Millemis
Forum Replies Created
Viewing 20 posts - 521 through 540 (of 1,252 total)
  • Millemis
    I am not aware that the WiiM can distribute the line-in signal via Airplay.
    Are you sure of that?
    As far as I know it is a AP receiver.
    It can distribute sound to other WiiM devices
    But then you would require a WiiM device connected to the BL6000’s….instead of an APE.
    Please correct me if I am wrong!
    in reply to: Beolab 8 review video #49957
    Millemis
    in reply to: Beolab 8 review video #49948
    Millemis
    I did that at some point with my (then) Avant 1st gen….just for fun.
    But switched back to using my surrounds again.
    People should not be shy of trying out things – no harm done, you can always return to what you had before.
    P.S.
    The BST as the ‘motor’ has made experimenting much easier.
    For instance I have ‘the triangle’ as one of my listening positions…..mostly for demonstrating for friends how well that works.
    IMG_0731
    in reply to: Beolab 7.x vs 6000 #50050
    Millemis
    Google search yields no results.
    Here they are:
    in reply to: Beolab 7.x vs 6000 #50049
    Millemis
    Specs aside – maybe these two videos from Steve@SoundsHeavenly can help.
    in reply to: Beolab 7.x vs 6000 #50045
    Millemis
    I understand that you want to get the sound from a tv – but how do you plan to connect those Beolabs?
    in reply to: Bang & Olufsen App – Beta version 5.x.x. #49165
    Millemis
    ….turn off automatic updates!!
    Sure you can turn off the auto update of the beta, but only untill the older ones expires.
    How do you turn off auto updates of the regular app is the more important thing – should you be lucky enough to have a device with a running 5.3.
    From the settings/iOS
    in reply to: Bang & Olufsen App – Beta version 5.x.x. #49164
    Millemis
    It seems that they are either totally ignoring the users with older gear (through the converter) in their setup…..
    ……or they are letting us wait and wait for something to change.
    I think it is time for them to tell us where they are heading.
    in reply to: Beocord 7000 doesn’t like the Beolink 1000 #50005
    Millemis
    Alright then….it is just the cassette deck that does not work using the remote!
    Millemis
    Are you sure, that the 7.6 is connected to it’s own powerlink socket called Centre 1.
    in reply to: Beocord 7000 doesn’t like the Beolink 1000 #50000
    Millemis
    1: The remote is faulty (did you check the batteries?)
    Try another remote!
    2: The Beomaster is set to Option 0 – in which case it shall not respond to the commands of the remote.
    3: The ir sensor/the ir circuit of the Beomaster is faulty.
    Must be looked after by a service person (if you can not yourself).
    in reply to: Beolab 8 review video #49939
    Millemis
    Thank you, Steve!
    in reply to: Do you know this Beostand? #49966
    Millemis
    Deleted
    in reply to: Avant 55 Over the Air Antenna #49963
    Millemis
    I would like to know how to install an over the air antenna to my Avant 55, since it does not have a coaxial input. Also, I can’t find a selection for antenna in any of the menu options.
    Could it be that your Avant is a no-tuner version?
    in reply to: What are you listening to…..right now. #33209
    Millemis
    Pealed and opened….
    IMG_0727
    Listened and enjoyed what I was hearing.
    in reply to: Bang & Olufsen App – Beta version 5.x.x. #49160
    Millemis
    Unless the testflight 5.3 should be delayed (which I do not think will happen), the only way to keep the (regular) 5.3 will be to use an older iDevice (pre iOS14).
    It seems that the 5.4 version requires a later iOS version.
    in reply to: Bang & Olufsen App – Beta version 5.x.x. #49157
    Millemis
    Hi Tim
    Yes this a mess – I too downgraded to the previous Testflight version (5.3).
    But you should know that that version only is accessable 31 days from now on.
    After that they have either massively improved the then Testflight version or the regular….or we are left with a cripled app.
    P.S.
    You will have to switch to the Radio tab at the buttom in order to change to radio, when already using the BST……which is rather ? an unnessesary step.
    in reply to: Beovision 11 mit AppleTV4K #49896
    Millemis
    Wer nicht unbedingt ein Apple-user ist – und nix gegen Google hat – könnte die Google TV dongle benutzen.
    Die hat auch eine Bedienungsoberfläche mit Apps wie ATV.
    Allerdings gibt es hier keine möglichkeit mittels PUC das ganze mit der Beoremote zu steuern – die mitgelieferte Remote is unumgänglich.
    Sonst kenne ich nichts in der Grösse.
    Es bliebe dann nur die frühere/deine jetzige Version vom AppleTV und Airplaying von einem iPhone/iPad mit den entsprechenden Apps installiert.
    Aber wenn der BV an der Wand ist, brauch man ja die Abdeckung nicht zu montieren (dann müsste es ja gehen)….es sei denn der Fernseher wird (weit) von der Wand gedreht, wenn in Betrieb.
    in reply to: How to add stations to B&O Radio #49904
    Millemis
    Sirs, cool down please ? MM, how to “ask” B&O to add a station? Yann.
    Never tried, but I would try to contact the Costumer Service….or let my dealer do so.
    Others have tried – so maybe just wait for a better answer here.
    in reply to: How to add stations to B&O Radio #49902
    Millemis
    @trackbeo
    Whatever you think…
    Bang & Olufsen Radio is a service provided by B&O for the devices they sell……not some kind of free-for-all-self-service.
