Forum Replies Created
Madskp
GOLD MemberGreat to hear that you finally got a working solution for this, although a complicated one 🙂
I also connected a Chromecast Audio to the TV/Aux input of the BM7000, so that if I do select A.Aux by remote, both the BS4 and the BM7000 go to A.Aux as a source and I can cast music from my phone or tablet. The BM7000 has therefore also allowed me to add an extra source too.
But how are the A.aux command mapped in this situation? Or is that not going through the NL/ML converter?
My Beomaster 5 remains connected (set as an audio slave) and it does not seem to have been adversely affected – it still responds to the N.Music command from my remotes.
But what about N.radio? Is the BS5 not responding when you use that for the redcord player scenario?
I’m guessing that means that the N.Radio signal from a Beoremote One is different somehow?
Yes something must be different, although I cannot say what that could be.
Madskp
GOLD MemberDisregard – I solved it, but I don’t know how. I disconnected everything, reconnected everything, changed a few settings, and I’m pretty sure I ended up with the same as I started with, but now it’s working! Maybe I just had a loose connection somwhwre.
Then nevermind my comments. But I would be interesting to hear the settings you did to achive this?
Madskp
GOLD MemberIf I should guess you are trying to get the BS4 Aux input activated with the PHONO/N.RADIO command by trying to change the command in the NL/ML converter?
Good thinking, but I am not sure that it is possible. If I understand the manual for the NL/ML converter correctly the IR mapping features is for choosing which source name a ML source should have on the NL network:
Not sure if that also applies for the Converter IR eye too. Others might know better. I can also try to test it at one point, but it might take some days before I have the possibility to do so.Just to be sure what you are doing:– What role have you setup the NL/ML converter to have?– Is the IR mapping setting you are mentioning like this:Location: Denmark
Madskp
GOLD MemberYou are welcome, and great that it worked.
Btw. you mentioned in your first post that you had to press link CD on the remote to get the CD playing. Can you do that by pressing just CD now?
Madskp
GOLD MemberI have now tried to test with the Beoplay M3 instead of the Beoplay V1, and with Both the BC2 and BS Ouverture I can get the Beoplay M3 to start playing. The sound is for some reason very bad (it works great when I do airplay), but the functionality is there.
Only thing I changes was to make the Beoplay M3 the primary and secondary product to connect to in the NL/ML converter setup.
Please let me know if this calls for any other testing scenarios
Madskp
GOLD MemberI have now tried the same test with my Beocenter 2. At first it did not work. I could start it from the Beoplay V1 and control it, but if I used the buttons on the BC2 it could not start the TV. Later I found out that was because I had speakers connected to the BC2. When I disconnected them I could start the Beoplay V1 TV by pressing the DISC button on the BC2.
In my previously testing with the BS Ouverture there was speakers connected to that, but that did not seem to matter for this functionality, so there might be some differences in how different systems do this feature.
I also checked settings on the TV again, and I am not sure if this is something I have set manually, or if it wast automatically set based on the settings in the NL/ML converter, so here goes (disclamer my menu language is Danish, so translation might be different with english menus):
In the menu Product integration ->Connect to other products
Product 1: Beolink Converter NL/ML
Speakers to: Beolink Converter NL/ML
If this has to be set manually it might make a difference in behaviour
BS7000 – BLC – NL : start cd with button on BG CD7000 – NL source doesn’t start this evening (but I’m not sure this was the same before I powered everything down this afternoon, but forgot the Beosystem 7000 and the T1611
Do you have a Powerlink cable between the Beomaster 7000 and the T1611 along with the 7 pin DIN cable? That is required for buttons on the music system to control connected Video Master in ML systems.
And for your setup that might be the problem since this feature is from the ML world where it would activate the TV in the setup. But you connect to a music systems (the Core) in the NL world. Not sure if this has impact when the NL/ML converter is translating. I will try later to see if I can do the same with my Beoplay M3.
Madskp
GOLD MemberYes it is. You will have to use the connectors marked Powerlink and connect to the speakers with Powerlink cables
Madskp
GOLD MemberI have just tried now with Besound Ouverture (A.opt. 0) – NL/ML converter – Beoplay V1 (V.opt. 2)
The setup of the NL/ML converter is as follows:
Pressing CD on the BS Ouverture starts the Beoplay V1 and the music is playing through it’s speakers. So it works, at least with the Ouverture.
I have quick start timers activated on the Beoplay V1, not sure if that makes any difference, but just for the full picture.
I might be able to do some more testing later in the week with other music system, and also with a Beoplay M3 as the NL source to see if that works just as well.
Madskp
GOLD MemberWhen using just an ML connection there is no ‘speaker on’ signal that I am aware of, but you would think that the ‘data’ connection would cover this requirement.
I have not tried this with a Masterlink music system, so agree that it could function in another way. I can try to do a test later thisweek with my BS Ouverture and/or my Beocenter 2 to see if they can activate the Beoplay V1 via the NL/ML converter
8 September 2025 at 15:47 in reply to: Beocenter 1 with Suspicious Display and IR Board (PCB58) #69479Madskp
GOLD MemberYes very good to know what the issue was. Thanks for getting back as that can be usefull for the next person having this issue 🙂
One more of these detoriation of materials issues to the list of rubber belts, speaker foam and what have you.
This kind of issue can not be predicted by anyone even if they had both the servicemanual and the schematics of the TV set.
Madskp
GOLD MemberI got this functionality working with a Beocenter 9300 – 1611 converter – NL/ML converter -Beoplay V1 where I could activate the Beoplay V1 with a press on one of the buttons on the BC9300. It was discussed in this thread https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/24/ where the goal was to find out if the same functionality could be had with a MCL2AV with a connected Beogram. The thread might be a littl messy, but I know I had it working.
I don’t know if the Beosound 9000 does have any limitations in this regard, but in theory it should work.
My NL/ML converter is the latest software version.
I can select link->CD on the TV and play CDs and use the Beoremote remote to control the 9000.
I am wondering why you would have to press link – CD. It should be possible to assign the CD source on the BV11 to the CD player on the Beosound 9000 if they are setup as linked products
6 September 2025 at 07:07 in reply to: Integration of BeoSound 3000 without speakers in to BeoVision 11 #69417Madskp
GOLD MemberHello again. Your pin numbering on the 7 Pin DIN is not correct. The numbering shouldbe like the 8 Pin, but without pin 8.
hope this helps
5 September 2025 at 17:38 in reply to: Integration of BeoSound 3000 without speakers in to BeoVision 11 #69390Madskp
GOLD MemberI have drawn up (what I understand) is the correct configuration for a cable from Power Link to AV and a cable from BS 3000 AUX to AV. Please check for me if they are correct (see files attached).
I do not see the attached file. Could you try to attach it again?
One question remains: Which pin should I solder the breaded wire to at the AUX end? Or should I not need to bother with that?
Pin 2 i also ground in the AUX connector like in the Powerlink connector
4 September 2025 at 09:49 in reply to: Integration of BeoSound 3000 without speakers in to BeoVision 11 #69360Madskp
GOLD MemberIs the above the correct thing to do?
Or should I solder the light grey shield wire from position 8 of the 8 pin mini din to position 8 of the 9 pin mini din.? Or have both those shield wires soldered to position 8 of the 9 pin mini din?
That sounds right. The grey wire in a fully wired Powerlink cable is not ground, so that should be unused.
By the way, I like the idea of going from the AUX of the BeoSound 3000 to the AV of the BeoVision 11 however, the AUX socket is a 7 pin. Can I just cut off the centre pin of the power link connector?
No, You will also need to use another wire pair for the left and right channel since they are connected to pin 1 and 4 of the 7 Pin DIN connector in that use case
Madskp
GOLD MemberMy best bet would be that another device is also connected to the Beolit 20 and has first priority to it.
This is based on my experience with my Beoplay Earset that is normally connected to my iPhone, but once in a while used with my Macbook. The stability of the connection to the Macbook is very random, whereas the connection to the phone is allways working.
Don’t know if it helps, but just my 2 cents
Madskp
GOLD Member– Disclamer start: I do not have much faith in auto generated answers from chatbots – disclamer end –
Very hard to decipher the Chat GTP conversation, but before you start paying money to repair your Beomaster 7000 you should consider a few things.
If your setup is actually connected like the sketch in this posthttps://forum.beoworld.org/forums/topic/access-options-on-beomaster-7000/#post-68804 and the Pentas are connected to the TV and only the TV the the Beomaster 7000 has nothing to do with volume control in your main room. The volume for the Pentas are regulated by the device they are connected to, hopefully the TV as advised bye me and other members earlier.
DO NOT CONNECT THE PENTA SPEAKERS TO THE BEOMASTER 7000 IF YOU WANT THIS SETUP TO WORK
Also as far as I iunderstood the devices you had volume troubles with and Apple TV and the PC source, both something connected to the TV. As advised before I would look into the speaker group setup for these connections. Based on what you are telling it sounds like the center speaker on the BV7 might not be in play for dialogue.
29 August 2025 at 17:40 in reply to: Beocenter 1 with Suspicious Display and IR Board (PCB58) #69165Madskp
GOLD MemberYou are very welcome.
Unfortunately B&O at one point stopped showing schematics in the servicemanuals because the began replacing boards instead of repairing them. Therefor it can be hard to figure out which components are in the products without disassembly and measuring.
If it is the capacitors under the shield, I am guessing those would be surface mounted components since the back of the PCB has no through-holes in that section?
That is very likely.
Thanks again. This is my only B&O product so it really helps to hear from someone with more experience. I tried getting help from the CRT TV enthusiast community but it seems that B&O TVs are such a different kind of product that the regular CRT TV enthusiast community can’t really offer much help for issues like this. Thanks again!
Not much experience with repairs on them. I have had B&O CRT’s some 15-20 years ago, but never had to repair them when I had them.
Not much activity about CRT’s here on Beoworld either. Only once in a while. I guess most people that use CRT TV’s today are retro gaming entusiasts. You might be lucky to find something on the archived forums thought.
Madskp
GOLD MemberUntil I have a chance to experiment with more systems, I’d venture to say that MCL82 itself is primarily a kind of “communication facilitator”, or “glorified IR extender” with an attached speaker switch, which is hard set in advance to the capabilities and IR protocols of whatever master system is specified
I kinda had a feeling about this since the IR transceivers for both MCL82 and MCL30 are very simple inside compared to the MCL2 trancievers
MCL30 transceiver on top and MCL82 below. I guess the MCL82 one has a little extra components to facilitate the IR transmitter for 2 way communication.Stay tuned, I’m nearly there!
Very interested to see what you have come up with 🙂
29 August 2025 at 15:16 in reply to: Beocenter 1 with Suspicious Display and IR Board (PCB58) #69149Madskp
GOLD MemberThere are other B&O products where IR issues are related to bad electrolytic capacitors. In most cases it is capacitors near the IR receiver, so they might be within the metal shield.
Other than that have you tried to reapply options settings to ensure that it somehow hasn’t gone to option 0(no ir)
29 August 2025 at 12:32 in reply to: Integration of BeoSound 3000 without speakers in to BeoVision 11 #69146Madskp
GOLD MemberYou might wan’t to consider how you are going to control this setup.
If you wan’t to control both the Beovision 11 and the BS3000 with a remote there a few things to consider:
- The AV input on the BV11 can only be assigned to one source name. So if you make that CD, you will be able to press CD and start both the BV11 and the CD player on the BS3000. However you will have trouble selecting another source from the BS3000 (you can do it on the BS3000 button though). Further more you will have a double volume control issue.
- If you instead assign the AV input to a video based source name like DVD or V.MEM you can active the BV11 with that and then select the desired audio source on the BS3000 with it’s source button. This way you will avoid the double volume control issue.
- Instead of using Powerlink out of the BS3000 you can get a fixed volume by using the aux out pins in the AUX connector. This way you only do volume control on the BV11. If this is smart depend on which of the above solutions you take.
- I will also mention the larger alternative which is the Beolink Converter NL/ML which can give you full integration between the BV11 and BS3000. This will of course be a more costly solution and might be hard find in Australia since they can only be found used now.
Hope this input is helpfull, and feel free to ask for more clarification
