Forum Replies Created
Severed_hand_of_skywalkerBRONZE MemberI just wish it had more than ONE PL port.
Severed_hand_of_skywalkerBRONZE MemberFirst step. Try new shielded cables.
1 August 2024 at 16:58 in reply to: BeoSound Essence Mk2 final sw version number? 2.5.55678(170713653) ? #57865 Severed_hand_of_skywalkerBRONZE MemberMy MarkII’s both have 2.5.55678 as well.
Severed_hand_of_skywalkerBRONZE MemberThe actual products on the website would never be confused with anything from B&O
https://beostage.com/complete-setup
Severed_hand_of_skywalkerBRONZE Memberwell… easy enough to ignore. The app itself has way bigger problems.
Severed_hand_of_skywalkerBRONZE MemberApp hasn’t appeared for me yet but I do like that button on the bottom right to select the product. I assumed that this was coming soon as it was shown online at the beosound 9000c release.
Severed_hand_of_skywalkerBRONZE MemberWe love our 12h clocks here. Damn Europe :D. Shame
Severed_hand_of_skywalkerBRONZE MemberSounds odd to me I would ask the dealer about that. Maybe something harmless or maybe a misunderstanding. Maybe when they were servicing them they got the round plate mixed up.
Severed_hand_of_skywalkerBRONZE MemberI have a beosound 9000 with a pair of BL4000’s hooked up to an essence Mk2.
With it I can use the analog inputs to connect the 9000. This way I can play a CD on the 9000 and it plays on the BL9000 as well as to all my other B&O products in other rooms.
I can play music through B&O radio, Airplay 2. Spotify.
All of this can be controlled through the B&O app in terms of volume, inputs etc. Just not CD selection but that’s understandable.
I have had zero problems with this setup in 3 years.
Severed_hand_of_skywalkerBRONZE MemberLooks great in the new clean room. I always thought that centre speaker looked like an evil goatee though 😀
You must be logged in to view attached files.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberNice interview but what is that product in the thumbnail ?
Severed_hand_of_skywalkerBRONZE MemberOh my god after over a month with no updates they have updated the beta app. The Theatre screen is more compact now. Haven’t found any new features though.
Severed_hand_of_skywalkerBRONZE MemberYou have the latest firmware?
Severed_hand_of_skywalkerBRONZE MemberLocation: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberI have a BS9000 connected to an essence with Powerlink speakers. By the sounds of it this box won’t work in this situation unless it has more ports than just USB-C?
Severed_hand_of_skywalkerBRONZE MemberI was wondering the same. I assume its a essence or core without any ports.
Severed_hand_of_skywalkerBRONZE MemberI have the same problem with my A9 Gen 2. Refuses anything but its original name.
Severed_hand_of_skywalkerBRONZE MemberI did mine first day on My G2. No issues. No real point though if you don’t use the TV os. I sure don’t use it, still terrible.
Severed_hand_of_skywalkerBRONZE MemberI don’t mean it’s laggy controlling the products. More that the interface and interaction with the halo is a bit choppy. But since its just a glorified volume control it doesn’t matter much.
Severed_hand_of_skywalkerBRONZE MemberThe Halo isn’t really buggy luckily. It’s just a bit laggy with very limited usage.
