beosthlm
Forum Replies Created
Viewing 11 posts - 1 through 11 (of 11 total)
  • in reply to: Beosound 5 encore tablestand issue #108215
    beosthlm
    It’s good that you try this first without cables. I’ve destroyed at least one due to incorrectly positing the mounting bracket. The key is to orient the bracket correctly. There are three orientations and @carolpa’s clip from the mounting instructions show which that is correct. If unsure, just test the three (without attached cables), and see. It should be perfect alignment, otherwise it’s the wrong orientation.
    in reply to: Beosound 5 Encore #81096
    beosthlm
    It only has aux in without metadata unfortunately. Was hoping to upgrade the encore also, but I don’t have one to test with. If you have a BeoSound 5 with a BeoMaster 5, there are more modern options now.
    beosthlm
    Just published v 0.6.0 for those of you interested with support for local playback on your PowerLink speakers from Spotify. Also pops up like a Spotify Connect speakers. So, fingers crossed for your setup, if you play from Spotify the BeoSound 5 will come up as a speaker. Audio will come out through your connected speakers, and the artwork display on the screen. I’ve tested a bit around on one of mine and works well for me, but it’s still at a stage where this is probably not a plug-and-play solution for most just yet. Radio stations are also added.
    I’ll try to gather up some bugs from users to improve the experience of setting this up and running it in various configurations. Ping me through email or GitHub if I can help anybody get up and running.
    beosthlm
    Quick update here. I have added support for PowerLink now for some sources, so it works standalone without Sonos or Bluesound. I have also added more mature support for the SSD / HD in the BeoMaster 5, so plugging that it will connect to the database and show and play your songs. In my testing that has worked quite well. I’ll wrap up this and the CD implementation and will publish a bit more in the README on this. Notably, Spotify on local playback with PowerLink speakers is not implemented yet, and the project is still in an experimental stage with a few technical users successfully set it up. I hope to be able further accessible and feature complete over time.
    in reply to: Beosystem integrating networkplayer project #75425
    beosthlm
    Really nice work so far! Love the look of those matrix LEDs! And impressive what you have got together so far. Keep up the good work!
    in reply to: BeoSound 5c – Open source revival of B&O’s BeoSound 5 #74230
    beosthlm
    Ruedi,
    I have added experimental support for the SSD / HD and so also for CD. Both of those features are bit buggy to say the least and the former is primarily as a proof of concept, but I’m planning to add support for this. I’m not really using master link myself, so uncertain on the amount of work to support that. I’m a bit curious to test it and may hook my BeoSound 9000 to one of the BS5c and have a look, but it’s for a later day. So, in essence it’s multiroom only with Sonos and Bluesound at the moment and quite tailored to my setup (BS5 – Sonos, primarily Spotify as source, and BeoLab 5s). I’ll keep you posted.
    in reply to: BEOSOUND 9000 becomes mute #74228
    beosthlm
    Have you tried the test mode and see what that reports? See e.g., https://archivedforum.beoworld.org/forums/t/24372.aspx
    in reply to: BeoSound 5c – Open source revival of B&O’s BeoSound 5 #73745
    beosthlm
    Hi Ruedi,
    Thank you. The alteration works with all version of the BS/BM5, apart from the Encore. B&O built in the ”master” into the BeoSound 5 Encore, and hence it is significantly more difficult to replace only the ”master”-part of the system.
    Funny you should ask 🙂 I do have a version that supports the ripper also, but it isn’t released yet. I’m intending this more to be able to play CDs lossless in a nice way, rather than ripping them in on a drive though.
    MasterLink is probably quite possible to make work, only in software, but I haven’t gotten to that yet as I don’t have a need to connect any of my BS5c to ML. However, I may add a section to over the network control NL. I have a BeoSound 9000 that could be cool to control that way, and maybe of interest to somebody else as well.
    Yes, it’s quite possible to customize with what you like, e.g., a new section ”Radio” where you can select your streaming channels. Having said so, in it’s current form there is no user friendly configuration do so something like that. Instead, it would require a bit of software development.
    Can you describe more about your setup, and how you ideally would want it to work and I can maybe help you further?
    in reply to: BeoSound 5c – Open source revival of B&O’s BeoSound 5 #73480
    beosthlm
    I have an extra motherboard for the BM5 that you can have for free if it’s of help to you. Email me through the website
    in reply to: BeoSound 5c – Open source revival of B&O’s BeoSound 5 #73475
    beosthlm
    It works without a BM5 too if you want actually. There’s three parts that makes sense reusing from the BM5, but it is flexible
    • Power supply. Without this you need a stable 12V supply and set up the right cable to the BS5 (so it’s easier to just reuse it from the BM5)
    • Daughtercard (that sits on top inside the BM5). Without this IR won’t work. I’m not using MasterLink myself, but that would be possible to make work
    • The box. To keep it tidy
    General failures on the BS5/BM5 has been, to the best of my knowledge the HDDs and the motherboard. None of which that are reused. So hopefully this can revive a few dead units.
    beosthlm
    It can control Sonos, or something else as a player through Home Assistant (or other home control system of your liking). I have set it up so Sonos control goes through HA, but will add an option to control Sonos without HA also. This will both have one less requirement, and on the margin a little bit lower latency.
    It does work perfectly with a Beo4 yes, and also with bluetooth remote if you prefer. With regards to Beoport; if your question is if you have all functionality without a BeoMaster 5, as long as you have a Beoport and a power supply for the BeoSound 5, then it is correct yes. You would then have the BeoSound5(c) working without IR, and you would have IR to the Beoport.
