Mark-sf
Forum Replies Created
Viewing 20 posts - 301 through 320 (of 463 total)
  • in reply to: Beogram with Excess Static #43701
    Mark-sf
    I am not familiar with SoundDesign B&O cartridges. Could you mean SoundSmith? Record static (that is electrostatic attraction to vinyl) is usually caused by dry environments. A Zerostat can help mitigate it when cleaning the record. If by static, you are instead meaning electrical noise thru your speakers, that is something entirely different and can be confirmed by its random nature. Finally, if you are referring to pops and ticks from your records that occur at the same points during playback, these are either defects or foreign matter in the grooves that may be cleaned using ultrasonic techniques. If you good clarify the above we could help further.
    in reply to: Replacement Beogram power and signal cables #43706
    Mark-sf
    Christian, you should realize that the 4000c has a line-level output since it has a built-in phono pre-amp versus a phono one in your 4000/4002. Therefore the screening and grounding are of more importance on yours. It is highly unlikely that Sound Heavenly manufactures their own wire but buys it in bulk from a supplier. What is it about the 4000sc’s wiring that you find desirable?  I have custom-wired several hundred Beogram 4000x’s in my time so could provide guidance if you’d like.
    Mark-sf
    That adjustment is your azimuth and really cannot be done visually. A static measurement assumes the diamond and cantilever is perfectly orthogonal to the record surface which is seldom true. Unless you have a measurement capability to check for optimum channel separation using a test record, you should not try to fine-tune this adjustment.
    in reply to: BG 5500 Arm string ankers broken #43614
    Mark-sf
    Check out the service manual either here as a Silver Member or at beomanuals.com. You need to open it from the top and you can find the endpoints on the large pulley and near the left of the tonearm base illustrated in the manual.
    Mark-sf
    In reality, dynamic speakers are only nominally 4 or 8  ohms. They vary their impedance with frequency. A manufacturer rates an amp’s power into a load. Therefore as the load goes from 8 to 4 an amp must deliver more current to support the voltage needed to drive the speaker. If the amp cannot its voltage will drop which reduces its watts. This just means if both an 8 and 4 ohm pair had the same sensitivity you could play the 8 ohm louder. Both will still work. Simply turn the volume down if you hear distortion from any speaker regardless of its rating.
    in reply to: Should I Spend 75$? #43586
    Mark-sf
    Can’t really comment on it without more details. However, for $75 it’s a steal no matter its condition. It will likely need an overhaul but there are plenty of parts such as belts, relays, caps, fuses, etc available.
    in reply to: Beogram 4000 Tonearm and Sound #43474
    Mark-sf
    Welcome. It’s great you are trying to assist her. It appears she has a 3000 not a 4000. There are adjustments for both set down point and tracking force described in the service manual available online. I would first check on how clean the stylus is. That can be done with a magnifying glass. How comfortable are you with taking things apart and putting them back?
    in reply to: Stylus and cartridge for Beocenter 2000? #41489
    Mark-sf
    Yes the E will work fine and trace better since it’s an elliptical shape versus the spherical of the S.
    in reply to: Beogram 6002/8002/TX etc. platter issue #42866
    Mark-sf
    Its conductivity is not functional since it’s used optically to be non-reflective for record edge detection.
    Mark-sf
    You need to adjust your speed as well.
    in reply to: Which BeoGram for my Beosound 5 ? #43425
    Mark-sf
    You need a Beogram with a built in preamp. See https://beoworld.org/article_view.asp?id=67 for a list.
    in reply to: Arm on Beogram 5000 worn’t move down #43402
    Mark-sf
    The easiest first check is to make sure your counterweight has not moved. Is the arm able to go down by adding more tracking force?
    in reply to: Beogram 4002 – should I replace the capacitors #43351
    Mark-sf
    Welcome to the forum! You can find the service manual online which describes testing for the detection signal. If you are not comfortable with soldering and desoldering I would fine someone that is. While replacing caps and relays is called for as a general restoration strategy nothing is harmed to wait for a failure if it’s working fine. You can even live with the detection issue if it’s not simply an adjustment.
    in reply to: Beogram 6002/8002/TX etc. platter issue #42864
    Mark-sf
    That paint is not conductive as it only needs to be non-reflective. I don’t have a specific recommendation as B&O never published this to my knowledge.
    in reply to: beogram options #43342
    Mark-sf
    A Beogram 1900 would be a less expensive option and still have the squared form factor and matching finish.
    in reply to: problème son #43254
    Mark-sf
    Welcome! Your problem is likely the amp and not the turnable. Which amp do you have the speakers plugged into? Can you describe the nature of the noise (hum, hiss, thumps, etc)? Does it have a headphone jack you can try? If so do you hear the same noise?
    in reply to: Beogram for BeoMaster #42883
    Mark-sf
    Dave, my recommendation regarding Sound-Smith was only for re-tipping the cartridge. Your other answers indicate the presence of potentially more than one problem. In your original post you stated that it stopped moving last week. Was it in regular use up to that point or had it been unused for a significant period of time? Before recommending a repair approach, since you’ve already been inside:
    1. Do you have a VOM?
    2. Do you have any soldering/desoldering experience or skills?
    3. Have you ever used a circuit diagram?
    If the above answer are all no, then your best bet would be 3rd-party repair. The Service Manual is online and it does not need to be repaired by a B&O service shop. Any reputable audio equipment technician should be able to fix this and they could even post here for guidance. However, you need to decide whether the cost of a re-tip plus such a repair is worth it to you versus selling it “for parts or repair” online? In yours condition they still go for $200-$300 assuming its cosmetic shape is good..
    in reply to: RX2 Tonearm issue #42858
    Mark-sf
    The hardest part of a B&O repair is taking it apart so it goes back together!
    Mark-sf
    If putting such a weight on it is not disrupting its suspension and belt running location, then its suspension height is not correctly adjusted.  Such a weight requires readjustment to compensate. Non-suspended turntables such as direct drives do not have this requirement.  The WFGUI with a test record and the DIN filter should better reflect the true performance. If you get a good belt and everything is adjusted properly and still seeing W/F>.2 then I would suspect the motor bearings may need a new oill suffusion or replacment.
    Mark-sf
    First you should note that your phone is heavy relative to a record and this will negatively impact the WF test on most beograms due to their lightweight construction, floating suspension and low torque. To use that app you need to readjust the suspension so it’s free and level when the phone is centered over the spindle and that the belt is centered on the pulley and platter. You should also also make sure the motor pulley and platter edge are clean. Finally, unless you got the belt from a legitimate B&O parts site, I would suspect it.
