Severed_hand_of_skywalker
Forum Replies Created
Viewing 20 posts - 201 through 220 (of 338 total)
  • in reply to: Will this be more than a concept? #49494
    Why do we want transparent screens? So you can see the wall behind the image as you watch TV?
    in reply to: Update Beosound Theatre 3.2.1 #48990
    I really hope they fix this serious issue ASAP.  they have been very slow with all Theatre releases which was my main concern when buying it a year ago. It should NOT be in this software state so long after its been released.
    in reply to: Upcoming height speaker? #48924
    I’m hoping for a replacement for the BL3 to add to my theatre as hight Speakers
    in reply to: Beolab 8 #48758
    So how will the touch panels on the BL8 work if it is hooked up to a system like the theatre. Will hitting PLAY cause the whole 5.1 system to play (hopefully) or will the 2 BL8 speakers just play independently (God I hope not)?
    Maybe someone with some 28’s can comment?
    in reply to: Beolab 8 #48750
    What is going on with the total lack of Airplay 2 and Chromecast? That’s a total pass for me without it.
    in reply to: Beolab 8 #48748
    Hi, The fluid sweet spot requires Ultra Wide-band connectivity which I don’t think was available when Beolab 28 was developed. Kind regards, Steve.
    Really makes you wonder why the Theatre doesn’t have this feature either, plus the 28’s come out in 2021.   UWB works with iPhone 11 and up which shipped in September 2019.
    Im sure we are all confident that with the Mozart platform we are all getting this upgrade right? 😀
    in reply to: Beolab 8 #48747
    Nice little speaker. It seems that the ‘Bang & Olufsen’ logo is lit when turned on. Like it!
    Could it be a render error? In any event, I would hope that in configuration this could be disabled. Call me a fossil, if you will, but I loved the old green light/red light signifiers.
    “Beolab 8’s beam width control lets you switch seamlessly between two listening experiences. Narrow down with precision audio channelled directly to you. Or go wide and diffuse sound throughout your space. Which mode is it in? The LEDs on the front will enlighten you.
    So it’s not a rendering error and I 100% doubt you can turn off the lights as it’s a UX feature.
    in reply to: Beolab 8 #48746
    in reply to: Moving a Theatre + 65″ LG #48814
    I would do it yourself with help from them or a friend.
    in reply to: Beolab 8 #48725
    Where is the woofer in this? Is it inside firing up?
    in reply to: Beolab 8 #48722
    Beolab 8 does more than adapt to your room. It adapts to you. Using ultra- wideband technology, it directs the acoustic sweetspot to wherever you are. As long as your phone is on you, the sound is too. No need to readjust your speaker, or your room. *Fluid Sweet Spot only works when using Beolab 8 in a stereo setup with Apple iPhone (Apple iPhone 11 or newer).
    This sounds very impressive.
    in reply to: New product launch – beosound theatre? #38414
    Ive noticed that any beta or official Firmware updates for the Theatre have really dried up recently.  I mean B&O was pretty slow from the start almost a year ago but Im a bit disappointed as both the app features / UI and firmware really need some improvements.
    in reply to: Besound Esscence Mk1 brick or not? #48308
    I have several essence mrk2ls and they all work perfectly with b&O radio and airplay.
    in reply to: A9 and Mesh networks #47846
    I have mark 2 A9 and it works just fine on my mesh.
    in reply to: A9 and Mesh networks #47840
    Not sure what you’re really asking? Your A9 doesn’t work on your mesh WiFi network?
    in reply to: Issues Stereo Pairing Beolab 28s #40212
    Be careful with Cat6 cables. I used some and it caused buzz’s and clicks. You should really use Shielded cat 7 cables to be safe.
    in reply to: Flash Your B&O – new(er) thread! #33513
    My recently acquired BS9000 to go with my BL4000’s and B&W sub.
    All hooked up to an essence that broadcasts to all my other B&O all over my loft.
    Just got the stand from fellow Beoworlder 🙂
    DSC02635 (1)
    in reply to: Beolab 17 best streaming option #46763
    I have the same setup and I used this product for years with the 17’s, turntable and sub-woofer hooked up and it all worked perfectly.
    https://ca.yamaha.com/en/products/audio_visual/wireless_streaming_amplifiers/wxc-50/index.html
    in reply to: Beosound Theatre side & height channels #46275
    You’re saying you’ve read the instructions and have no idea on how to add 6000’s as side channels? What would be your best guess based on what you read?
    in reply to: New Wireless Speaker Beosound A5? #45461
    But I would not for one minute think that B&O don’t know what they are doing power-management wise.
    My A2 was rated at 24 hours playback and always lasted under 2 hours.  My Halo remote does nothing all day and last 48 hours. My Beoremote 1 is hardly used and the battery lasts a month. I absolutely think B&O doesn’t know what they are doing power management wise.
