hcraig244
Forum Replies Created
Viewing 20 posts - 281 through 300 (of 337 total)
  • in reply to: Beolab 5000 Type 5303 #34484
    hcraig244
    SILVER Member
    You need to take the top off, remove the screws holding the amp PC down….it’s on a hinge so will lift up and can be put into the service position which is vertical. This allows access to the power on bulb, its a push fit onto a tab and can ce carefully pulled backwards untill released, you can then unscrew the lamp and replace it…..make sure you use the propper voltage…I think its 60vdc
    PA134348 (Copy)
    in reply to: Beomaster 5000 #33955
    hcraig244
    SILVER Member
    All complete and fully tested…..does sound very good for an old girl, I think it can now be identified as restored……
    P1016835
    in reply to: Beomaster 5000 #33954
    hcraig244
    SILVER Member
    Made a start on the front panel and curser…..takes quite a bit of fiddling around to get the felt pads back in along with the nylon studs on which the curser rides…..
    P1016820
    in reply to: Beomaster 5000 #33953
    hcraig244
    SILVER Member
    Hooked up to a Beolab 5000 and an antenna, and I have to say that in spite of the occasional unexpected minor issue this tuner sounds tremendous….crystal clear and very stable….all that remains is to put it all back together ;¬)
    P1016814
    in reply to: Beomaster 5000 #33952
    hcraig244
    SILVER Member
    Completed all the component replacements….including the “fairchild black blobs”, fitted BC550B’s.
    P1016815
    in reply to: Beomaster 5000 #33951
    hcraig244
    SILVER Member
    Deciding the way forward was to replace the cloudy lens with the not so cloudy lens on the one I had just installed I set about dismantling the not so cloudy meter and discovered the internal connection from the + post was loose….tightened it up put it back together and having removed the newly extended + wire I soldered it back in place…..and yes everything worked fine!……spent a couple of hours on this
    P1016811
    in reply to: Beomaster 5000 #33950
    hcraig244
    SILVER Member
    However I extended the + wire and soldered the cloudy meter in place and ran another test, all worked fine
    P1016807
    in reply to: Beomaster 5000 #33949
    hcraig244
    SILVER Member
    The polarity of the meters are opposite, someone has erased the + / – markings from the left hand side meter and marked them up opposite to what they where…….the right hand side meter is the one with the milky lens and still has the + / – markings unchanged,
    The negative marking can be seen against the right side post, the meters have different shapes too….change in design down the years I expect.
    P1016804
    in reply to: Beomaster 5000 #33948
    hcraig244
    SILVER Member
    Thinking I may have damaged it during cleaning I took it out, looked ok and when I put my multimeter across it to check the moving coil continuity the needle deflected 3/4 up scale, as you would expect from the current from the meter set to ohms. I got out a meter I recently replaced due to severe clouding of the lens to compare….and found this curious thing……
    P1016806
    in reply to: Beomaster 5000 #33947
    hcraig244
    SILVER Member
    Started by checking the 240v supply to the transformer…..all good, 32v output to the new rectifier and around 40vdc out of the rectifier. Checked the 20vdc supply and found it was around 29vdc…adjusted the new trimmer I installed and brought it back to 20vdc……checked the voltage to the power ON lamp and that was good too…..so replaced the lamp and of course it illuminated ;¬)
    Connected a antenna and adjusted the tuning dial, the stereo lamp flickered as it passed through live broadcasts which was very encouraging…..however the tuning meter stayed hard down throughout.
    in reply to: Beomaster 5000 #33946
    hcraig244
    SILVER Member
    This is true Soren….I received this from Frede some time ago:
    Craigh,
    It is actually a ”short list” ?
    BC 550B for npn
    BC560B for pnp
    When the Beolab was designed (before 1967) only a few transistors were available is really low noise versions – therefore B&O have chosen a number of different types of coarse also being able to be used and meeting the actual voltage level. But I have for many years used the above type in the pre-amplifiers.
    And I am using the transistors type B because higher gain in classic electronics design is not a good idea (this is my opinion ?)
    B U T — for the power amplifier and the power supply – I only use the original RCA types !!!
    For the output power transistors and psu transistors — I am only using the original Motorola or RCA (there are to many “fake” 2N3055 out there).
    When I am writing the original it is actually the original because I re-use these transistors from Beolab 5000 which is scrapped.
    in reply to: Beomaster 5000 #33944
    hcraig244
    SILVER Member
    Removed the link and cleaned up the fuseholder…new fuses installed. Gingerly applied power from the variac up to 220v……and nothing happened, not necessarily a bad thing…there was no smoke or sudden popping of new fuses…..so a little fault finding exercise required….as for now a glass of wine is called for
    P1016812
    in reply to: Beomaster 5000 #33943
    hcraig244
    SILVER Member
    Thought I would check the fuses out too before powering up…..this is what I found.
    P1016802
    in reply to: Beomaster 5000 #33942
    hcraig244
    SILVER Member
    Finished with the replacement of trimmers and capacitors, all except the channel seperation trimmer…thought I would wait until the unit is up and running before playing around with a replacement for that one.
    P1016803
    in reply to: Beomaster 5000 #33941
    hcraig244
    SILVER Member
    And made a start on the trimers……P1016799
    in reply to: Beomaster 5000 #33940
    hcraig244
    SILVER Member
    New feet arrived in the post…….drilled the old ones out and fixed these with bolts.P1016795
    in reply to: Beomaster 6000 Type 2702 service manual #34017
    hcraig244
    SILVER Member
    Phil
    As I recall I replaced the zener diode 2D9 and the problem pesisted, I then replaced the two diodes 2D10 and 2D8 and still had an issue, I put off replacing the zener diode 0D2 because it was difficult to get at….its hidden away off PCB2 and bracketed against the front end shield box PC1, eventually I had no choice but to do so….and that solved the problem, I cant remember if I replaced 2TR8 or not….the post will be somewhere in the archived forum 2012-2022 along with pictures if you care to try and track it down…..it may help, I would recommend changing 2TR8 seeing as your going to replace the diodes…….good luck I have had lots of fun with the 6000 type 2702 amps.
    in reply to: Today’s flea market find. #34257
    hcraig244
    SILVER Member
    Quality…….
    in reply to: Beomaster 5000 #33939
    hcraig244
    SILVER Member
    Not perfect…..but I’m happy with the result…..
    P1016793
    in reply to: Beomaster 5000 #33938
    hcraig244
    SILVER Member
    disconnected and removed the tuning meter, front lens is a little cloudy from too much UV and some debris has got between the two halfs of the assembly….making it look unkept. Cant do a lot about the cloudy lens…I have tried in the past to no avail….but I can clean away the debris……..
    P1016785
