Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4000 and also BG8002
- This topic has 116 replies, 3 voices, and was last updated 1 month, 3 weeks ago by
hcraig244.
27 August 2026 at 09:24 #125261
hcraig244
SILVER MemberUsing 2500 grit carbourundum paper, little more than rough paper, cleaned the control panel switch contacts both sides particularly on the << and >> switches, in the past I have unsoldered the whole assemblies and gold plated them before putting them back….more of an exercise in indulgence on my part than a worthwhile requirement….the work was chronicled here and is probably in the archives somewhere.
You must be logged in to view attached files.27 August 2026 at 09:30 #125267hcraig244
SILVER MemberTransport slider contacts next up…..the plastic actuators that operate these switches have caused me grief in the past…I foolishly put silicone grease on them which, given their very light operating pressures, where getting held up by the viscosity of the grease causing intermittent errors in the Boolean logic circuits of the control panel……was a long time realising the cause of that one!
You must be logged in to view attached files.28 August 2026 at 11:11 #125280hcraig244
SILVER MemberAll the components now replaced….going to go ahead and replace the lamps in the control panel when they arrive from Martin, also the new pulley wheel to fit.
You must be logged in to view attached files.28 August 2026 at 11:26 #125282hcraig244
SILVER MemberMeanwhile the dust cover needs some attention, firstly clean all the old adhesive left by the tape fitted previously, IPA is the weapon of choice. I’m very reluctant to disturb further the previous attempt at a repair and have decided to attempt to reinforce it instead, trying to remove the epoxy glued screws would almost certainly result in more damage leaving less material to work with…some nylon matrix super glued over the cleaned up repair and some epoxy applied to the hinge on the underside….when I fit the new aluminium trim I will apply epoxy on top of the matrix and use the trim to further re-in force the repair….the main section of trim will be glued with aleenes tacky glue as I think that will be adequate.
You must be logged in to view attached files.29 August 2026 at 15:50 #125288hcraig244
SILVER MemberSet up the electrical adjustments…slow slide transports left and right, should be between 2.5vdc and 3.0vdc. Looked good to me so went with both as is.
You must be logged in to view attached files.29 August 2026 at 15:54 #125291hcraig244
SILVER Member30 August 2026 at 09:55 #125301hcraig244
SILVER MemberOn with the dust cover repair…the epoxy has cured and after a little cleaning up im quite happy with the joins so time for the new trim, getting everything central is key….
You must be logged in to view attached files.30 August 2026 at 10:01 #125304hcraig244
SILVER MemberOnce satisfied there’s nothing for it but to commit to the bend, there’s only one chance…..will need to apply glue and epoxy but given where we started I’m calling this a win.
You must be logged in to view attached files.2 September 2026 at 13:13 #125324hcraig244
SILVER MemberQuick adjustment of the 33rpm trimmer I replaced, was a little high but adjusted down nicely….the Beolovers patent tacho I purchased some years ago helped give the required accuracy.
You must be logged in to view attached files.2 September 2026 at 13:21 #125326hcraig244
SILVER MemberOne of my least enjoyable adjustments is the platter height, never have got it bang on despite trying many times on many machines…there just never seems to be the required adjustment afforded by the “slogger” in the threads between the bearing and the lock nut…the theory is good but in practice is very tricky to achieve…my tip….ensure the set screws are protruding a good amount below the lock nut to give them the most leverage…
This reply was modified 1 month, 3 weeks ago by
hcraig244.
You must be logged in to view attached files.2 September 2026 at 13:28 #125332hcraig244
SILVER Memberback of the platter needs to come up a little….some adjustments later this was the best I could do
You must be logged in to view attached files.2 September 2026 at 13:30 #125337hcraig244
SILVER Memberthe floating chassis also requires some adjustment to bring it flush to the deck plate…
You must be logged in to view attached files.4 September 2026 at 07:53 #125363hcraig244
SILVER MemberGot the platter level with the aluminium trim and also central to an acceptable point
You must be logged in to view attached files.4 September 2026 at 08:05 #125365hcraig244
SILVER MemberThis done, and bearing in mind the numerous adjustments made, the pickup arm lowering limit needed checking and as suspected it was falling below the level of the lower ridges on the platter….disastrous for the stylus should the detector arm fail and allow a drop onto a platter with no disc……easy adjustment which did have to out followed by setting the stylus force for the SP15 which should be 1.0 gram. The dial was set around 1.25 and sure enough my scale did read above 1.25g….I struggled to get a good image of these, set it to 1.0g and to be fair the scale on the pickup was very close to the 1.0g setting…..
You must be logged in to view attached files.4 September 2026 at 08:07 #125369hcraig244
SILVER MemberThis done I had to have a listen……..all sounds and looks healthy.
You must be logged in to view attached files.5 September 2026 at 15:40 #125385hcraig244
SILVER Member5 September 2026 at 15:46 #125391hcraig244
SILVER Member -
