Razlaw
Forum Replies Created
Viewing 20 posts - 81 through 100 (of 133 total)
  • in reply to: New product launch – beosound theatre? #37812
    Razlaw
    in reply to: New product launch – beosound theatre? #37811
    Razlaw
    After you run Room Sense, open the speaker group, should take you to a view in the app of the speakers that are included. Touch the three dots top right. New menu will open that will include advanced as an option. Select that.
    in reply to: New product launch – beosound theatre? #37809
    Razlaw
    Did room sense play a sound through them? Did you go into the advanced settings and select position of the R1 connected speaker?
    in reply to: New product launch – beosound theatre? #37806
    Razlaw
    I was able to add a speaker connected to a Receiver 1.  Initially it would find the Receiver 1, but not play a test tone or add it. I then rebooted the Theatre and tried again. After the reboot the Theatre found the Receiver 1, played the tone during room sense, and added it. The speaker position still must be selected manually and the bass management adjusted manually but the added speaker worked great through the Receiver 1 after doing so.
    in reply to: New product launch – beosound theatre? #37803
    Razlaw
    I am on beta also.
    in reply to: New product launch – beosound theatre? #37799
    Razlaw
    My Theatre is on 2.3.4.15129.  The complete number is found in the Set Up Overview under Support, and then select the Theatre.
    in reply to: New product launch – beosound theatre? #37798
    Razlaw
    I will check the version when I get home. I believe it is 2.3.4, however, there is one screen in the app, might be the “about” screen that gives a fuller version number …i.e. 2.3.4xxxxxx
    in reply to: The Halo still a viable choice? #41425
    Razlaw
    Thanks!  I do not have a BLI but have been considering one for a long time.  I am not sure I would get much benefit out of it which is what has held me back from getting one.
    in reply to: The Halo still a viable choice? #41421
    Razlaw
    Also, when the Theatre fails to turn on the TV screen, you can program a button on the Halo to do this.
    When you say can program I assume you mean with a BLI as opposed to a stand alone Halo?
    Thanks!
    in reply to: New product launch – beosound theatre? #37796
    Razlaw
    Unfortunately problem also
    occurs with MyButton.
    Thanks for the suggestion !
    in reply to: New product launch – beosound theatre? #37791
    Razlaw
    It is a Dish DVR.  The box does turn on as does the G2 but the image and audio do not begin.  Sometimes the screen indicates no signal.  If I turn on another source such as Apple TV, Netflix etc image and audio immediately begin.  If I then press satellite it also begins immediately.
    in reply to: New product launch – beosound theatre? #37785
    Razlaw
    Separate  satellite box. Connected to Theatre.  PUC control.
    in reply to: New product launch – beosound theatre? #37782
    Razlaw
    It is a very weird problem.  It is a G2 panel.  The problem only occurs when wanting to turn on satellite.  It is not present with any other sources, the sources built in to the G2 turn on promptly. Sometimes when turning it on, the audio comes on briefly, then stops, then the audio and picture both come on.
    in reply to: New product launch – beosound theatre? #37779
    Razlaw
    I still have a problem with the LG not turning on if I select satellite and it has been off for a long time.  Other sources start immediately and then can start satellite.  Also, hoping for Receiver 1 support. I read elsewhere online that an update to the app is coming soon that resolve the Receiver 1 issue.
    in reply to: New product launch – beosound theatre? #37777
    Razlaw
    Multiple presses of a button on the BR1, such as skipping through channels, or fast forward or rewind of a dvr’d program would cause the Theatre to disconnect from the screen, screen would go blank other than a message saying it had disconnected, screen would then come back on, say it had reconnected, but might switch sources and change volume level.
    in reply to: New product launch – beosound theatre? #37775
    Razlaw
    Received a software update today to my Theatre.  Initial impressions are the previous problems have been solved.
    in reply to: 19? With Theatre, 28s, 1s? #41231
    Razlaw
    Thanks for letting me know! I had second thoughts about the 19 before seeing this and told dealer to hold off on shipping the 19.  Now I am doubly glad I did.  I cancelled because I don’t know that I have a suitable place in the room for it.
    in reply to: New product launch – beosound theatre? #37763
    Razlaw
    I received another email today from BeoCare indicating that they are aware of the problem and developers are working on a fix.
    in reply to: 19? With Theatre, 28s, 1s? #41229
    Razlaw
    Have a 19 on it’s way from dealer to try out.  Am very curious to see if I like the sound better with or without it.
    in reply to: New product launch – beosound theatre? #37760
    Razlaw
    How do I enable B and O mode? App shows connected and I do not see an option to specifically enable it.
