Mark-sf
Forum Replies Created
Viewing 20 posts - 341 through 360 (of 463 total)
  • in reply to: beogram8000 won’t turn on #40955
    Mark-sf
    The high voltage on the 5V+ sounds to me like its not being normally loaded as the 6.2V zener at D20 is setting its max. This is reinforced by your previous report of 5.06V output. I would definitely start by examining its fanout presence to its loads.
    in reply to: static/popping even when not playing #41117
    Mark-sf
    What do you mean by “physical movement around the turntable”?
    in reply to: static/popping even when not playing #41115
    Mark-sf
    In addition to the muting switch, you may have a DC offset issue with your phono section. Is the piping only in one channel or both?
    in reply to: BeoGram 4000 tone arm problem… #40689
    Mark-sf
    First I would loosen the set screw in the black endcap to release trapped air. If that doesnt help then applying a penetrating oil/WD40 and leeting it soak should free it.
    in reply to: BeoGram 5500 arm adjustment #40539
    Mark-sf
    To address this you need to upload a picture that actually shows the arm skew you are referring to. It’s not clear whether both arms are skewed or just the tonearm. The arm movement adjustment only governs the perpendicularity of the arm to the grove as it plays the record and is not a factor when the arm is cued up.
    in reply to: Beogram 6000 #40757
    Mark-sf
    While I don’t have any 6000 leads, you can also look for a 4002 with an MMC6000 cartridge and a CD4 board. You probably have a better chance. However, your biggest issue will be finding a functioning cartridge. Soundsmith can retip them though at $600 is not cheap.
    in reply to: Beogram 2000 motor (1983 – 1987) #40498
    Mark-sf
    You only need to desolder the two larger pads at 12 and 6 o’clock.
    in reply to: Beogram 4002 Tracking Force Adjustment #40562
    Mark-sf
    If you need to lubricate, remove the dustcover and then the tonearm cover can be lifted straight up to gain access the dial and gear. At that point you can check the balance of the arm and the rear counterweight adjustment. You should not need to track at 1.2g. Sometimes the arm cover can get pushed so that it binds the arm. Its height should allow the screw to be centered and the arm to move freely when lowered.
    in reply to: Beogram 5500 DIN connector #40510
    Mark-sf
    The extra pins in the 7-pin one carry the Datalink signal to Beomaster receivers for remote control. The pins can be unscrewed to use with a DIN-RCA adaptor.
    in reply to: beocenter 2200 Driver belt installation #40340
    Mark-sf
    The platter lifts off to replace the drive belt. You need the right one which is available from beoparts.com.
    in reply to: beogram 5500 turntable repair, gear disassembly? #39792
    Mark-sf
    It’s easiest to remove the power supply whole as it’s carrier is secured with screws from the bottom.
    in reply to: beogram 5500 turntable repair, gear disassembly? #39787
    Mark-sf
    It appears you are not getting DC voltage from the regulator on PC Bd #2. I would disconnect  connector P3 and measure the DC voltage on the input and output of the regulator, IC1. Either C3 or C4 could be a problem but id the fuse is not blowing, I would expect the regulator has opened. It’s not likely the solenoid unless you hear it activate when simply plugging in the power cord. Then either TR4 or 5 could be shorted.
    in reply to: beogram 5500 turntable repair, gear disassembly? #39783
    Mark-sf
    If you are getting 12v at the anode of D1 then pressing Play should cause pin 10 to go high and turn it on. Please confirm you see 5v on that pin.
    in reply to: Beomaster 1700 #39957
    Mark-sf
    You should also reflow the connector’s solder joints as these are notorious for developing fractured connections.
    in reply to: Beogram 4004 (Type 5526) Issues #39878
    Mark-sf
    Thanks for the video. Some of what you are observing is normal. For example, the 33 button record clean function ONLY works when the arm has not left its home position. Also, the single arrow buttons do NOT work until the tonearm has left the home position. Finally, the >> and << and >> do not need to be held down.
    The two major problems I see are the following:
    1. The return servo motor direction is not functional as it should not only engage when you press and hold > or press >> but also when it gets to the center endpoint.
    2. Your solenoid is engaging but not holding as it’s there to keep the tonearm lowered. This means that there is an insufficient voltage on the coil when it switches to its “hold” mode.
    These are likely independent, and you have multiple issues. Go back to the servo motor circuit for #1 and the Solenoid circuit made up of TR9,10 and IC4 and its caps.
    in reply to: Beomaster 1700 #39952
    Mark-sf
    Quite frankly as long as the female connector is also clean, I would not worry about it coming back. You likely didn’t have rust but oxidation and the connections should be fine.
    in reply to: Beomaster 1400 buttons #39946
    Mark-sf
    You will need to open the top and remove the front panel as if I remember the switch assemblies are board mounted. Once you have access, you can see what is hanging up the interlock mechanism.
    in reply to: Beogram 4004 (Type 5526) Issues #39874
    Mark-sf
    Yes it is.
    in reply to: Help with Beogram 59XX resistor replacement #39898
    Mark-sf
    Diodes like transistors typically cannot be measured without being removed as you are measuring resistance of their circuit.
    in reply to: Repaint Beolab 4000’s #39890
    Mark-sf
    When I have painted aluminum I’ve used a self-etching primer. However, you obviously are going to need to remove the old paint first which may need to be sanded. Given the dings, that’s probably required along with a filler If you have a paint booth for your air sprayer that’s how I’d try. Nice DIY project if you take your time.
