filip_kbh
Forum Replies Created
Viewing 20 posts - 141 through 160 (of 167 total)
  • in reply to: How to connect a Beolab 3500 to BM7000 #44502
    filip_kbh
    I have now re-done the option settings while everything was connected to mains. Pressing Radio turned on both the BM7000 and the BL3500 but the BL3500 shut off after a second.
    Regarding the previous question, the datalink cable is connected to the socket called AUDIO OUT LINK on the 1611 box.
    in reply to: How to connect a Beolab 3500 to BM7000 #44500
    filip_kbh
    I just tried. Disconnected everything. Turned on the BM7000 and set it in A.OPT1. Disconnected it from mains. Connected the BL3500 to mains and set it in L.OPT6. Disconnected it from mains. Then turned on BM7000, thereafter BL3500 and finally the 1611 box. It still does not work – argh, this is so frustrating.
    in reply to: How to connect a Beolab 3500 to BM7000 #44497
    filip_kbh
    If the datalink cable is disconnected from the BM7000, I can turn on the BL3500 and change sources. I guess this points to a problem with my BM7000 then? The 7-pin datalink cable is brand new, so I don’t think that could be faulty.
    I have no way of testing with a different ML cable, unfortunately.
    in reply to: How to connect a Beolab 3500 to BM7000 #44495
    filip_kbh
    The beolink converter is type 1611, item 1161166, SW 1.3
    in reply to: How to connect a Beolab 3500 to BM7000 #44494
    filip_kbh
    I tried option 6. It turns on for a second and then turns off. I wonder if there could be a fault on the BL3500. Also, there is a sort of high pitched sound in the left speaker of the BL3500 which I suppose should not be there. It’s there independent of whether any connections have been made.
    Thanks for the help so far.
    in reply to: How to connect a Beolab 3500 to BM7000 #44492
    filip_kbh
    Display shows “ML on”.
    BL3500 SW version is 3.1
    Serial no is 2058xxxx.
    in reply to: How to connect a Beolab 3500 to BM7000 #44490
    filip_kbh
    The datalink cable has 7 pins, yes.
    in reply to: How to connect a Beolab 3500 to BM7000 #44508
    filip_kbh
    I have now tested for continuity between all pins. There is only continuity where there should be continuity. My money is on the BM7000. I saw Die Boegener made reply to someone around datalink not working after a thunderstorm. Since I did not have my BM7000 since the beginning, I have no clue what has happened to it previuosly.
    At https://archivedforum.beoworld.org/forums/p/28464/223667.aspx he replies:
    some parts in the datalink section are dead. Nothing special, 50 cents on the pre amplifier board.
    Replace:
    D5= 12V zener diode 0.5W
    TR1=BC547
    That’s all…
    Not sure if I should look into that at some point.
    in reply to: Beomaster 7000 not responding. #44066
    filip_kbh
    First of all, it sounds like you have a muting relay problem (faint sound in the Beolab 8000, assuming that they are connected with Powerlink cables and that the setting is correctly chosen on the speakers). Do you have sound in the headphone socket if you connect a headphone?
    Secondly, the Master Control Panel 5500 showing ‘No Contact’ is only a sign that there is a problem with 2-way communication. The error can either be in the MCP5500, the BM7000 or possibly both. If the Beolink 1000 does not send out signals, I would first suspect that the battery case is not making proper connection to the batteries – it’s a common file that is easy to fix.
    Regarding the Beomaster 7000’s lack of IR response, I would first suspect surface-mounted caps (SMD) on the IR board. But you could start off by simply cleaning the sensors that are bound to be dirty from dust and cigarette smoke.
    If you buy another BM7000 there is absolutely no guarantee that you will not run into similar problems or even new problems. they are 35-years old, and they need maintenance, like e.g. a car would not be expected to run for 35 years without exchanging oil, filters, battery etc.
    Let us know how it goes.
    in reply to: Tangential Drive Lubrication #44014
    filip_kbh
    I think perhaps it would be great to specify which Beogram you have. If there is a threaded bar, I am thinking Beogram 4000/2/4. I have used a silicon lube for mine which seems to be working great since lubrication some years ago.
    in reply to: Beogram 8002 dead after adjustment #43715
    filip_kbh
    Have you tested the fuse?
    in reply to: Beolab Penta Mk III amplifier problem #43172
    filip_kbh
    The error is somewhere in that amp.
    I just switched the two amps around, and then the display does not work in the other speaker where it worked before.
    in reply to: Beolab Penta Mk III amplifier problem #43171
    filip_kbh
    I now had time to test everything. So the good news is that the display works on one of the pentas. Using the same cable, making sure that the audio/video button is set to audio, the display of the other penta is still not working. Argh.
    I made a continuity test from the pins of the attached powerlink MKII cable to the connectors on the powerlink of the actual speaker (with the amplifier completely disconnected). All connections worked out fine.
    When connecting the powerlink cable to the amp, the continuity test is a bit strange. I get no continuity on pins 1, 4 and 7 in the Auto mode. I believe pin 4 is data. Any ideas where I should be looking next?
    Any help is appreciated.
    in reply to: Beocenter 9000 new laser required – Florida #43428
    filip_kbh
    Or it needs a proper cleaning. There is a thread called “Beosound 9000, how to fix the laser” that links to a video on how to clean the laser under the lens and mirror.
    in reply to: Beogram 4000 Tonearm and Sound #43475
    filip_kbh
    Hmmm – my guess is – since it’s a 59xx Beogram – that a small plastic tap has broken off where the wire attaches. There are some good posts about it on the forum.
    in reply to: Beosound 9000, how to fix the laser. #40739
    filip_kbh
    Glad that the video helped you. Hopefully it will be of use to many others, avoiding unnecessary replacement of the laser unit. Perhaps this thread could be renamed to “Beosound 9000 how to fix the laser” in order for more people to discover it.
    in reply to: Beolab Penta Mk III amplifier problem #43170
    filip_kbh
    So, it was the soldering but not in the actual connector. It was the damn Powerlink cable where the Data Ground had snatched off. After repairing the cable, the display works! Thank you for all the help.
    in reply to: Beolab Penta Mk III amplifier problem #43169
    filip_kbh
    Clear – thanks. Will check the soldering on that connector.
    in reply to: Beolab Penta Mk III amplifier problem #43167
    filip_kbh
    Yes, that area appears to have been hot sometime in the past. It was the same area in both speaker amps. I don’t know the history of the speakers. I bought them from an elderly lady, and she threw in a Beolab 3500 plus cables and connectors for the quite modest price of 263 dollars for all of it. I wasn’t exactly thrilled about getting the Beolab 3500 and immediately put it up for sale. However, it does not appear that it is in demand, so I guess I will mount it in my bedroom. I just need a 1611 converter box.
    Glitch – can you tell me where the “lower display connectors” are found? Do you mean in the lower board of the two, or is it found in another place than where the displays are mounted?
    in reply to: Beolab Penta Mk III amplifier problem #43165
    filip_kbh
    However, one problem remains. The displays do not work in either of the speakers. I have them connected to a Beomaster 7000 with a Powerlink Mk2 cable, and the selector at the bottom of the speaker is on Audio. The display in at least one of the speakers worked before I recapped the amplifier and the crossover boards. I did not test the other before I started the rejuvenation.
