Millemis
Forum Replies Created
Viewing 20 posts - 101 through 120 (of 1,253 total)
  • in reply to: Connecting a Beocentre to a phone #64479
    Millemis
    Is your bluetooth receiver already connected to the ‘Beocentre’?
    If yes, how and which ‘button’ is used to activate the input?
    (Do you use a remote for the ‘Beocentre)?
    If yes, push that button and let him connect to that with his phone….he can find the receiver in the bluetooth settings there.
    Note: you/he will have to turn up the volume on the phone to almost max and then control the volume on the ‘Beocentre’.
    in reply to: 100 Years of Bang & Olufsen – Struer Visit 2025 #64239
    Millemis
    Congrats to you 👏🎉
    P.S.
    I am all in, should there be a third drawing 😉
    in reply to: Beosound 5 with Beolink 1611 converter #64217
    Millemis
    ’…how to control my Samsung TV menu system with a Beoremote One’
    Have a look here – please be aware that we are talking the ir version (of BROne).
    in reply to: Beoplay M5 as a hub #64215
    Millemis
    No!
    in reply to: 100 Years of Bang & Olufsen – Struer Visit 2025 #64175
    Millemis
    I assume that all those, who was not chosen in the first round are considered for this new round?
    in reply to: Hall Audio – closed #64166
    Millemis
    The ‘fixed sound level’ is not an option to me…..
    ….since I also want to use the sources of the Essence (in addition to the audio from the tv).
    in reply to: Hall Audio – closed #64135
    Millemis
    I use – for an older Philips 32” tv in a guestroom – an ARC Extractor with an Essence MK2 (line-in) and a set of BL3.
    Works, but volume control is a bit fiddly.
    The tv volume has to be set high…..if I want it louder, I have to use  the Essence Remote (or the app).
    I assume, that it would have worked smoother with the Hall Audio Streamer or the OneRemote-box with the BL3’s directly connected.
    But I wanted the Essence (and Beolink multiroom) in the mix.
    That’ll do for now!
    If I could get my hands on a V1-32 at a reasonable price, I’d probably replace the current solution.
    in reply to: Hall Audio – closed #64120
    Millemis
    @Guy
    Yes, seems so – I only noticed it recently.
    I haven’t had the chance to test it yet, but I am sure, that it will work.
    Erland/OneRemote knows what he is doing.
    in reply to: Hall Audio – closed #64108
    Millemis
    “How was it different from using an Essence or Core?\n\n\u00a0”
    Modern tv’s (but not all) have an optical digital output, that can be used with the Core.
    No modern tv has analog audio output and – for the Essence – you’d have to use a Digital to Analog Converter in addition.
    However every (modern) tv has a HDMI/(e)ARC socket.
    That is what is used on the Hall Audio Streamer.
    It is more reliable, turns on/off with the signal.
    (That is the port used with soundbars).
    You simply use the original tv remote.
    So, the BS Core can be used – however, those, who are willing to spend what that costs, will rather buy the Connect Core instead….
    …..a device that B&O waited very (too) long to introduce and that basicly does, what the Hall Streamer does with the addition of being able to work inside the Beolink network/the Mozart platform.
    The Hall Streamer was very popular – it will surely be missed.
    Those who are in need of a HDMI/ARC box may have a look on the solution from OneRemote.
    in reply to: Low-Budget Multiroom Setup for Ceiling Speakers #64007
    Millemis
    Interesting!
    Yes, maybe Steve can say something about the difference between our two solutions.
    in reply to: Low-Budget Multiroom Setup for Ceiling Speakers #63996
    Millemis
    @Guy
    Are you sure that that is the right cable?
    I was recommended – and bought – this one and an adapter cable piece, when I wanted to connect my Essence MK2 to a Passive driving my CX100 in the kitchen (so basicly same scenario).
    That works perfectly!
    Millemis
    Software version – shown in the display…
    On the remote press MENU, then MENU, then 0, then 0, then PLAY.
    Millemis
    Generally the procedure is different from one version of the Beo4 to another.
    Have you tried activating (GO) A.Setup?
    in reply to: Connecting AUX source to Beo Ouverture #63818
    Millemis
    If you prefer to buy one….
    ….you’ll need something like this
    Millemis
    Danke dir!
    Übrigens, eine andere und wie ich meine, bessere, ist diese.
    Etwas teurer, aber dann auch komfortabler, wenn mal eingerichtet.
    in reply to: Beosound Theatre — Knowledge Base #63778
    Millemis
    @David
    It needs to be PCM.
    @Per
    Unlike the Beoworld Forum Discord/(the group there/Beotalk and B&O) is a closed forum….you’ll need an invite.
    If you watch the Beotalk YT show, you probably can get an invite from Miki.
    Millemis
    Hallo Stefan
    Für diesen Oldtimer ist keine Nachrüstung möglich – es gibt für keine von den B&O-geräten Nachrüstmöglichkeiten!
    Beocenter 9300 hat jedoch Anschlussmöglichkeit für externe Geräte…….DAB+ adapter gibt es jede Menge auf dem Markt.
    Diese müssen dann extern bedient werden.
    Die einzige Möglichkeit – die ich kenne – für eine einigermaßen integrierte Lösung ist die von Oneremote.dk.
    Siehe mal hier
    in reply to: Beovision 11-46 wall mounting #63089
    Millemis
    Best consult an installer.
    They might have installed one of these recently – maybe they have the spare parts.
    in reply to: Beovision 11-46 wall mounting #63088
    Millemis
    in reply to: Beovision 11-46 wall mounting #63086
    Millemis
    Could you maybe describe what you actually have!
    Maybe someone else can chime in ?
    It is a long time since I dealt with that – do not remember exactly.
    I’d have to stand in front of one to recall it.
    However this is what it looks like, when installed:
    IMG_1101
