Forum Replies Created
stotty1111GOLD MemberOk, thanks both, will look at it next week and get back!
Guy, strangely, I have a dead BC9300 here, I had proposed spares or repair for it, so it is looking like spares currently! stotty1111GOLD MemberThanks for that suggestion Guy, have supposedly looked to no avail!
Thanks all for your inputs, a wonderful resource!
Now all set up and working, its been a longtime since I did the original system setup and the memory grows dim ;-(
stotty1111GOLD MemberOk, now got it working on V aux , v aux2 and pc thus making the tv, dtv buttons obselete on the beo 4 — I recall that the buttons could not be reasigned , ie V aux -> dtv etc — is that correct?
I will try the output of the TNT box into the aerial sockets to chech if the output is readable by the tv — any idea(s)?
stotty1111GOLD MemberThanks for that, I acquired the documentation for the set last week, and sorting thro’ them yesterday it would appear that the DVB module fitted is the ‘T’ variant, the tv was originally supplied in 2009, and, has only had one owner! All the docs are in french, can you supply links to english versions? My technical french is not good!
So, I assume that is the reason for the digital tuner not working.
Said digital tuner handbook indicates that it could be pin related and there is a suggestion that it should be the same as the tv one.
The other problem is
I am wanting to connect a satellite box, a french terestrial box and a computer, the pc by the dvi, the other 2 by scart, when using av1 and 2 there is no option for to call up appropriate id’s, they are;
connections
av1 stb v aux
av2 decoder
av3 none
av4 dvi i pc
I have tried setting all to none and restarting things, all to no avail — I must be doing something wrong along the line.
I just thought default back to factory might give me a clean sheet to recommence so to speak!
stotty1111GOLD MemberBUMP
No suggestions then?
stotty1111GOLD MemberOk, thanks for all the info etc, just tried again with the options highlighted on both tv and dtv, using both Beo4 and also joystick Beo4 pushing left arrow x 2 then stop just returns to the tv and dtv screens.
I am wanting to reset the tv to default settings in the hidden menu, if i select this option, is it going to reset the pin pin code to factory setting? I do not know if my code is a user choice, assuming of course the pin code could be reset originally.
I want to do this as I am having problems setting up the tv to operate with a satellite box connected to an AV scart and the supposed dtv system will not tune any digital (TNT) stuff!
stotty1111GOLD MemberSorry to have confused you all, I’m trying to remove the pin code on a bv7-32, the code on the 10-32 is already non existant!
stotty1111GOLD MemberOk, tried the suggested route, load tv setup page press left hand double arrows twice followed by stop, should get to a pin code page, mine does not do this, just goes back to tv screen,
what am i doing wrong,
I am using a non joystick Beo4
stotty1111GOLD MemberThanks for that and the link, we have Bricodepot and castorama here a la frog – brico is equivalent to B&Q trade and Casto the std B&Q, Next time in either Quimper or Brest I will have a look for the cable trunking, the distibution thing, I think that will stay, however in another DIY chain they had some 2 pin plugs with horizontal cable exits, I will probably replace the existing with some, also the 10 way power block with an 8 way job
I realise it’s being a little nitpicky, but the system as is was installed over 10 years ago with the original BV7-32.
Talking of that, if I go into the engineering menus and reset the piece to factory default , will that delete any ancilliary programs installed or will they still be accessible?
stotty1111GOLD MemberSo, got the tv working in my system, photos show thw progress made tidying up the cabling etc.
The room is open plan and the rear of the tv backs onto the dining area so its been a little involved.
It is acceptable for now, but i may need to shorten the scart interconnecting lead by about 30cms, something for the future!
Photos give an idea of it all!!
stotty1111GOLD MemberHi
Sorry about delayed response, the system did not like my login details!
The BC2 is a UK supplied piece and it does have DAB facilities. Here in France, no DAB service!
So, found the masterlink manual, and after reading the relevant section, I decided to go back to factory settings with both pieces, then chacked all the cabling and connections then reprogrammed both pieces , Op 2 – tv Opt 0 – BC 2 , switched them off and rebooted and hey presto it all works!
Well I say all works, the radio works, but the cd/dvd will load but not play, I suspect my next voyage of discovery will be to investigate the drive system, I haven’t looked as yet at the repair manual, is it belt or geared?
I will try to load some views of my installation later!
Tony
stotty1111GOLD MemberThanks for all the assistance with my questions, I viewed the Beoplay, it was on a low frame stand, I wasn’t impressed!
Eventually sttled on a BV 10-32 in black and in excellent condition.#I realise the sound is a little challenged but is in a system which works very well, so well pleased, It is on a different level to the 7-32 it has replaced!
Bonne fetes to all!
stotty1111GOLD MemberAs ever, thanks Guy, just had a quick look and yes, the fog begins to clear!! 😉
stotty1111GOLD MemberThanks all for your inputs!
Having done some investigations, it might be a goer, but as you might expect my sort of local BnO outlet, 150miles away in Rennes are less than helpful, they just want to flog more new ‘stuff’.
I now need to give some thought to it all, as, I can buy a 7-40,but it is complete with stand, soundbar etc and i already have those here —- doh, life’s a bitch!!
stotty1111GOLD MemberA couple of shots of the ‘Media Centre’ showing the Lenovo idea for streaming(10years old now), quite dinky for the time – note the keyboard!.
The pc is similar to that I am trying to connect to the BV 6-26 – the one shown is a later version with HDMI’s.
The speakers are temporary, I have a pair of BL4000’s waiting for repair, they don’t switch on currently!
stotty1111GOLD MemberSo, been looking at the service manuals via a Danish site, little ref to DVI socket.
Just a thought, is there any point emailing B&O either here in France, GB or Denmark to pose the question on how to activate/reactivate the DVI socket with their Tech Service depts
stotty1111GOLD MemberTried that, without pc output and with output, the option is just test patterns the DVI is not highlighted and cannot be accessed.
The Type No 9252
Item No 1816658
stotty1111GOLD MemberFirstly, thanks for all your suggestions.
I think my problem is more basic, having reset the 6-26 to default I can no longer get the tv to respond to PC Go on the Beo4, it is not present on the menu > connections listing, when called by the Beo4 it eventually defaults to the analogue tv which is not activated.
So, I think I need to open up the box to see what’s actually in there — maybe the apparent activation of the DVI was a left over from its hotel use,
stotty1111GOLD MemberI wouldn’t know, we are getting into the realms of black magic here! 😉
The only observation I can make would be that I have 2x Lenovo Ideacentre Q190’s, they both work through a 7-32 with a DVI socket so i would have assumed the outputs would have worked through the 6-26. But, bear in mind it was a ‘special’ for use in a hotel. The unit did come via a B&O outlet in Chester UK! So, I would assume some prep by them was made!
stotty1111GOLD Membertried that first, didn’t work 🙁
Tony
