Millemis
Forum Replies Created
Viewing 20 posts - 61 through 80 (of 1,253 total)
  • in reply to: Beolab 3 – Questions regarding setup #68185
    Millemis
    For sure a good find 😀
    Why not try out both option to see how you get most of your new speakers.
    Since it seems that you already have a running setup in the bedroom, start with the living room.
    With the BL2 the 3’s will be an upgrade!
    Millemis
    I know this product.
    (Btw – it has already been presented on the Beoworld Forum some years ago).
    It is developed and is sold as a solution for all those, who wants to maintain their MasterLink setup and – because they have lost the old school analog FM radio – wants to add an internet radio option.
    I find it very well described on the website.
    Also you can se the BT version (=4.2) there.
    I would not be worried about BT….nothing that I use, but it should be sufficient for those, who likes BT streaming.
    Also there is an option for including a turntable to the mix.
    Since the Aux input of the AudioMaster is used for connecting the box, this is via connecting this to the box.
    In my opinion a clever solution….
    ……which unfortunately comes a bit too late for those of us, who already have migrated to a NL-based solution.
    in reply to: oneRemote backup battery? #68049
    Millemis
    Never heard that the device should have a backup battery.
    But it is not unknown, that it looses its settings.
    You will have to set it up again.
    If you want a 100% answer, you could contact OneRemote directly.
    in reply to: EE TV Box Pro #67833
    Millemis
    Seems to be a Sagemcom branded box….if that helps you.
    in reply to: Exchange BSys 3 with BSys 4 on a BV 4-50? #67745
    Millemis
    The biggest problem there will be to find this adapter (9 pin <-> scart female).
    I guess you could use an digital/coax connection for ‘better’ sound.
    The setup will be similar to setting up other external sources.
    As for using the HDMI….that will need some testing.
    Millemis
    I am pretty sure that these internal speakers won’t work, when the tv is connected to the BS Theatre.
    Connecting the tv and the Theatre requires activating ARC/eARC in the tv (and CEC), which normally would exclude sound from internal speakers.
    Only a test can tell.
    Maybe someone else has tried it.
    B&O once made a table of what is possible with 3rd party tv’s.
    The TCL is not in there, but it might give you an idea of the ‘troubles’ when not connecting to a recommended LG- tv.
    By the way – those built-in speakers do not rank high in the tests…
    ….however, they seem to be better than most built-in speakers of the current tv’s.
    And why would you want to use them, when you have a BS Theatre connected 🤔
    in reply to: Office Move – Multicare Electronics (Beoworld) #67567
    Millemis
    For sure….this is noticeable ✔️
    (Safari on iPad)
    Thank you!
    in reply to: BEOSOUND MOMENT: RISK OF FIRE AND EXPLOSION #66879
    Millemis
    Confess I also have a BV11 – less enamoured with that than you are – remote not easy to use in the dark and the drama turning it on with the Bang & Olufsen coming up before anything happens –
    Seems that you use the BROne.
    Why not use a Beo4?
    As for the B&O logo – just set some Quick Start timers and it turns on immediately (with the curtains).
    in reply to: Best B&O solution for Desktop setup? #66730
    Millemis
    @Teun
    Why not just stick to your current setup – it seems that you like it so far.
    If anything…then a set of the BL8’s – that would be a clean setup. But that is a lot of money for a desktop solution.
    P.S.
    I use a set of passive AudioEngine desktop speakers driven by a small amp which is analog connected to a USB-DAC on my Mac Mini.
    But I have space to hide the clutter away….which not everybody has on his desk.
    Works well for me – it does not have to be B&O speakers for my limited use of desktop computing.
    in reply to: 100 Years of Bang & Olufsen – Struer Visit 2025 #66680
    Millemis
    If you plan to go by train from Copenhagen to Struer, you should know that:
    You can get very low fares if you plan and buy tickets at the right moment – you can buy 2 months ahead.
    The prices will vary depending on the time of the day.
    If you are over 65 years old 😉 you pay less.
    I would recommend buying a seat reservation.
    The duration can vary quite a lot – the quickest train rides are at 4 hour 15 minutes approx – with 1 change.
    See this example:
    DSB (danish railroad service) has an english version of their homepage: https://www.dsb.dk/en/
    in reply to: Question for Geoff: Time alignment #66609
    Millemis
    I am pretty sure that Geoff will not see your post – he hasn’t been on the Beoworld forum for a long while.
    Maybe I am wrong…we’ll see.
    In the meantime you could visit his own homepage – I am certain that you will find your answers there.
    Start here: https://www.tonmeister.ca/wordpress/bo-tech/
    in reply to: Beolab 19 vs. Beolab 2 #66494
    Millemis
    A lot of us would be happy to have a setup like yours
    I see no real point in changing from BL2 to BL19….unless you have money to burn.
    Honestly 6xBL9 should provide enough and bass in the room….…..even without the BL2.
    But what do I know 🤣
    P.S. I would not change the BL4000’s to BL3’s – if at all, then to the BL17’s.
    in reply to: Update of the B&O 6.6.3250519 application… #66484
    Millemis
    I am on 663 as well.
    With the two stations, that I listen to most, there are no problems….is as it uses to be.
    in reply to: Is this forum dead? #66465
    Millemis
    Yes this forum is dying a slow death over the last couple years.  Very little engagement these days The discord channel is pretty active so I suggest that.
    That depends on what you are looking for and how.
    The Discord Channel lately seems to have become a playground for people bragging about how many products they have and in which colours respectively how many they can afford…
    …at least partly 😕
    I am sure that you can find answers (if that is what someone is looking for) there, if you dig deeper into it.
    The Beoworld Forum, however is the go to forum for those, who have questions concerning older products/setups.
    The newer products and the use of these are – unfortunately – not very present here nowadays.
    But there are skilled/experienced people here, should someone have questions.
    In the end we much realize that the Beoworld forum is not the only forum on the internet like it used to be.
    The Beoworld forum will probably only survive, if people post/ask here…..and they get relatively snappy answers.
    But honestly – as a long time poster and member – I myself sometimes have my doubts, whether the forum will survive nowadays with all the B&O related groups all over the internet.
    P.S.
    One major benefit of the Beoworld forum is, that the threads here are indexed by Google – a simple Google Search can often lead to answers.
    This is not the case with the different Facebook Groups and Discord Channels!
    in reply to: Is this forum dead? #66452
    Millemis
    Firstly…
    ….what do you want to discuss – feel free to start a discussion (here).
    Secondly….…
    …..yes, there are several Facebook groups and also Discord channels.
    in reply to: Bremdal Radio #66337
    Millemis
    The guys in Bremdal are absolutely ‘good guys’!
    However, you should know that they are closing down the stores (the B&O and the B&O Classic as well) very soon.
    They are now selling what is left.
    For how long the online store will exist is hard to say.
    P.S.
    It is a sad story 😟
    in reply to: B&O Core crashes #65946
    Millemis
    You could try to connect a streaming source e.g. the Macbook (with a physical connection/a cable) to the aux input of the Core…
    …in order to see, if the Core still drops out, when it does not depend on your wifi or ethernet connection.
    in reply to: Beosystem 3000c #65848
    Millemis
    Sure….now that you have teased it, go ahead.
    in reply to: Alternatives for driving a 2.1 Beolab setup #65634
    Millemis
    1: yes, a splitter and or daisychaining will do.
    2: the converter contains a digital to analog converter….otherwise it would not work!
    3: that depends on the setup/the sub etc.
    The PL out on the linked version is also just L/R….it is just easier when you use Beolabs to have PL-out on the converter straight away.
    Some subs have connections for L/R pass through (and some sort of bas management).
    4: sure, in that case the tv has to be on.
    Alternatively – since you have two sets of Beolabs –  you could create two sets…..one for tv and one for music.
    Personally I would not mind the tv being on – for longer listening sessions you can mute/turn off the picture of the C3.
    P.S.
    If you go for the WiiM Ultra, you can connect the C3 there – it contains a HDMI/ARC Converter.
    (The similar B&O device is the Beosound Connect Core).
    It also has a trigger port, so you’d only need the ‘right cables’ for the connection to your Beolabs.
    Feel free to ask Steve@SoundsHeavenly, if you are in the UK.
    If you are in Denmark/Scandinavia, A/V Connection.dk can provide the right ones.
    Millemis
    There should be multiple solutions to this.
    If you want an external streamer (to be used with an app on phone/tablet), you could use the line-in/optical on the Eclipse. Just connect the output of the streamer there.
    If you want to try that out, go for e.g. a WiiM Mini (these devices have good reputations).
    The small box can easily be hidden away. You can even create a seperate Speaker Group for that input….in case you have external speakers connected to the tv.
    If the 1st Generation BeoVision Eclipse still supports Casting, you could just (chrome)cast from the Qobuz app on your device.
    The Qobuz app should be available for download to the tv (?).
    In case this is not supported on the 1st Generation BeoVision Eclipse, you could add a GoogleTV streamer via HDMI…..I am pretty sure you can find the Qobuz app in the Google app store for that.
    In case you lean more towards Apple solutions, you could add an AppleTV box – there is a Qobuz app for that.
