Siri
Forum Replies Created
  • Siri
    This project is quite impressive and amazing to see get developed. Quite tempted to get a BS5 I saw for sale without the base station.
    However, i am wondering. You mention it supports Plex, but do you know if Jellyfin would also work? Alternatively other Self hosted music streamers.
    And if you don’t have the base station, is your only option wireless speakers or would it be possible to connect Powerlink speakers still?
    in reply to: Ouverture glass door hinges glue? #124947
    Siri
    The black coating was ripped off when the Epoxy failed. I not noticed the Extram Repair affecting it. Tho I supose its possible my glue got better adhesion without the coatin ginn the way.
    My thinking was it was worth trying. worst case i break a panel that is allready scratched up and according to my Local B&O store they had spare panels in stock.
    in reply to: Ouverture glass door hinges glue? #124945
    Siri
    Inn my attempts i did break the black coating, but from my experiments I found Loctite Extream repair seems to hold. I can remove the doors without it breaking, but how long it will last I do not know.
    I tried epoxy, but that didn’t last very long in my attempts.
