudspeakers are all situated against the same wall, you should not be afraid to do the following:
make the centre channel one or two milliseconds early. You can do this by telling your surround processor that it’s about 30 to 60 cm farther away than it really is.
raise the level of the centre channel 1 or 2 dB
drop the level of the surrounds as much as necessary – in my experience, it’s not unusual to have to drop them by as much as 6 dB if you’re against the same wall with them. (Note that, if you have a BeoPlay V1, a BeoVision 11 or a BeoSystem 4, you can do this using the “Fader” adjustment in the Sound menus. This will merely control the relative levels of the Front and Surround / Back loudspeakers – so it’s a one-fader solution to doing it manually for each loudspeaker output.)”MM
20 January 2025 at 11:32 in reply to: After 25 years – My challenges upgrading my B&O Ecosystem #62917 MillemisBRONZE MemberThe Almando products have been discussed here several times throughout the years.
There are mixed reviews….often people returns to a B&O solution (the BS Theatre) after a while.
I would advice to wait for posts with positive reviews for Almando, before purchasing – in the meantime you could search the forums including the old ones.
Personally I am looking forward to the solution from Neomesteren. – the products, that they have up ‘till now, are excellent.
Anyway – it will be very hard to get the integration with projector/screen and tv, that you aim for.
Tv’s are getting bigger and bigger, which leaves less need for B&O to provide this kind of solution.
That said….it might be possible with a great deal of DIY.
Some have used a BeoSystem 4.Running a BS Theatre with a projector/screen solo, however is not a big problem, but you will probably need a professional installer for that.
As for ‘Brodersen timer etc’ – I have no idea…never heard of that.
Finally:
I agree with Peter in his post: “you need to think about what you want to achieve”.Best luck finding the best solution.
18 January 2025 at 22:24 in reply to: Possible to use two ML/NL converters instead of ML cable #62868 MillemisBRONZE MemberHi Johan
Out of interest…….which (audio) sources are you able to use, when at the BV10?
And how do you start these with the Beo4?MM
MillemisBRONZE MemberThat will be hard to beat 😉
MillemisBRONZE MemberYes, that is true!
You simply ‘tell’ the Theatre which speakers are connected and the DSP takes that into account, when you do the setup/the Room Compensation, the Listening Groups…….As for which speakers – this is hard to say, because it depends on your room/placement options, your needs/wishes, your budgets.
The BL4’s can be used, however most people would advice you to stay away from them – they often fail.Height speaker at the back surely are recommended, but only if you also have surrounds…the 18’s is a good choice for this/for surrounds.
Many people would place the 18’s up front, because they primarily want to listen to music from them. Again…it depends on your room and your wishes/needs.
In case you’d place the 18’s as fronts, use any other speakers as surrounds.
An old golden rule is to recomment using the same (type) of speakers for fronts and surrounds.
The heights then can be added along the way – especially, if you are primarily watching movies and/or listening to music in Atmos.MM
MillemisBRONZE MemberEasy to find out
As for delay, please have a look at this older Beoworld thread here
MillemisBRONZE MemberWhy not simply keep the 3200 and connect the WiiM there.
If you dislike the presence of the 3200, go for an Essence MK2, a Beosound Core – they can be hidden away.
Just connect the WiiM to the Line-in there, if you are not pleased with the options, that the Essence/Core offers.These two B&O devices would give you the option of having a (B&O) remote control, by the way.
MillemisBRONZE MemberYou will not be able to turn on the 5’s this way!
A quote from Steve in another related post (there are several, if you search here):
“Unfortunately with Beolab 5 it is not possible to activate the speakers via a voltage trigger – a coded Datalink signal is needed (either via the Powerlink socket or IR remote control) in order to wake the speakers before use.”
MillemisBRONZE MemberI had that too – the post was reactivated after connecting the admins.
Seems to be a bug…..something that automaticly happens.
Maybe the admins should look into that.MM
MillemisBRONZE MemberYou do not need a PL input – you need a PL output to connect the BL9’s to.
Furthermore – if you want the sound from the LG tv – you best buy the new Beosound Core Connect, which has a HDMI/ARC input for the HDMI output labelled ARC/eARC on the tv.
You will not be able to control the tv with a B&O remote (the Beoremote One/BT), however you can control the sources of the Core Connect. Alternatively you could use the Bang &Olufsen app for this.
P.S. You will need adapter cables (RJ45 to DIN-female Powerlink) to connect the BL’s to the Core Connect.
5 January 2025 at 19:37 in reply to: Sad news —— Viggo Kristesen – Bremdal, Denmark – has passed away #62320 MillemisBRONZE MemberYesterday was the funeral ceremony for Viggo.
It started in the main church in Struer with nearly 500 people attending.
Family, friends, running and biking friends, colleagues including former colleagues, current and past employers, neighbours, costumers and business contacts in the crowded church.Thereafter almost all followed the hearse and the 5 service vans of the Bremdal company with the B&O logo and lots and lots of cars drove in a cortege to the shops in Bremdal, past the home of Viggo and his wife and further on to the museum in a former school in Resenstad not far from Struer.
After a couple of hour with lunch and coffee, speaks, anecdotes and friendly conversations at the tables – how did you get to know Viggo and so on? – there was an opportunity to visit the huge collection there.
Amazing what Viggo and his sons have collected there!
Viggo was a lovely, gentle and certainly a diligent, hardworking man.Here is a sneak peak into the rooms of the collection – image all these former classrooms left and right filled with B&O products from the early days on and up till now…..
….and the link to the video, that Steve made there a couple of years ago:
The world largest collection of B&O products in Resenstad near Struer.
MillemisBRONZE MemberI agree – that would actually be a much better idea!
MillemisBRONZE MemberYou will need a normal aux audio signal switcher and the fitting adapter cable/s.
You can get these on Amazon or elsewhere.
You will need one with two inputs and one output.
The output is then connected like you currently do using the 5 pin DIN connector (it is not a Powerlink connector!)Which adapter cables will depend on which aux switcher you get.
Do remember that the turntable will need a phono preamp for that too.
If you are uncertain – and assumed you are in the UK – you could write to Steve/SoundsHeavenly (there is a link on this site).
He will surely be able to help and can provide what you need.MM
MillemisBRONZE MemberI am pretty sure that you will not be able to activate anything/Essence from the linkroom.
But, if you start playback from it directly – using the Beo4 (supposedly there is an ir eye connected) or a Beoremote One/BT respectively the B&O/the Spotify app – you can unmute/play and listen in the linkroom/s.
Looking forwards to your findings!
MillemisBRONZE MemberDitto
M🎅M
MillemisBRONZE Member -
