Mark-sf
Forum Replies Created
Viewing 20 posts - 81 through 100 (of 491 total)
  • in reply to: MMC 6000 Setting Question #70510
    Mark-sf
    The proper setting is MM. it does have lower output than typical.
    in reply to: Cartridge MMC 5000 for Beogram 4000? #70468
    Mark-sf
    The stylus brush that was included with the cartridge is next too useless IMO and if not careful can damage the cantilever. Much better is a gel-based cleaner such as the DS Audio ST-50 which I use. Removing the cartridge is not difficult as long as you have the stylus guard in place. While holding the tone arm from the side (with thumb on top and finger under), use the other hand to pull at a downward slight angle and it will unplug. Before replacing with one of your previously used ones, I would have the stylus checked for wear to preserve your records.
    in reply to: Cartridge MMC 5000 for Beogram 4000? #70407
    Mark-sf
    No problem. Putting it more simply, while the cartridges are compatible they wear out due to use and go bad due to the rubber-type parts aging even if stored in their original box. Unless you purchased them new, you can’t know how many hours of playing time they’ve had. With care your 20E will last up to 800 hrs, and the 5000 to 1000. Only a good microscope can evaluate. A test record can evaluate the rubber suspension state. Be advised a worn out cartridge will damage records. A quality dealer or retipping company can evaluate.
    in reply to: Cartridge MMC 5000 for Beogram 4000? #70374
    Mark-sf
    The MMC5000 has a Shibata-shaped stylus designed to support CD4 records. It has a much narrower profile than the 20E family which is elliptical. Assuming its suspension has not dried out since it was released in the late 70’s (an optimistic assumption) and is not worn out, it is technically compatible. What makes you think it is not?
    in reply to: Cartridge Options for Beogram #70206
    Mark-sf
    Faced with the two options, I would definitely go with the new MMC4 which has a nude elliptical stylus versus the rebuilt MMC5 that has a bonded diamond. The 4 has less mass to resolve more detail and track better.
    in reply to: Beogram 8002 not turning on #70152
    Mark-sf
    Great progress! As to you hum issue, this is most likely the wrong DIN cable adaptor. Since the table has a DIN socket, unless you are connecting DIN->DIN you need a DIN-RCA that has an additional chassis ground wire designed for turntable outputs.
    in reply to: Beogram 2400 #70079
    Mark-sf
    Welcome to the forum! You really cannot evaluate the stylus with a jewelers loop and given that the cartridge is about 45 years old, even if it was in unplayed condition, the suspension would have aged to become the issue. That cartridge was never sold with that model and was a previous generation, so it may have been used when added to that turntable. As to lubrication, that would be centered around the motor bearings as to whether the infused oil has dried out. Once you get a belt, I would test with a record that you are not concerned about damaging. A good dealer may have a stereo microscope to examine the stylus wear. Test records can determine the state of the suspension and motor bearings.
    in reply to: Beogram 6500 carriage movement issue #69961
    Mark-sf
    Alf, it’s important that the pulley is fully counter clockwise against its stoop before mounting the cord. If that is the case then you can manually check its movement by first unplugging it and the push the cam’s toothed bar toward the front and rotate the swing ring counter clockwise to rotate the cam and check its movement.
    in reply to: Help needed, Beogram 6006 #69960
    Mark-sf
    I would set the tracking force to zero, remove the arm cover and ensure the arm floats with no friction up to down. If it doesn’t you have found your issue and need to find where it is binding. Sometimes its the cover, tonearm wires too tight, sticky bearing, etc.
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69892
    Mark-sf
    Emma, you’re welcome. Enjoy with your new addition!
    in reply to: Help needed, Beogram 6006 #69891
    Mark-sf
    I would check that if you manually lower the arm before the edge of the record that it goes down to just above the top plate. I would also check the tracking force calibration.
    in reply to: Beogram 8002 not turning on #69872
    Mark-sf
    Most of the time with these models it is an issue with the ribbon cables between the main board and the other ones including the keypad. I would carefully reflow all of the connections on each cable end. I would also check if your 2MHz clock is running on Pin 11 of IC1.
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69854
    Mark-sf
    In the first instance I have bought a new DIN to RCA cable from Sounds Heavenly as it does seem that B&O pins are wired differently – fingers crossed this works… will keep you posted!
    Thanks so much again, Emma
    Emma, if you get sound but have a hum using the Sounds Heavenly cable, return it and get one that has a separate ground wire that you connect to the thumb screw on your phono preamp. I included an example in my previous reply.
    in reply to: Beogram 5500 to Kanto YU5 speaker set up help #69782
    Mark-sf
    You need a Phono DIN adapter cable to go into your preamp such as this one: https://www.av-connection.com/?PNo=AV-DINPHONO&gad_source=1. The one you’re using is likely connected to the wrong pins and also needs the ground wire.
    in reply to: Beogram 1000 – Motor issue and technical question #69696
    Mark-sf
    On a turntable that old, if its motor is not turning then the grease has hardened and bearings dried out. You never posted what is actually not working.
    in reply to: Beogram 1000 – Motor issue and technical question #69671
    Mark-sf
    That is simply a chassis ground.
    in reply to: Beogram 1000 – Motor issue and technical question #69577
    Mark-sf
    I’m not sure which wire you believe is totally missing. If you are referring to the Red/Black twisted pair in the first picture that appears unconnected, that is normal for 1000’s not equipped with a phono PC board. Yours simply has the jumper board that directly connects the tonearm cable to the output cables which then go into a preamp’s phono inputs. What is actually not working?
    in reply to: Beogram 8002 not turning on #69525
    Mark-sf
    That capacitor is not your problem. You say you don’t have voltage at the 01C1 5V regulator. Does this mean that you measure 0V at both its input and output? If that is the case can you check the continuity of the F1 fuse? If it is good that means you have no output out of the diode bridge and its supporting capacitors.  That’s where I would focus.
    in reply to: Help needed, Beogram 6006 #69485
    Mark-sf
    You need to adjust the aperture (B) so that the arm moves every 2 revolutions. Make sure that stray light does not leak in when doing it.
    in reply to: Beogram 1200 tonearm damage #69441
    Mark-sf
    Your problem is not simply the knob. That amount of damage would have destroyed the arm bearing so that even if you could get the knob in the arm would damage records.
