Forum Replies Created
MillemisBRONZE MemberJust received the notification for the new beta version of the app.
Seems that the reordering issue is fixed = probably soon in the regular app version too.
Play B&O Radio on the headphones……sounds very interesting.
However, I will have to wait to test untill tomorrow….it is late.
MillemisBRONZE MemberOn a side note right now.
I just received the notification for the new beta version of the app.
Haven’t installed it yet – will have to wait untill tomorrow….it is too late for playing ?
Seems to be some goodies there:
MillemisBRONZE MemberIt must be PCM, when it arrives at the BST, since the UHD player is doing the decoding.
How is you speaker setup – 5.1 or 7.1?
MillemisBRONZE MemberAgree with Jaffrey.
The option for reordering the station list should have a high priority for B&O IMO.
Some people prefer the old TuneIN option because of the fiddling with reordering their favourites in B&O Radio.
B&O’s intention for launching B&O Radio was to make things better!MM
MillemisBRONZE MemberIf there is anything we would maybe need, it is the support for DTS HD-MA in the Theatre.
DTS IMAX Enhanced will be limited (I only know of something from Disney+) and that – as Sandyb writes – is only ‘passthrough’ in the coming LG.
Marketing people however, probably will advertise this as ground breaking – a reason for the costumer to buy a new 2023 LG tv.I guess DTS has failed in the marked…….Dolby was first and dominates streaming and cinema.
Friends of physical media stil have and still buy Bluray/UHD, which often contains a DTS HD-MA track – and not every player does the decoding correct.
Anyway – I have little hope for something to change in the Theatre.
Personally I managed to get a player that is DTS HD-MA capable and that is connected directly to the BST.MM
MillemisBRONZE Member@Mr10%
Sorry to say it….I do not agree with you.
That the fronts best be ‘massive’ and the surrounds ‘less’, is only part of an answer.
Thatis however, when you with your setup are focusing on 2 channel content/aka stereo.
If you are someone, who leans more towards watching movies with multichannel sound, the surrounds should ideally – if possible – be equal to the fronts…..we are talking discrete channels for the surrounds nowadays.
That is even more important, if you are into multichannel music (SACD/Bluray/Spacial Audio from Apple Music/Tidal…).Apart from the size of the room it also it depends on what you use as the processor for the sound.
If you use the Theatre with it powerfull speakers built-in, you best place your additional set of speakers as surrounds….in case you have only one set.
For those with the Theatre, who also listen to 2 channel music and not just to movies, best get 2 speakers up front too – if you can afford it, the BL90 or 50.
Unfortunately these are only for the few!So there is no definitive answer to the question – it all depends……
P.S.
At the last AGM in Struer, there was a demo of 5 channel music (from a SACD) in the main listening/test room.
Up front were two BL50’s, as surrounds a set of BL6000, the center channel was the speakers of a BV11……sounded pretty good to me ?MM
MillemisBRONZE MemberBL8000 with BL6000 and the BL7-2 is a classic speaker setup from B&O.
First time the BL8000/6000 was used was with the A/V 9000 system, back then with the dedicated center speaker of the 9000 tv part.
Later on they were used with the various BV7 variants, now with the dedicated 7-4 center speaker…..and even more often with the 7-1/2/6.
Often these are complimented by the sub BL2.These speakers are still used in a lot of homes around the world – they still do an excellent job (when looked after/serviced) and are popular to this day.
You can even buy wooden lamellas for them….to make them look more Beo-modern.You have made a good choice – have fun with your setup.
MillemisBRONZE MemberNo, unfortunately not……..yet!
This was discussed here some time ago and also reported to the support.
As of now it is a pia to ‘reorder’ your stations or add a new station to a specific place in the list.
We must hope that they get this sorted out soon.MM
MillemisBRONZE Member MillemisBRONZE MemberNo, it is not 2-way in that sense.
However, it receives the information from your Core, how this is setup….you might say it is then taylor made for the Core.
As an example, you can see the favourites you have made for the B&O Radio and choose a specific station from the list.MM
MillemisBRONZE MemberI am also still on the initial Theatre SW (and not on beta).
You write about the LG update.
It was offered today to me too, however I thanked no, since we just sat down to watch a movie.
What is in that update – something worth mentioning for a Theatre owner?MM
MillemisBRONZE MemberOk – since your 3200 seems to be locked in to the cabinet, take that out of the mix (disconnect that from the mains – you don’t really neeed that and it has no speakers of its own).
Make the BS4 the Audiomaster – Option 2
and the BV5 (with all the speakers) the Videomaster – Option 2
This way you can access the DAB+ and the connected APE from everywhere (apart from the bedroom, of course) including from the BV5.MM
MillemisBRONZE MemberI am afraid noone here can answer that question!
Why would you get a better discount now than in 2-3 months?
MillemisBRONZE Member1. You should use that option, yes.
2. Not 100% sure, haven’t tested that – but I’d say, yes it switches on with the incoming signal.
3. (If I understand your question right) sure, that is how it is supposed to work – but you will need an adapter PL/RJ45 to PL/DIN.MM
MillemisBRONZE MemberI’d ask my dealer anyway.
This is not supposed to be so, even after garantie.
How old is it – has you had any fluid spilled on it or so?Also, you could buy a new insert/inlay and reuse the housing, if you don’t have success with glue.
MillemisBRONZE MemberI’d put the BV5 in Option 2 and the 3200 in Option 0 – all speakers connected to the tv…..means an integrated setup.
(Move the Airport Express to the 3200).
The BS4 should then be in Option 6 (= act as a link product) – you can only have one Audiomaster respectively one Videomaster in a setup.Even if you would want to make changes in that room, it should be worth it to try that out before.
MillemisBRONZE MemberKnown issue – please contact your dealer
Start at 5:00
MillemisBRONZE MemberThe BS3000 should support Option 6.
Read about that here on page 9:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SOUND_SYSTEMS/BEOSOUND_3000/BS3000_RB_EN.pdf
N.B. Reading your plan, the 3000 does not seem to be masterlinked!Some of the linkroom devices might not support (and respond to) the A.Aux command – this depends on the SW version.
Why would you want to get rid of the audiomaster/the BS4?
Adding a NL/ML Converter brings the additional sources from a NL device (which you would also need).
These can be played via the BS4.How are your BV’s option programmed – the BV5?
You can not upgrade the BV5 – best buy a BV10 (be sure to have this updated with the PUC’s for the devices, you want to add, before you install it).
You might also get the BV11, if you are serious about installing the NL/ML Converter.N.B.
You are very lucky to have a plan of the setup!
Many B&O setups in old houses are not or not well documented…….which makes it very difficult to give advice.P.S.
If you want to know more about, how a NL/ML Converter works/the different setups etc, have a look here:https://cdn.webshopapp.com/shops/98396/files/334286248/beolink-converter-nlml-ver-14-beomac.pdf
MillemisBRONZE MemberI would look for a later software version (or latest SW, like Carolpa’s) if I was looking for a BS3000, rather than worrying about clamper size. Obviously the earlier ‘small clamper’ versions are more likely to have earlier software, unless they have been updated. If you search BS3000 on UK eBay they often show photos of the labels so you can get a good idea of Type Numbers, SW versions and clamper size.
I bought it then for two reasons 1) option 5 & 6 available and 2) N.Music & N.Radio accessible. ter info: now it is integrated in NL through a BLC.
That is what I would buy…..if I needed yet another ML audiomaster ?
MillemisBRONZE MemberDavid Crosby – thanks for all the music – RIP.
