Forum Replies Created
Severed_hand_of_skywalkerBRONZE MemberYes this forum is dying a slow death over the last couple years. Very little engagement these days The discord channel is pretty active so I suggest that.
Severed_hand_of_skywalkerBRONZE MemberI thought you couldn’t connect external speakers to the stage?Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberGreat. but all of it is dependent on your router/hub/network if its deezer or airplay. Maybe attach something to the line in of the core that doesn’t use network at all and see what happens.Normally I would say something is defective but if you got a replacement and there is no reported problems of this happening it could be caused by something on your end.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberWhats the music source? basically what I am trying to figure out is that if the core is streaming music from online and there is some internet drop out or issue the core could get confused and crash.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberSo you tested both? Whats it doing when it crashes?Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberAre you on ethernet or Wifi? What is it doing when it crashes?Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberThey think they can buy a cheap 3000 off eBay for $400 and slap on some wood and have the board checked then mark it up for 30k? It’s literally a kick in the teeth to everyone who kept this company alive for the last 100 years. I’m horribly unimpressed.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE Memberunpair the remote and re-add it.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberThey have completely lost their minds if they think that price is compelling.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberHeadphones H 100 are not too bad 🎶
For the money they had better be beyond specular
Severed_hand_of_skywalkerBRONZE MemberI’d totally be down for a new turntable.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberI have a really bad feeling it will just be a colour variant of something they already have on the market OR beolab 5 refurbished and costing 75kLocation: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberI haven’t used it but people seem to like STB brackets.I also can’t believe an OLED from 2018 already has problems. My Sony OLED from 2015 is still going strong. Did you have a lot of static images with logos on your screen a lot? Just curious.Location: Toronto, Canada
Severed_hand_of_skywalkerBRONZE MemberYou have a lot of options to choose from but feel free to explore eBay for older B&O speakers as most of them look modern and work great.
I don’t have 2’s but I use Beosound 3’s a rears for my theatre and its more than adequate. Im thinking of getting some 12.3’s to replace them eventually just to get some more bass in the back.
With the BS2 you would have to use Digital power link which I don’t think a ton of people here have experience using yet. Personally I worry about wifi interference but I guess that really depends on the individual use case.
Severed_hand_of_skywalkerBRONZE MemberIf its airplay you can connect to the Apple TV and have the sound play through the theatre from the Apple TV
Severed_hand_of_skywalkerBRONZE MemberThe Movie Companion. They have a beosound 3000 hooked up to a Mcintosh and show a close up.
13 April 2025 at 16:33 in reply to: Beosound 9000 MKII – The sledge is moving only at the slow speed #65114 Severed_hand_of_skywalkerBRONZE Memberwhat exactly does that do?
Severed_hand_of_skywalkerBRONZE MemberI’ve heard a lot of people complain about the playmaker over the years? What exactly is bad about it?
Severed_hand_of_skywalkerBRONZE MemberI let everything do it all on its own as I hear its very accurate measuring distances and the end result sounds great.
Severed_hand_of_skywalkerBRONZE MemberThey do pop up on eBay pretty often so if you don’t find one here keep checking eBay. 🙂
