Forum Replies Created
Mark-sfBRONZE MemberTo do a fair comparison I would still connect the 3500 directly to the 28s.
Mark-sfBRONZE MemberYou likely have a shorted transistor in the On portion of the electronic sw. Check TR13 if I remember correctly. There is also a companion on the muting board for the remote.
Mark-sfBRONZE MemberFirst, which RIAA preamp are you using? I would definitely try a direct connection to the line in of your BL28’s bypassing the Moment.
Mark-sfBRONZE MemberYes that is what I meant. I do see that Martin has an 8002 Cap kit at https://www.beoparts-shop.com/product/capacitor-kit-beogram-6006-8000-8002/. I have gotten parts quickly from him in the US.
Mark-sfBRONZE MemberYou can’t get a “set”. You need to get a cap kit that includes all the values you need. These kits are available on Amazon, DigiKey, Mouser, etc. Only do the electrolytics (the cylindrical ones) first as they are the most likely culprits. Don’t forget the 47mF on the CPU board.
Mark-sfBRONZE MemberI doubt its the motor as its on the right as is the transformer. My suggestion would be to open the unit per the manual at https://beo.zone/media/files/Bang-Olufsen-Beogram_CD-5500-Service-Manual.pdf and identify the specific component generating heat.
Mark-sfBRONZE MemberNo I did not check this because there is audio on the speaker pin. I would expect that an issue with the muting relay would prevent audio from passing to the speaker port. As far as I can see it is much earlier in the signal processing? When I trace the audio there is a signal on the output pin of the speaker port. This signal dissapears when I attach a load (speaker) to the port. I can’t see any damage on the port, there are no shorts on the pins. Voltage of 4.5v on the pin for the dataline seems correct.
By your earlier statement the Rt Spkr Jack (P91) works so there is no other likely failure than the relay. Anything eariler shares the audio path with P91. Datalink is not involved in the audio path.
Mark-sfBRONZE MemberI’m not sure what that circuit board’s function is as it’s markings and wiring could indicate that it is on the power amp outputs. You definitely have a defective left channel if it is reading 24v. That is also the channel associated with the R101 that you replaced. Fix the left channel first and you may find that the right channel no longer makes noise.
Mark-sfBRONZE MemberThe transport screws are not used to adjust the leveling and do not come out so they are not likely stripped. The screws to level are under the platter. Take a look at the service manual at https://beomanuals.com/manuals/Beogram/Beogram%205500/Beogram_5500-Service_Manual-version2.pdf for instructions.
Mark-sfBRONZE MemberAre you certain it was R201 3.3K ohms that was burned? I ask because that is a series input resister to the power amp IC and i can’t see it getting the current to “blow” it. If that is the resister, could it have been cracked instead? As to the noise can you describe its character. Can you check if you are getting a DC voltage on the output with the speakers disconnected?
Mark-sfBRONZE MemberThose were power darlington transistors. You can use BDX33A and BDX34A to replace them.
Mark-sfBRONZE MemberI would check the 12v supply. You may have bad caps at C3 or C4. Make sure you have a clean 12v at the solenoid. TR6 regulates the voltage to 5v for the motor so it would not cause this issue. There may be 120Hz noise on the 12v line.
Mark-sfBRONZE MemberBased upon Beolover’s sample, that separation was caused by force. Note that there is thin film residue to the old bond indicating that a shear force will likely be more successful than heat softening. This would call for a non-marring mallet with the platter supported thru the center hole. You could also try a .1mm stainless steel spudger to work around the edge to break the bond.
Mark-sfBRONZE MemberI would not try as the two pieces are bonded. Applying heat to relax the bond would damage the ribs.
Mark-sfBRONZE MemberChristian, I’m afraid the 8002 had a different bearing yet again as it was a different drive system.
Mark-sfBRONZE MemberI believe the confusion is due to the 4002 having two different bearings. The earlier 5503 types had the platter from the 4000 which had a ball and thrust pad. Yours is the later one which had a lighter but larger black subplatter and only used a centered point. In any case, there does not appear to be anything missing.
30 May 2022 at 18:04 in reply to: Beolab 4000 vs Beovox CX 100 – which one is the better solution? #35166 Mark-sfBRONZE MemberAre you sure about the models you are comparing? The CX100 is a passive speaker and the 4000 is active.
Mark-sfBRONZE MemberHope your son appreciates it!
Mark-sfBRONZE MemberI would check the 7V power supply section around TR19 and C10. If the fuse that was bad was T1A for the 5v supply there may be and issue with IC4 circuit or its zener.
Mark-sfBRONZE MemberI don’t know what you mean by “servo noise”. If you mean 120hz buzz then it’s likely a power supply cap problem. As for the 45 sod are you seeing a variable freq on pin 1?
