Forum Replies Created
Bill Lumbergh
BRONZE MemberReally strange. No version of the B&O app has worked on my MacBook in the last 15 months…
I will have to dig around and try different settings, but I have to my knowledge never changed any of the standard settings. I have installed some windows management apps as I have a 40” monitor, but the B&O app doesn’t work either if plugged into the external monitor or in laptop mode.
Bill Lumbergh
BRONZE MemberVery strange. Work fine for some but not for others, all with M-processors. Especially strange that it works on one Mac Mini A4 and not on another…
I have tried to delete and download the latest version of the B&O app, plus running MacOS on latest version. Though, it has never worked for me (have tried for a year).My B&O Icons:
Bill Lumbergh
BRONZE MemberThe default set-up is to have them deactivated when you have front L/R-speakers included, like your BL50. I have a 5.0 set-up with BL28 as front L/R and BL8 as surround, and the side-firing speakers in the Theatre are deactivated. I tried to add them in another listening position, but preferred them diactivated.
Bill Lumbergh
BRONZE MemberAre you referring to the built in app in the LG TV? I do not like that app, and also got very low volume when playing Atmos content. I instead use an Apple TV and play music from that, much better interface and usability. And the sound had better volume. Well worth the 150 EUR. The only benefits with the in-built LG apps that I can find is that you can start them from Beoremote 1, but the remote to the Apple TV is so quick to use so I prefer that anyway (even if I can use the Beoremote 1 for my Apple TV). I can really recommend in investing in a Apple TV, both for music playing and for streaming TV/video.
Bill Lumbergh
BRONZE MemberThe strange thing is that on my Mac (16 inch MacBook Pro M1 Max) the iPad app only shows an animation (see attached screenshot) on most of the window, and then there is a white field on the right side of the window. No menus/buttons available. I have tried to reinstall the app, but without any success. Same animation shows.
Han anyone else had the same problem with running the iPad app on a Mac, and managed to get the app to work?
You must be logged in to view attached files.My B&O Icons:
Bill Lumbergh
BRONZE MemberI did not know there is a MacOS app. Where do you find it? I cannot find it in the regular AppStore. Is it somewhere on the B&O-site? I have an MacBook Pro M1 Max and I have tried to use the iOS-app but it does not work for me as it freezes on a background pic. AMacOS app would be great.
Bill Lumbergh
BRONZE MemberHi, I think that they also are used for wired Digital PowerLink (DPL), which was launched in autumn last year. So they probably left out commenting on them when writing the manual, as it was a future feature. But someone else that knows more, please confirm or correct me.
