Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4000 and also BG8002
- This topic has 116 replies, 3 voices, and was last updated 1 month, 2 weeks ago by
hcraig244.
18 August 2026 at 17:18 #125057
hcraig244
SILVER Memberfloating chassis caps first…..easy to get to
You must be logged in to view attached files.18 August 2026 at 17:24 #125059hcraig244
SILVER Memberonto this little lot…….I’ve seen one of these three legged monsters before, maybe in a BM6000….not too sure, nasty things and awkward to get out. And a link is required to connect the negative leg…the last pic doesn’t show the link, soldered it in once i had the replacement cap in place.
This reply was modified 2 months, 1 week ago by
hcraig244.
You must be logged in to view attached files.18 August 2026 at 17:29 #125064hcraig244
SILVER MemberThe IC canister next…..I had replaced the caps that hide underneath it, learning from the last one!…..this cap is probably the most difficult to access I have ever come across. I cut the old one out retaining the negative leg as long as possible and created a loop on the replacement cap negative leg and hooked it over the existing piece of the old cap…..the positive leg comes out easy enough and the new leg fits in nicely.
hcraig244.
You must be logged in to view attached files.18 August 2026 at 17:35 #125068hcraig244
SILVER MemberWith some trepidation I connected everything up and gave it a test……all performed well.
You must be logged in to view attached files.20 August 2026 at 15:29 #125104hcraig244
SILVER MemberDust cover fixed bracket is still fixed with the two sided tape…..decided to beef it up with some epoxy to make sure it stayed that way.
You must be logged in to view attached files.20 August 2026 at 15:29 #125107hcraig244
You must be logged in to view attached files.20 August 2026 at 15:36 #125110hcraig244
SILVER Membernoticed that the teflon/mylar strip for the spring lever has become detached, need to reaffix it…
You must be logged in to view attached files.20 August 2026 at 15:38 #125113hcraig244
SILVER MemberAll done and on test…….all three are now ready for collection….BG4000 next!
You must be logged in to view attached files.21 August 2026 at 15:01 #125124hcraig244
SILVER MemberThe Beogram 4000
Internally looking pretty good, can’t see any footprints anywhere which is encouraging…pully wheel looks wobbly when running, may be buckled, but still works fine.
You must be logged in to view attached files.21 August 2026 at 15:04 #125129hcraig244
SILVER MemberControl panel also looks in good shape….there is a tantalum capacitor hiding away in there that sometimes gets missed….
You must be logged in to view attached files.21 August 2026 at 15:10 #125132hcraig244
SILVER MemberSadly the dustcover isn’t doing so well…..been the subject of a repair in the past, still sort of holding together and I will reinforce the existing repair with additional epoxy….the new aluminium strip will lend more support when fitted as it isn’t foil, more sturdy material…..I would be asking around for a doner cover to replace it with, I think I heard of someone fabricating them but not looked into it?
You must be logged in to view attached files.23 August 2026 at 16:01 #125149hcraig244
SILVER Member23 August 2026 at 16:09 #125154hcraig244
SILVER MemberThe two tricky tantalum caps in the multivibrator on off circuit board are also tricky to get out…..
You must be logged in to view attached files.23 August 2026 at 16:13 #125156hcraig244
SILVER MemberHappy with this and when tested all still working fine…..I have to confess to not knowing what the two sticky backed squares provided in Martins capacitor kit are for, new one on me….Martin?
You must be logged in to view attached files.26 August 2026 at 13:48 #125235hcraig244
SILVER MemberI’m suspecting the sticky squares belong under the two 2000uf caps……main PCB up next
You must be logged in to view attached files.26 August 2026 at 13:54 #125237hcraig244
SILVER MemberWhen replacing the skeleton type trimmers I like to measure the active sides so I can set the new piher trimmers as close as I can for starters, those done and the caps replaced the board is complete
This reply was modified 2 months ago by
hcraig244.
You must be logged in to view attached files.26 August 2026 at 14:07 #125243hcraig244
SILVER MemberTaking a look at the carriage drive pully, that is undoubtedly buckled, I notice a crack in the collar where the tightening grub screw sits….my guess is that this has been overtightened an some point and cracked…allowing the screw to be tightened further with nowhere to go except pushing backwards and warping the pully wheel out of true…while the crack was open I have gave it a coat of epoxy and let it close up again, will leave it overnight and see if its sorted…..the best this would be to replace it with one of the readily available (on ebay I think) aluminium wheels.
You must be logged in to view attached files.26 August 2026 at 14:37 #125247 beogram8002BRONZE Memberthis seller in Lithuania does not say 4000, but maybe the size is correct ?
Precision turntable tonearm pulley B&O Beogram 4002/04 6000 26.6mm (hole 4.5mm)
26 August 2026 at 16:28 #125248hcraig244
SILVER MemberOur friend has this for half the price….
26 August 2026 at 16:31 #125249 -
