Millemis
Forum Replies Created
Viewing 20 posts - 461 through 480 (of 1,290 total)
  • in reply to: Questions and or suggestions for the B&O app team #50813
    Millemis
    @Miki
    What a weird ending…..why?
    in reply to: Questions and or suggestions for the B&O app team #50812
    Millemis
    You can find the link HERE
    in reply to: Questions and or suggestions for the B&O app team #50810
    Millemis
    Now that Mr Andersen and the app team – or whoever did it – has decided to honor us with a new redesigned app, why didn’t they think of adding the 4 MyButtons to the Now Playing screen?
    We find these MyButtons on the new B&O Mozart devices, on the Beoremote Halo and – not to forget – on the Beoremote One.
    Would have been a cool and usefull feature.
    Maybe Mikipedi4 could ask that question!
    in reply to: Apple TV 4K Settings #51063
    Millemis
    I used some off Amazon, when I installed my Theatre/LG combo a year ago – definitely not something expensive or fancy.
    As long as they are certified, they will be good.
    in reply to: 4pcs of Beolab 5 #51328
    Millemis
    That would be Ultra Party Mode ?
    But – as the post from Mr10% indicates – nothing for ‘critical listening’.
    in reply to: Making a Beosound 5 an auxiliary to a Beosound 9000 #51321
    Millemis
    I never tried other than the standart setups.
    But, since the BM5 has a line-out port and you only need the sound going to your BS9000/AUX, it should be possible to use the appropriate cable for a connection.
    IMG_0785
    The only problems I see there is, that you (probably) will not be able to use the manual volume control on the BS5….in any case it would be better to use volume control via the BS9000.
    Also there will be some troubles with remote controlling of the two units – both will respond, unless you can set the BS/BM5 to option 0.
    In that case you will have to control the BS/BM5 manually and choose A.aux on the BS9000 with the Beo4.
    For how this can be done have a look here on page 20.
    Wish you good luck experimenting – please return with your results.
    P.S.
    Do not use any other cables between the two units.
    And…..you will need a wired ethernet connection from your home network for the BM5.
    in reply to: Beo Converter controls BeoCenter 9500 #51228
    Millemis
    Still there is the question that Carolpa (and also I) asked…..do you have any NL devices in the mix?
    Or do you just think of being able to have an interface on a mobile device (= the app) to control the sources of the BC9500?
    And where will the speakers be connected?
    This is important because of the settings in the NL/ML Converter.
    in reply to: Beo Converter controls BeoCenter 9500 #51219
    Millemis
    It will be something like this (this is my 6500 set and the converters).
    Of cource depending on you setup in general!
    In my case it is also linked to my V1 tv…..which is NL.
    IMG_0779
    P.S.
    Please don’t ask what ‘GeneralDown – GeneralUp’ means….I have no idea ?
    N.B.
    Using the converter only makes sense, if you have NL devices in the setup.
    in reply to: What are you listening to…..right now. #33213
    Millemis
    No need for unwrapping this time ?
    IMG_0777
    in reply to: What are you listening to…..right now. #33211
    Millemis
    Listening to the 1993’ album Crescent Moon from the Cowboy Junkies.
    IMG_2592
    in reply to: Advertising on B&O Radio #51096
    Millemis
    Not what I have noticed.
    Is it on all stations or only on
    some?
    Are you sure you use B&O Radio and not (still) TuneIn?
    in reply to: Looking back to the 1970’s with BeoTalk #51072
    Millemis
    Thanks Keith
    That’s the real Beotalk 😉
    in reply to: Apple TV 4K Settings #51049
    Millemis
    @BeoVision
    If you have a spare PUC/IR Blaster, my advice would be to use that with the ATV, once it is there……..assuming that the spare HDMI cable is connected to the Theatre, of course.
    If that however, is connected to the tv, you only have CEC controlling as an option (which may work fine).
    in reply to: Apple TV 4K Settings #51044
    Millemis
    Pardon me, but what is: ‘a puc cable was run to my comms cab’ – what is a comms cab?
    If the PUC cable was run to another device than the ATV (and just to that), this has no influenze on (PUC) controlling the ATV.
    Probably – when the Theatre was installed – the installer meant to rely on CEC controlling of the ATV by just connecting it to the Theatre or to the LG-tv by a HDMI cable.
    This mostly works fine.
    A lot do it that way – personally I prefer the PUC method.
    In both cases it is controlled with the Beoremote.
    As for optimal settings on the ATV 4K please have a look
    here and here
    Here are some tips about the settings of the LG tv.
    Please notice that there are different views on how to best make these settings.
    A Google search can help.
    The most important setting IMO is the enable ‘Filmmaker Mode’!
    in reply to: Upgrade to Beosound Theatre or not. #50862
    Millemis
    Relax…..as long as you label your cables properly, it is doable.
    69313793098__9B63FDB8-7532-45D9-ACBB-D4B179A9505B
    IMG_1854
    IMG_1855
    in reply to: Theatre + LG TV : TV Recording #50947
    Millemis
    Some versions have – my C2, which I bought in Germany, has a twin tuner ?
    in reply to: Theatre + LG TV : TV Recording #50945
    Millemis
    Does your tv have a dual tuner?
    Millemis
    Maybe this can help a bit.
    By the way nowadays Sonos only work as a Mesh network, if one of the devices is hardwired.
    Otherweise it works over the regular wifi network (which of course can be a Mesh network).
    in reply to: Upgrade to Beosound Theatre or not. #50859
    Millemis
     Are you able to hide yours away?
    Yes, but that is because my tv is placed on a lowboard.
    Actually it is the same, that I had with my (wallmounted) Avant previously – and the BV8-40 before that.
    I need the space there – not just for the ATV – but also for a Bluray player, a network switch, a Chromecast Ultra dongle, the power sockets and ‘cables that are always too long’.
    No need for wall mounting here and no need for turning the tv.
    If you have the Theatre on a tablestand/floorstand, the ATV should be able to fit into the SMI, you’ll need for mounting the tv to the Theatre.
    in reply to: Upgrade to Beosound Theatre or not. #50856
    Millemis
    There is no way you can hide an ATV behind a wallmounted LG….unless you’d make a hole/a cave for it in the wall.
    It makes much more sense to connect it directly to the Theatre (and use the PUC).
    I can assure you, that you can control the ATV just like before – I do that every day.
